Mounting 396
Old August 15th 07, 01:45 AM posted to rec.aviation.piloting,rec.aviation.owning
Paul kgyy
Default Mounting 396
On Aug 14, 5:38 pm, "Dan Luke" wrote:
Bottom line, I found the yoke mount handy and had no problems with it.
How did you do the wiring to provide free movement of the yoke?
Old August 15th 07, 12:37 PM posted to rec.aviation.piloting,rec.aviation.owning
Dan Luke[_2_]
Under the yoke shaft I attached an adhesive tie-wrap clip to the panel.
Before I tie-wrapped the cables to the clip, I pulled the yoke out to its full
aft travel. The cables then trailed below the yoke shaft along with the PTT
cable. This setup was unobtrusive and caused no interference problems with
the yoke.
Dan
T-182T at BFM
Mounting 396 Paul kgyy Piloting 40 August 24th 07 08:47 AM
Mounting Cambridge 10 in ASW-19 jcarlyle Soaring 0 February 27th 06 01:48 PM
ELT Mounting for an ASW20-C Papa3 Soaring 11 January 26th 06 06:37 AM
Mounting my GPS Charles Talleyrand Owning 8 November 19th 03 11:51 AM
Mounting my GPS Charles Talleyrand Piloting 8 November 19th 03 11:51 AM
