"Fortunat1" wrote in message
.. . OK, which brings me to another side of this, I guess. I'm hand reaming. By that I mean I'm putting a tap handle on the reamer, sticking the work piece in a vice and going at it by twisting the thing by hand. Needless to say it's nearly impossible to keep the reamer absolutely straight. Am I doing this right? One suggestion I got was to use my drill press by rigging something up to hand turn the drill spindle (no way I can get it to turn slowly enough for reaming) in order to get the reamer straight in. If you look at the top of your hand reamer, I'll bet you'll find a centering hole. Chuck up a tapered center in the drill press and use it to steady the top of the reamer. Rich S. |
"Rich S." wrote in
: "Fortunat1" wrote in message .. . OK, which brings me to another side of this, I guess. I'm hand reaming. By that I mean I'm putting a tap handle on the reamer, sticking the work piece in a vice and going at it by twisting the thing by hand. Needless to say it's nearly impossible to keep the reamer absolutely straight. Am I doing this right? One suggestion I got was to use my drill press by rigging something up to hand turn the drill spindle (no way I can get it to turn slowly enough for reaming) in order to get the reamer straight in. If you look at the top of your hand reamer, I'll bet you'll find a centering hole. Chuck up a tapered center in the drill press and use it to steady the top of the reamer. Hmm, good one. I could alos use the press to regulate the pressure on the tool easily enough that way.. |
Reaming needed on aft wing attach point. | Boelkowj | Home Built | 0 | November 7th 03 01:30 AM |
