Any Ideas on Turning off the Spammer?
Old August 14th 07, 06:36 PM posted to rec.aviation.piloting
Montblack
Default Any Ideas on Turning off the Spammer?
("Mike Flying 8" wrote)
I took the others suggestion and downloaded NFilter and I have none of it.
It is great, easy to setup, and free! I would suggest everyone do the
same.
http://www.nfilter.org/
It doesn't mention XP ...?
Paul-Mont
Old August 14th 07, 07:02 PM posted to rec.aviation.piloting
Mortimer Schnerd, RN[_2_]
same.
Don't worry... it works with XP. I'm running it with XP Pro SP2.
mschnerdatcarolina.rr.com
Old August 14th 07, 07:31 PM posted to rec.aviation.piloting
Mike Flying 8
same.
In addition to the 95/98/NT, it works with XP and Vista.
Thanks for the suggestion MS.
Old August 14th 07, 10:07 PM posted to rec.aviation.piloting
Morgans[_2_]
"Montblack" wrote in message
same.
Would not load on mine.
Jim in NC
Old August 14th 07, 10:21 PM posted to rec.aviation.piloting
alexy
same.
I've been running it on XP pro SP 2 for several years. Can't remember
if there were any "gotchas" on setting it up. Are you familiar with
how it works as a proxy? My startup folder contains a shortcut to
newsproxy.exe, which is a file of 245760 bytes. The folder containing
that file also has a file nfilter.dat with all my filters in it.
What happens when you try to load it?
Alex -- Replace "nospam" with "mail" to reply by email. Checked infrequently.
Old August 14th 07, 10:30 PM posted to rec.aviation.piloting
alexy
same.
Another thought: Might you have a firewall that is blocking it? Might
need to give permission to newsproxy.
Old August 15th 07, 12:32 AM posted to rec.aviation.piloting
Morgans[_2_]
"alexy" wrote in message
Something like file not recognized as a windows 32 file.
Jim in NC
Old August 14th 07, 10:38 PM posted to rec.aviation.piloting
Mike Flying 8
Right Click on the file and extract it to a new directory. Then just
run the EXE file. I originally had the same problem. It was saying
something about 32 bit application, when I extracted it, it works
fine. I do not think it is even necessary to run the setup. On my XP
machine I just copied the directory and ran the exe file.
On another note, I tried to set this up running on my local server,
and then changing the Agent to access the Nfilter at 192.168.0.200
instead of localhost. It did not work. I was going to try and have
this just run on my server for all my PC's on my home network, but it
seems I can not hit my server for some reason. I opened my firewall
for testing and it made no difference.
Any ideas here?
On Tue, 14 Aug 2007 17:07:24 -0400, "Morgans"
same.
Old August 15th 07, 12:34 AM posted to rec.aviation.piloting
Morgans[_2_]
"Mike Flying 8" wrote in message
Any ideas here?
I'll try that. Seems to be my problem.
Jim in NC
Old August 14th 07, 10:48 PM posted to rec.aviation.piloting
Larry Dighera
wrote in :
Word is, that the incompatibility with XP is only the installation
program. Just run nfilter.exe executable file in its own folder, and
it should run fine.
berrie - extremely charming fast downloads - GO AWAY SPAMMER!!!!! Blume, Alf Aviation Photos 0 January 30th 07 09:21 AM
religious spammer origin John T Home Built 6 May 23rd 05 01:54 PM
To that airliners.net spammer (was: New Airplane...Studen pilotagain! TTA Cherokee Driver Owning 0 August 11th 04 04:37 PM
Biggest Usenet SPAMMER Finally Identified!!! ----- O0wTX1aN Dave Kearton Military Aviation 0 July 4th 03 12:22 AM
Biggest Usenet SPAMMER Finally Identified!!! ----- O0wTX1aN Dave Kearton General Aviation 0 July 4th 03 12:22 AM
