#111
Please keep in mind that there are many lithium ion and lithium polymer
chemstries. It isn't too informative to just say "Lithium Polymer" or Lithium Ion" without stating the precise chemistry. Further, chemistries are changing almost daily. Many are proprietary. There's no such thing as a "standard" lithium battery chemistry. Valence, Saft and A123 Systems use chemistries that are far safer than the relatively inexpensive Korean made model airplane batteries - safer than the typical laptop or cell phone battery which are spec'd mainly on price. Interestingly, the safest chemistries in the latest cells also offer faster charging, greater energy density and will endure a FAR greater number of charge cycles. They're also potentially cheaper. I've already made a cell holder for A123 Systems "A1" cells. That's the lithium phosphate nano cathode one used in 36V DeWalt power tools. You can buy a couple of new DeWalt 36V power packs for $50 or so on Ebay. Then, dismantle the pack to retrieve the individual cells. My pack will be 13.8 volts and 11AH weighing 3 pounds. It will be the same size as a 7AH 12V SLA but weigh less than half as much. Bill Daniels Some Lithium cells can suffer thermal runaway and fire. Others are extremely wrote in message oups.com... On Aug 10, 5:12 pm, Dave wrote: Are you able to provide links to any forums or web sites related to this Check this out:http://www.calcars.org/news-archive.html David Johnson Lithium Polymer batteries are widely used in RC planes, cars, etc and are known to be potentially dangerous. Most runaway fires occur during charging but it has also occurred to a lessor degree during discharge and even storage. Vented charging safety bags are recommended for this reason. There is a video on this link that shows the explosive power of small LiPo's. Consider the size differance of these batteries to the one hung under the trike in one of the first posts or those that could be installed in the wings of a sailplane. http://www.liposack.com/video.html |
#112
On Fri, 10 Aug 2007 17:12:09 GMT, Larry Dighera
wrote: It sounds like you have quite a bit of experience in this area. Are you able to provide links to any forums or web sites related to this topic? Try http://electricppg.com I've been flying PPG for about 6 years now; got into it when I realized I couldn't afford to restore my Taylorcraft. Finally managed to get another plane (Kolb this time), but PPG is so much fun I don't intend to give it up. Never flew an electric PPG, though... they're still pretty rare birds. -Dana -- -- If replying by email, please make the obvious changes. ------------------------------------------------------------------------------- Abandon all hope, ye who PRESS ENTER here. |
#113
On Sat, 11 Aug 2007 15:35:25 GMT, Larry Dighera
wrote: I would assume that the source of these Li-ion Polymer battery fires is excessive electrical current flowing through the battery either from too high a charging rate, too high a discharge rate, or a short internal (as in the case of the Sony laptop cells) or external, or being over charged. Perhaps it would be prudent to install a circuit breaker of fuse to prevent too high a current and a timer to disconnect a forgotten charger. I imagine the root of the problem is very low internal resistance which, while making them very efficient, also allows the current to "run away". Good circuit design can alleviate many of the issues, but safety if the batteries are damaged in a crash is still an issue. -Dana -- -- If replying by email, please make the obvious changes. ------------------------------------------------------------------------------- Abandon all hope, ye who PRESS ENTER here. |
#114
![]() "Dana M. Hague" d(dash)m(dash)hague(at)comcast(dot)net wrote in message ... On Sat, 11 Aug 2007 15:35:25 GMT, Larry Dighera wrote: I would assume that the source of these Li-ion Polymer battery fires is excessive electrical current flowing through the battery either from too high a charging rate, too high a discharge rate, or a short internal (as in the case of the Sony laptop cells) or external, or being over charged. Perhaps it would be prudent to install a circuit breaker of fuse to prevent too high a current and a timer to disconnect a forgotten charger. I imagine the root of the problem is very low internal resistance which, while making them very efficient, also allows the current to "run away". Good circuit design can alleviate many of the issues, but safety if the batteries are damaged in a crash is still an issue. -Dana -- Any battery chemistry, including lead-acid, can overheat with excess charging current - usually to the detriment of the battery and whatever it is in at the time. All can do damage if they are shorted. The problem with the first generation lithium cells was the chemistry released oxygen when overheated which combined with the flammable lithium made an incendiary bomb. The newest lithium-nanophosphate cells do not release oxygen and thus do not burn or explode although they can be damaged by overcharging. Cells made by A123 Systems, Saft, Valence and others are more than safe enough for use in aircraft or cars. They have a little less energy capacity than the old chemistry but they make up for it with fast charging and long life. They can typically manage a 20C discharge rate without harm - that's 200 amps for a 10 AH battery. Admittedly, you don't want to short that. Bill Daniels |
#115
On Mon, 13 Aug 2007 17:39:44 -0400, Dana M. Hague
