Charles Talleyrand wrote in
oups.com: On Aug 7, 7:34 am, Bertie the Bunyip wrote: The drag is induced by the cooling itself. How can the drag be induced by the cooling itself? If I understand you, the same cowling with the same air flow shows significantly different drag depending on whether the engine inside is hot or cold. I honestly don't understand that. Not what I mean. the flow inside is quite different with the prop turning or not, though. I'm away at the moment, but I'll look in my library when I get home for a better definition than I can provide off the top of my head..K? In any case, It's Cessna's claim nd not mine that cooling drag was sorted on the airplane. I also recently read an aricle in a very old Sport aviation about the pros and cons of pusher/tractor arrangements. I can't remember if the author came up with a definitive answer as to which was better or more efficient, but I don#'t see how he could, really. Bertie |
monitoring pusher props | Ernest Christley | Home Built | 11 | May 16th 06 11:53 PM |
Pusher props for WW I fighters | John Bailey | Military Aviation | 3 | September 11th 04 10:18 AM |
Interested in Tractor vs. Pusher Gyroplane | Dunewood Truglia, Esq. | Rotorcraft | 1 | July 2nd 04 04:26 PM |
1/2 VW and a shrouded/ducted propeller? | BllFs6 | Home Built | 9 | May 6th 04 05:33 AM |
Ducted Fan Design | David | Home Built | 5 | February 7th 04 06:15 AM |
