Electrically Powered Ultralight Aircraft
Old August 13th 07, 11:45 PM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.ultralight,rec.aviation.soaring
Bill Daniels
Default Electrically Powered Ultralight Aircraft
"Dana M. Hague" d(dash)m(dash)hague(at)comcast(dot)net wrote in message
On Sat, 11 Aug 2007 15:35:25 GMT, Larry Dighera
I would assume that the source of these Li-ion Polymer battery fires
is excessive electrical current flowing through the battery either
from too high a charging rate, too high a discharge rate, or a short
internal (as in the case of the Sony laptop cells) or external, or
being over charged. Perhaps it would be prudent to install a circuit
breaker of fuse to prevent too high a current and a timer to
disconnect a forgotten charger.
I imagine the root of the problem is very low internal resistance
which, while making them very efficient, also allows the current to
"run away". Good circuit design can alleviate many of the issues, but
safety if the batteries are damaged in a crash is still an issue.
-Dana
Any battery chemistry, including lead-acid, can overheat with excess
charging current - usually to the detriment of the battery and whatever it
is in at the time. All can do damage if they are shorted. The problem with
the first generation lithium cells was the chemistry released oxygen when
overheated which combined with the flammable lithium made an incendiary
bomb.
The newest lithium-nanophosphate cells do not release oxygen and thus do not
burn or explode although they can be damaged by overcharging. Cells made by
A123 Systems, Saft, Valence and others are more than safe enough for use in
aircraft or cars. They have a little less energy capacity than the old
chemistry but they make up for it with fast charging and long life. They
can typically manage a 20C discharge rate without harm - that's 200 amps for
a 10 AH battery. Admittedly, you don't want to short that.
Bill Daniels
Electrically Powered Ultralight Aircraft Larry Dighera Piloting 178 December 31st 07 08:53 PM
Electrically Powered Ultralight Aircraft Larry Dighera Home Built 191 August 21st 07 12:29 AM
World's First Certified Electrically Propelled Aircraft? Larry Dighera Piloting 2 September 22nd 06 01:50 AM
Powered gliders = powered aircraft for 91.205 Mark James Boyd Soaring 2 December 12th 04 03:28 AM
Help! 2motors propelled ultralight aircraft [email protected] Home Built 3 July 9th 03 01:02 AM
