Headset recommendation
Old August 9th 07, 06:46 AM posted to rec.aviation.piloting
Morgans[_2_]
Default Headset recommendation
"tony roberts" wrote
No contest - I have flown both.
David Clark X-11
I'm curious. You seem to be going against the stream, by not picking the
Bose.
What are the qualities that make you choose this way?
Jim in NC
Old August 13th 07, 05:45 AM posted to rec.aviation.piloting
tony roberts
Hi Jim
I found the DC's to be more comfortable - they stayed put - the Bose
kept slipping and I had to keep sliding them back into position.
The D C's clarity was superior when listening to transmissions,
The DC's appeared to be much more robust - I had the impression that
they would stand up better,
And after winning all of those areas - they were almost $300.00 less.
Tony
C-GICE
Tony Roberts
PP-ASEL
VFR OTT
Night
Cessna 172H C-GICE
Bose.
Need 12v Outlet Recommendation Kyle Boatright Home Built 5 July 28th 07 04:42 PM
HSI Recommendation? randall g Owning 6 June 13th 07 09:22 PM
ELT Recommendation Dean Owning 3 April 26th 06 09:08 AM
Headset recommendation (Lightspeed L1 and LightFlight Mach 1) Gerald Sylvester Piloting 0 October 27th 05 06:12 AM
ASW 20 Recommendation? Eric Greenwell Soaring 1 August 11th 03 06:56 AM