d(dash)m(dash)hague(at)comcast(dot)net wrote in : safety if the batteries are damaged in a crash is still an issue. I would think the hazard somewhat less than gasoline. |
#116
It's sort of like a neighbor of mine who was complaining
about the price of gas - his SUV only gets 12MPG. I suggested he think about pushing his 6000 pound truck 12 miles by hand. That would give him the proper respect for the energy in a gallon of gasoline - and its value. Liquid petroleum fuels are extremely energy dense. It's going to be really hard to replace that with electricity. But maybe not impossible. Bill Daniels For many applications a better 'alternative energy' might be to squeeze the maximum available power out of existing technology. Below is an engine which uses the heat from combustion to add another power stroke to an engine. Its not electrically powered but in the future it may compete with electric engines. http://www.popsci.com/popsci/technology/ c1609351d9092110vgnvcm1000004eecbccdrcrd.html Name: Steam-o-Lene Engine Inventor: Bruce Crower Cost to Develop: $1,000 Time: 1.5 years Prototype | | | | | Product Bruce Crower's Southern California auto-racing parts shop is a temple for racecar mechanics. Here's the flat eight-cylinder Indycar engine that won him the 1977 Louis Schwitzer Award for racecar design. There's the Mercedes five-cylinder engine he converted into a squealing supercharged two-stroke, just 'to see what it would sound like,' says the now half-deaf 77-year-old self-taught engineer. Crower has spent a lifetime eking more power out of every drop of fuel to make cars go faster. Now he's using the same approach to make them go farther, with a radical six-stroke engine that tops off the familiar four-stroke internal-combustion process with two extra strokes of old- fashioned steam power. A typical engine wastes three quarters of its energy as heat. Crower's prototype, the single-cylinder diesel eight-horsepower Steam-o-Lene engine, uses that heat to make steam and recapture some of the lost energy. It runs like a conventional four-stroke combustion engine through each of the typical up-and-down movements of the piston (intake, compression, power or combustion, exhaust). But just as the engine finishes its fourth stroke, water squirts into the cylinder, hitting surfaces as hot as 1,500°F. The water immediately evaporates into steam, generating a 1,600-fold expansion in volume and driving the piston down to create an additional power stroke. The upward sixth stroke exhausts the steam to a condenser, where it is recycled into injection water. Crower calculates that the Steam-o-Lene boosts the work it gets from a gallon of gas by 40 percent over conventional engines. Diesels, which are already more efficient, might get another 5 percent. And his engine does it with hardware that already exists, so there's no waiting for technologies to mature, as with electric cars or fuel cells. 'Crower is an innovator who tries new ideas based on his experience and gut instincts,' says John Coletti, the retired head of Ford's SVT high- performance group. 'Most people won't try something new for fear of failure, but he is driven by a need to succeed.' And he just might. Crower has been keeping the details of his system quiet, waiting for a response to his patent application. When he gets it, he'll pass off the development process to a larger company that can run with it, full- steam. |
#117
Warning: A boring essay on obsolete internal combustion technology follows.
A merging of steam and internal combustion is probably the first "hybrid" with the first efforts dating from the beginning of the last century. The pinacle of its development was the monster water-injected turbo-compound radial engines developed late in WWII. Water injection acts is several favorable ways. First, somewhat as described below, it flashes into steam to increase the cylinder pressure and then escapes through the exhaust valves to a pressure recovery turbine which transmits its power back to the crankshaft through a fluid coupling - the "turbo compound" part. Water also cools the cylinder allowing more fuel/air mixtue to be forced into it. Finally, and this not widely known, water is even more effective than tetraethyl lead in decreasing the tendency of the fuel/air mixture to detonate or pre-ignite thus allowing far higher boost pressures. The only compound more effective than water is nitros oxide. Both Allied and Axis ari forces used water injection but only Germany used nitros oxide. Either could double an engines power for as long as the supply of H2O or NO lasted. But, on a power to weight basis, avgas easily wins so water injection was only used for takeoff or when maximum military power was needed to escape an enemy. The citation for the above is a very old engineering textbook titled "High Speed Internal Combustion Engines" by Sir Harry Recardo. I highly recomend it if you are at all interested in IC engines. Sir Harry's work on sleeve valve engines is particularly interesting. I could be wrong but I would guess that water injection gets 90% of the benifits possible without the major modification to the engine required by Bruce Crower's "6-stroke". Bill Daniels "Steve Davis" wrote in message ... It's sort of like a neighbor of mine who was complaining about the price of gas - his SUV only gets 12MPG. I suggested he think about pushing his 6000 pound truck 12 miles by hand. That would give him the proper respect for the energy in a gallon of gasoline - and its value. Liquid petroleum fuels are extremely