#101
On 2007-08-14 07:32:35 -0700, "Martin X. Moleski, SJ"
said: On Tue, 14 Aug 2007 08:48:34 -0500, "Gig 601XL Builder" wrDOTgiaconaATsuddenlink.net wrote in : ... it seems a second wave of the crap made it though Supernews' filters. I've got about 50 today and this is the first I've seen of it. I saw some this morning. Maybe a couple of dozen. Pretty easy to tell by eye which were real r.a.p threads and which were not. Marty I did not see them, but I am filtering out anything cross-posted to sci.crypt. -- Waddling Eagle World Famous Flight Instructor |
#102
![]() "Montblack" wrote in message ... ("Mike Flying 8" wrote) I took the others suggestion and downloaded NFilter and I have none of it. It is great, easy to setup, and free! I would suggest everyone do the same. http://www.nfilter.org/ It doesn't mention XP ...? Would not load on mine. -- Jim in NC |
#103
"Morgans" wrote:
"Montblack" wrote in message ... ("Mike Flying 8" wrote) I took the others suggestion and downloaded NFilter and I have none of it. It is great, easy to setup, and free! I would suggest everyone do the same. http://www.nfilter.org/ It doesn't mention XP ...? Would not load on mine. I've been running it on XP pro SP 2 for several years. Can't remember if there were any "gotchas" on setting it up. Are you familiar with how it works as a proxy? My startup folder contains a shortcut to newsproxy.exe, which is a file of 245760 bytes. The folder containing that file also has a file nfilter.dat with all my filters in it. What happens when you try to load it? -- Alex -- Replace "nospam" with "mail" to reply by email. Checked infrequently. |
#104
alexy wrote:
"Morgans" wrote: "Montblack" wrote in message ... ("Mike Flying 8" wrote) I took the others suggestion and downloaded NFilter and I have none of it. It is great, easy to setup, and free! I would suggest everyone do the same. http://www.nfilter.org/ It doesn't mention XP ...? Would not load on mine. I've been running it on XP pro SP 2 for several years. Can't remember if there were any "gotchas" on setting it up. Are you familiar with how it works as a proxy? My startup folder contains a shortcut to newsproxy.exe, which is a file of 245760 bytes. The folder containing that file also has a file nfilter.dat with all my filters in it. What happens when you try to load it? Another thought: Might you have a firewall that is blocking it? Might need to give permission to newsproxy. -- Alex -- Replace "nospam" with "mail" to reply by email. Checked infrequently. |
#105
Right Click on the file and extract it to a new directory. Then just
run the EXE file. I originally had the same problem. It was saying something about 32 bit application, when I extracted it, it works fine. I do not think it is even necessary to run the setup. On my XP machine I just copied the directory and ran the exe file. On another note, I tried to set this up running on my local server, and then changing the Agent to access the Nfilter at 192.168.0.200 instead of localhost. It did not work. I was going to try and have this just run on my server for all my PC's on my home network, but it seems I can not hit my server for some reason. I opened my firewall for testing and it made no difference. Any ideas here? On Tue, 14 Aug 2007 17:07:24 -0400, "Morgans" wrote: "Montblack" wrote in message ... ("Mike Flying 8" wrote) I took the others suggestion and downloaded NFilter and I have none of it. It is great, easy to setup, and free! I would suggest everyone do the same. http://www.nfilter.org/ It doesn't mention XP ...? Would not load on mine. |
#106
wrote in : http://www.nfilter.org/ It doesn't mention XP ...? Would not load on mine. Word is, that the incompatibility with XP is only the installation program. Just run nfilter.exe executable file in its own folder, and it should run fine. |
#107
![]() "alexy" wrote in message What happens when you try to load it? Something like file not recognized as a windows 32 file. -- Jim in NC |
#108
![]() "Mike Flying 8" wrote in message ... Right Click on the file and extract it to a new directory. Then just run the EXE file. I originally had the same problem. It was saying something about 32 bit application, when I extracted it, it works fine. I do not think it is even necessary to run the setup. On my XP machine I just copied the directory and ran the exe file. On another note, I tried to set this up running on my local server, and then changing the Agent to access the Nfilter at 192.168.0.200 instead of localhost. It did not work. I was going to try and have this just run on my server for all my PC's on my home network, but it seems I can not hit my server for some reason. I opened my firewall for testing and it made no difference. Any ideas here? I'll try that. Seems to be my problem. -- Jim in NC |
#109
On Tue, 14 Aug 2007 14:07:45 -0400, Dudley Henriques wrote:
You devious fellow you!!!! Laugh I cannot take credit for any of what I wrote. There've been plenty of articles in periodicals I read discussing this over the years. - Andrew |
#110
On Tue, 14 Aug 2007 13:25:06 -0500, Gig 601XL Builder wrote:
It a great leap when compared to Mr. Henriques' theory that it was some guy getting his jollies. Oh. I see what you mean, now. - Andrew |
berrie - extremely charming fast downloads - GO AWAY SPAMMER!!!!! | Blume, Alf | Aviation Photos | 0 | January 30th 07 09:21 AM |
religious spammer origin | John T | Home Built | 6 | May 23rd 05 01:54 PM |
To that airliners.net spammer (was: New Airplane...Studen pilotagain! | TTA Cherokee Driver | Owning | 0 | August 11th 04 04:37 PM |
Biggest Usenet SPAMMER Finally Identified!!! ----- O0wTX1aN | Dave Kearton | Military Aviation | 0 | July 4th 03 12:22 AM |
Biggest Usenet SPAMMER Finally Identified!!! ----- O0wTX1aN | Dave Kearton | General Aviation | 0 | July 4th 03 12:22 AM |
