Hi JJ
Thanks for your input. On Wed, 08 Aug 2007 13:29:26 +0000, John Sinclair wrote: I'd cover the hinge gaps on your LS-3 with little pieces of mylar on the flaps and ailerons (look at a ASW-27) they did a meticulous job installing mylar. Then select mylar that just touches the control surface and doesn't go any further. If the mylar is lifted when control in moved, you will get increased stick pressure and it would be a shame to lose the light stick your LS-3 has. This sounds tricky, I must have a good look at a 27. I am not sure how to get mylar to cover the gap but not bend when the surfaces are moved. And as you point out, while the LS3a has not got the best performance it has got lightest controls! I am sure it would be much easier to mess up the control feel with mylar than it would be to increase the performance. What is the relative work in fitting and maintaining mylar verses internal seals? Maybe we should just use hinge tape on its own. Lots of work to replace every season, but possibly as effective as the other options. Don't know if zig-zag works on the LS-3, anybody got performance feedback on that? Ours was fitted by the previous owner. I doubt it has any benefit. Thanks Ian |
Mylar tape | [email protected] | Soaring | 1 | October 31st 06 10:37 AM |
Mylar seals for PIK20D | culverflyer | Soaring | 5 | May 19th 04 06:25 PM |
ZZ Mylar seals | Mike | Soaring | 3 | March 29th 04 03:45 PM |
mylar seals | D.A.L | Soaring | 1 | February 23rd 04 07:15 PM |
Mylar (again) | JJ Sinclair | Soaring | 0 | December 11th 03 10:40 PM |