energy dense. It's going to be really hard to replace that with electricity. But maybe not impossible. Bill Daniels For many applications a better 'alternative energy' might be to squeeze the maximum available power out of existing technology. Below is an engine which uses the heat from combustion to add another power stroke to an engine. Its not electrically powered but in the future it may compete with electric engines. http://www.popsci.com/popsci/technology/ c1609351d9092110vgnvcm1000004eecbccdrcrd.html Name: Steam-o-Lene Engine Inventor: Bruce Crower Cost to Develop: $1,000 Time: 1.5 years Prototype | | | | | Product Bruce Crower's Southern California auto-racing parts shop is a temple for racecar mechanics. Here's the flat eight-cylinder Indycar engine that won him the 1977 Louis Schwitzer Award for racecar design. There's the Mercedes five-cylinder engine he converted into a squealing supercharged two-stroke, just 'to see what it would sound like,' says the now half-deaf 77-year-old self-taught engineer. Crower has spent a lifetime eking more power out of every drop of fuel to make cars go faster. Now he's using the same approach to make them go farther, with a radical six-stroke engine that tops off the familiar four-stroke internal-combustion process with two extra strokes of old- fashioned steam power. A typical engine wastes three quarters of its energy as heat. Crower's prototype, the single-cylinder diesel eight-horsepower Steam-o-Lene engine, uses that heat to make steam and recapture some of the lost energy. It runs like a conventional four-stroke combustion engine through each of the typical up-and-down movements of the piston (intake, compression, power or combustion, exhaust). But just as the engine finishes its fourth stroke, water squirts into the cylinder, hitting surfaces as hot as 1,500°F. The water immediately evaporates into steam, generating a 1,600-fold expansion in volume and driving the piston down to create an additional power stroke. The upward sixth stroke exhausts the steam to a condenser, where it is recycled into injection water. Crower calculates that the Steam-o-Lene boosts the work it gets from a gallon of gas by 40 percent over conventional engines. Diesels, which are already more efficient, might get another 5 percent. And his engine does it with hardware that already exists, so there's no waiting for technologies to mature, as with electric cars or fuel cells. 'Crower is an innovator who tries new ideas based on his experience and gut instincts,' says John Coletti, the retired head of Ford's SVT high- performance group. 'Most people won't try something new for fear of failure, but he is driven by a need to succeed.' And he just might. Crower has been keeping the details of his system quiet, waiting for a response to his patent application. When he gets it, he'll pass off the development process to a larger company that can run with it, full- steam. |
#118
On Mon, 13 Aug 2007 17:39:44 -0400, Dana M. Hague d(dash)m(dash)hague(at)comcast(dot)net wrote in : safety if the batteries are damaged in a crash is still an issue. I would think the hazard somewhat less than gasoline. The battery can produce it's own ignition source. |
#119
On Tue, 14 Aug 2007 08:40:29 -0500, "Gig 601XL Builder"
wrDOTgiaconaATsuddenlink.net wrote in : Larry Dighera wrote: On Mon, 13 Aug 2007 17:39:44 -0400, Dana M. Hague d(dash)m(dash)hague(at)comcast(dot)net wrote in : safety if the batteries are damaged in a crash is still an issue. I would think the hazard somewhat less than gasoline. The battery can produce it's own ignition source. You have a point. While a source of ignition (sparking wires, hot muffler?) is required to ignite post-crash gasoline fumes, it would take an un-fused short circuit or significant deformation of a battery to potentially ignite a lithium battery. Granted, if the crash occurs as a result of fuel exhaustion, there is little fire hazard, while the lithium would always be aboard. |
#120
On Aug 13, 8:10 pm, "Bill Daniels" bildan@comcast-dot-net wrote:
Warning: A boring essay on obsolete internal combustion technology follows. A merging of steam and internal combustion is probably the first "hybrid" with the first efforts dating from the beginning of the last century. The pinacle of its development was the monster water-injected turbo-compound radial engines developed late in WWII. Water injection acts is several favorable ways. First, somewhat as described below, it flashes into steam to increase the cylinder pressure and then escapes through the exhaust valves to a pressure recovery turbine which transmits its power back to the crankshaft through a fluid coupling - the "turbo compound" part. Water also cools the cylinder allowing more fuel/air mixtue to be forced into it. Finally, and this not widely known, water is even more effective than tetraethyl lead in decreasing the tendency of the fuel/air mixture to detonate or pre-ignite thus allowing far higher boost pressures. The only compound more effective than water is nitros oxide. Both Allied and Axis ari forces used water injection but only Germany used nitros oxide. Either could double an engines power for as long as the supply of H2O or NO lasted. But, on a power to weight basis, avgas easily wins so water injection was only used for takeoff or when maximum military power was needed to escape an enemy. The citation for the above is a very old engineering textbook titled "High Speed Internal Combustion Engines" by Sir Harry Recardo. I highly