On Fri, 17 Aug 2007 11:28:06 -0700, Phil wrote
in .com: It might be possible to get enough capacity there for a practical general aviation electric plane. It might indeed. But I'd have to know more about the paper battery specifications before I could render any sort of judgment. I guess we'll have to wait until more information is disclosed. Let's see ..... http://www.eetimes.com/news/semi/rss...etimes_semiRSS Paper battery is rechargeable R. Colin Johnson EE Times (08/14/2007 9:42 AM EDT) PORTLAND, Ore. — Rensselaer Polytechnic Institute researchers said they have developed a paper-thin battery by immersing a carpet of vertical nanotubes in an ionic liquid electrolyte. The result is a cellulose paper that stores electrical energy. The RPI team produced a supercapacitor by placing a second nanotube electrode on the other side of the paper. They then added a lithium electrode atop the paper, creating what they claim is a paper-thin rechargeable battery. "The carbon nanotubes are embedded in the paper, and the electrolyte is soaked into the paper, so it really looks, feels and weighs about the same as paper," said RPI professor Robert Linhardt. The supercapcitor and rechargeable battery are the result of a year and half of collaborative research among three RPI labs. One lab was making carbon nanotube-based structures, which were adapted to serve as a battery electrode. By growing the nanotubes vertically on a sheet, liquid cellulose was poured between the "forest of nanotubes" to form the battery. Another lab added a lithium-based top electrode to create either a rechargeable battery or a supercapacitor by adding a second nanotube electrode. Ionic liquids first dissolved the cellulose, turning it into a gel. The fluids also serve as the battery electrolyte, carrying ions from one side of the paper battery to the other. Each sheet of battery-paper generated about 2.4 volts with a power density of about 0.6 milliamps/cm2. For higher voltages, paper can be stacked. For more current, the sheets can be expanded to larger areas. The battery-paper operates from minus 100 degrees up to 300 degrees Fahrenheit, and can deliver quick surges of current, the RPI researchers claim. It can also be rolled twisted or cut into many shapes. So far, the RPI researchers have only cycled their paper batteries through 100 rechargings. But they claim no deterioration in performance has been detected after recharging. Next, they plan long-term testing of the batteries to determine the maximum number of rechargings, and to optimize the design for higher power densities. ... http://www.uberreview.com/2007/08/fl...-institute.htm It does not function better than existing batteries on the market and at present it is extremely expensive to produce. http://news.rpi.edu/update.do?artcenterkey=2280 Contact: Michael Mullaney Phone: (518) 276-6161 E-mail: “We’re not putting pieces together – it’s a single, integrated device,” he said. “The components are molecularly attached to each other: the carbon nanotube print is embedded in the paper, and the electrolyte is soaked into the paper. The end result is a device that looks, feels, and weighs the same as paper.” Can someone make the necessary conversions to compare the power density of about 0.6 milliamps/cm2 for the paper battery to secondary lithium-ion Polymer batteries at 130 - 1200 Wh/kg*? * http://xtronics.com/reference/energy_density.htm |
The original paper battery article is available on-line:
http://www.pnas.org/cgi/content/abst...urcetype=HWCIT Proceedings of the National Academy of Sciences of the United States of America Published online before print August 15, 2007 Proc. Natl. Acad. Sci. USA, 10.1073/pnas.0706508104 This Article Full Text (PDF) Articles by Pushparaj, V. L. Articles by Ajayan, P. M. Engineering Flexible energy storage devices based on nanocomposite paper To whom correspondence should be addressed. Pulickel M. Ajayan, E-mail: |
Electrically Powered Ultralight Aircraft | Larry Dighera | Piloting | 178 | December 31st 07 08:53 PM |
Solar powered aircraft. Was: Can Aircraft Be Far Behind? | Jim Logajan | Piloting | 4 | February 9th 07 01:11 PM |
World's First Certified Electrically Propelled Aircraft? | Larry Dighera | Piloting | 2 | September 22nd 06 01:50 AM |
Powered gliders = powered aircraft for 91.205 | Mark James Boyd | Soaring | 2 | December 12th 04 03:28 AM |
Help! 2motors propelled ultralight aircraft | [email protected] | Home Built | 3 | July 9th 03 01:02 AM |
