![]() "Rich S." wrote Amen to that, Jim. Have you ever let a drill bit spin just for a second on some stainless and work-harden the surface? My downfall is always using a large diameter bit, in a drill press that will not go slow enough, in thick steel. It is amazing how you can take the temper out of a 21/32" bit, in just a couple seconds. DAMHIKT ! Also, I found you can actually get a molten blob of glass on the end of a regular HSS drill bit. You DO have to try quite hard to do that, tho! Especially the part of not breaking the glass, in the process. :-o Sounds like he is using the reamer correctly, tho. It's just the lasered skin that's dulling the tool. I guess the answer is probably pretty obvious, but would it be possible to normalize the steel right around the small area of the hole? Too much loss of strength? It does sound like lowering the tool speed would be worth the try, once the new reamers get there. It will be fairly obvious is the tool speed is too low, once a few holes are attempted. -- Jim in NC |
Reaming needed on aft wing attach point. | Boelkowj | Home Built | 0 | November 7th 03 01:30 AM |