recomend it if you are at all interested in IC engines. Sir Harry's work on sleeve valve engines is particularly interesting. I could be wrong but I would guess that water injection gets 90% of the benifits possible without the major modification to the engine required by Bruce Crower's "6-stroke". Bill Daniels "Steve Davis" wrote in message ... It's sort of like a neighbor of mine who was complaining about the price of gas - his SUV only gets 12MPG. I suggested he think about pushing his 6000 pound truck 12 miles by hand. That would give him the proper respect for the energy in a gallon of gasoline - and its value. Liquid petroleum fuels are extremely energy dense. It's going to be really hard to replace that with electricity. But maybe not impossible. Bill Daniels For many applications a better 'alternative energy' might be to squeeze the maximum available power out of existing technology. Below is an engine which uses the heat from combustion to add another power stroke to an engine. Its not electrically powered but in the future it may compete with electric engines. http://www.popsci.com/popsci/technology/ c1609351d9092110vgnvcm1000004eecbccdrcrd.html Name: Steam-o-Lene Engine Inventor: Bruce Crower Cost to Develop: $1,000 Time: 1.5 years Prototype | | | | | Product Bruce Crower's Southern California auto-racing parts shop is a temple for racecar mechanics. Here's the flat eight-cylinder Indycar engine that won him the 1977 Louis Schwitzer Award for racecar design. There's the Mercedes five-cylinder engine he converted into a squealing supercharged two-stroke, just 'to see what it would sound like,' says the now half-deaf 77-year-old self-taught engineer. Crower has spent a lifetime eking more power out of every drop of fuel to make cars go faster. Now he's using the same approach to make them go farther, with a radical six-stroke engine that tops off the familiar four-stroke internal-combustion process with two extra strokes of old- fashioned steam power. A typical engine wastes three quarters of its energy as heat. Crower's prototype, the single-cylinder diesel eight-horsepower Steam-o-Lene engine, uses that heat to make steam and recapture some of the lost energy. It runs like a conventional four-stroke combustion engine through each of the typical up-and-down movements of the piston (intake, compression, power or combustion, exhaust). But just as the engine finishes its fourth stroke, water squirts into the cylinder, hitting surfaces as hot as 1,500°F. The water immediately evaporates into steam, generating a 1,600-fold expansion in volume and driving the piston down to create an additional power stroke. The upward sixth stroke exhausts the steam to a condenser, where it is recycled into injection water. Crower calculates that the Steam-o-Lene boosts the work it gets from a gallon of gas by 40 percent over conventional engines. Diesels, which are already more efficient, might get another 5 percent. And his engine does it with hardware that already exists, so there's no waiting for technologies to mature, as with electric cars or fuel cells. 'Crower is an innovator who tries new ideas based on his experience and gut instincts,' says John Coletti, the retired head of Ford's SVT high- performance group. 'Most people won't try something new for fear of failure, but he is driven by a need to succeed.' And he just might. Crower has been keeping the details of his system quiet, waiting for a response to his patent application. When he gets it, he'll pass off the development process to a larger company that can run with it, full- steam.- Hide quoted text - - Show quoted text - The reference in Sir Harry Recardo's book to doubling HP with water injection and Nitrous Oxide could lead someone to believe that those two ingredients were all that was needed. There is no advantage to injecting water into a conventional normally aspirated 4-stroke IC engine although an endless array of systems to do so has been sold to the unwary. Water or water/alcohol injection however has long been known to do an excellent job of reducing combustion temperatures thereby preventing detonation. While this is of little importance in a normally aspirated engine it is a big help in forced induction engines. I have used both water and water/alcohol in two turbocharged motorcycle engines over a 15-year period with very good results. Dyno results have not shown any measurable added HP from the water alone (possibly because the water displaces some air/fuel mixture) but it allows a significant increase in boost pressure, which can add a bunch. Any engine dependent on this scheme for detonation protection will however self-destruct in short order should the water flow stop. Nitrous Oxide injection provides more oxygen, which in turn allows more fuel to be added which is the source of the extra HP. Crower's Steam-o-Lene is another matter. Think I'll wait until they go into mass production. It must have an interesting exhaust sound. |
Electrically Powered Ultralight Aircraft | Larry Dighera | Piloting | 178 | December 31st 07 08:53 PM |
Electrically Powered Ultralight Aircraft | Larry Dighera | Home Built | 191 | August 21st 07 12:29 AM |
World's First Certified Electrically Propelled Aircraft? | Larry Dighera | Piloting | 2 | September 22nd 06 01:50 AM |
Powered gliders = powered aircraft for 91.205 | Mark James Boyd | Soaring | 2 | December 12th 04 03:28 AM |
Help! 2motors propelled ultralight aircraft | [email protected] | Home Built | 3 | July 9th 03 01:02 AM |
