Larry Dighera wrote:
On Wed, 8 Aug 2007 08:12:37 -0500, "Gig 601XL Builder" wrDOTgiaconaATsuddenlink.net wrote in : They obviously don't make a 100HP motor of the type you showed or you would have quoted it's specs. Take a look at the ~75 HP electric motor installed in the Sonex Waiex: http://www.sonexaircraft.com/news/im...irventure07/e- flight_5947.jpg Exclusive of the two black boxes, the Sonex motor sure doesn't appear to weigh any where near the 1,118 lbs motor you found. My guess would be under 100 lbs. It is custom built for/by Sonex, so I'm not able to quote its specifications. You don't really believe Sonex is using an electric motor that weighs any where near 1,118 lbs, do you. The entire empty weight of the Waiex is only ~620 lbs with a gross weight of 1150 lbs. Of course I don't. But they might as well be at this point becuse the electric motor they have has never been off the ground. I wish the Sonex guys well and will praise the hell out of them if they do what they are trying to do. But, as I said in a earlier post, I just don't see this big of a technological leap coming from a company whose last major enginnering feat was converting a VW engine for aircraft. If and when it happens it will be either a bunch of guys from MIT or Cal Tech or as the offshoot of a much more profitable electric motor project. |
On Wed, 8 Aug 2007 10:48:40 -0500, "Gig 601XL Builder"
wrDOTgiaconaATsuddenlink.net wrote in : Larry Dighera wrote: On Wed, 8 Aug 2007 08:12:37 -0500, "Gig 601XL Builder" wrDOTgiaconaATsuddenlink.net wrote in : They obviously don't make a 100HP motor of the type you showed or you would have quoted it's specs. Take a look at the ~75 HP electric motor installed in the Sonex Waiex: http://www.sonexaircraft.com/news/im...irventure07/e- flight_5947.jpg Exclusive of the two black boxes, the Sonex motor sure doesn't appear to weigh any where near the 1,118 lbs motor you found. My guess would be under 100 lbs. It is custom built for/by Sonex, so I'm not able to quote its specifications. You don't really believe Sonex is using an electric motor that weighs any where near 1,118 lbs, do you. The entire empty weight of the Waiex is only ~620 lbs with a gross weight of 1150 lbs. Of course I don't. But they might as well be at this point becuse the electric motor they have has never been off the ground. The motor was apparently designed by Bob Boucher. He also designed the motors Dr. Paul MacCready used to fly across the English channel solely under power from the sun, and other successful AeroVironment electrically powered aircraft commissioned by NASA. If anyone can design a proper electric motor for aviation, Mr. Boucher should be able to; he has the past successes to prove it. I wish the Sonex guys well and will praise the hell out of them if they do what they are trying to do. But, as I said in a earlier post, I just don't see this big of a technological leap coming from a company whose last major enginnering feat was converting a VW engine for aircraft. If and when it happens it will be either a bunch of guys from MIT or Cal Tech or as the offshoot of a much more profitable electric motor project. Perhaps. |
Electrically Powered Ultralight Aircraft | Larry Dighera | Piloting | 178 | December 31st 07 08:53 PM |
Solar powered aircraft. Was: Can Aircraft Be Far Behind? | Jim Logajan | Piloting | 4 | February 9th 07 01:11 PM |
World's First Certified Electrically Propelled Aircraft? | Larry Dighera | Piloting | 2 | September 22nd 06 01:50 AM |
Powered gliders = powered aircraft for 91.205 | Mark James Boyd | Soaring | 2 | December 12th 04 03:28 AM |
Help! 2motors propelled ultralight aircraft | [email protected] | Home Built | 3 | July 9th 03 01:02 AM |
