Electrically Powered Ultralight Aircraft
Old August 17th 07, 04:03 PM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.ultralight,rec.aviation.soaring
Charles Vincent
Default Electrically Powered Ultralight Aircraft
In rec.aviation.piloting Tim Ward wrote:
The advantage from the electric engine at cruise is that it uses zero
energy.
Snippage
Jim Pennino
Remove .spam.sux to reply.
You want to support this, somehow?
Tim Ward
At cruise the electric motor is turned off.
The only energy used is some slight bearing friction.
The electric motor is only turned on when more power than the gas
engine can provide is needed.
To carry more weight at the same speed and altitude takes more power, so
you have to account for the energy expended kiting you deadweight
electric takeoff system around the sky as well. Sizing an engine for
cruise has been done, if only backwards. Think JATO. Most JATO's are
actually RATO (rocket assisted takeoff). I expect RATO would beat an
electric system based on energy density and the fact that when it is
done you have reduced your weight by the fuel. I also suspect for a
given amount of thrust the rocket will be lighter than an electric motor
and associated clutches and gearing. In my opinion, at this point in
time it is just as practical for a homebuilt as well as in not.
Charles
Old August 17th 07, 04:35 PM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.ultralight,rec.aviation.soaring
energy.
Snippage
Jim Pennino
Tim Ward
Well, that's true enough, but the above was about hybrid cars.
Jim Pennino
Old August 17th 07, 05:15 PM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.ultralight,rec.aviation.soaring
No, it's not true enough.
To carry more weight at the same speed and altitude requires more LIFT.
A higher CL - and/or more wing area.
THEN, to overcome the increased drag, THEN you need more power.
But more power by itself won't satisfy the constraints...
So if I add 1 pound to a 2400 pound gross aircraft loaded to 2300 pounds,
it would be impossible to cruise at the same speed and altitude without
the 1 pound unless I added wing area?
How about 50 pounds?
Jim Pennino
Old August 17th 07, 05:32 PM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.ultralight,rec.aviation.soaring
Charles Vincent
No. You can increase the angle of attack, which increases the lift ( to
a limit) and also increases the drag, which must be overcome with more
power. If your speed drops, so does the lift. If you could increase
your aspect ratio, you could get more lift at the same speed at the same
power I think. So I guess Richard is flying a swing wing texas
parasol.;') For the rest of us, we have to add power to carry more
weight at the same speed and altitude. Since most planes lose weight
while in flight in the real world, you actually have the opposite issue.
Charles
Old August 17th 07, 06:35 PM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.ultralight,rec.aviation.soaring
Gee, you mean all I gotta do is tweek the trim and throttle a bit?
Who'd have guessed it? :-)
Jim Pennino
Old August 17th 07, 07:56 PM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.ultralight,rec.aviation.soaring
cavelamb himself[_4_]
Charles
Don't be snotty, Charles.
Since the subject is an electrically powered aircraft, the weight issue
is not trivial. That's been my issue with this thread from the start.
The constraints given here were to fly at the same speed and altitude
but at a higher weright.
You can increase lift via increased angle of attack only as far as
CLmax. No Farther. (You seem to have that part right)
Beyond that any increased weight will require increased wing area.
Aspect ratio alone won't answer is most cases.
And - an electric powered plane would NOT lose weight in flight.
No electrons are "consumed" - no change in battery weight.
Old August 17th 07, 09:02 PM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.ultralight,rec.aviation.soaring
Charles Vincent
Not really being snotty at all. Frankly, I was in the process of
deleting screenfulls of messages on the topic of electric powered
airplanes being as the subject really holds no interest for me. For
some reason I happened to read "The advantage from the electric engine
at cruise is that it uses zero energy" on one message just as I deleted
it. Pulling it back from the trash, I felt compelled to respond to it.
My mistake. For some reason you are in turn compelled to nit pick my
correct assertion because it did not completely cover the relevant
aerodynamic theory. In my opinion, it covered enough, but not following
the thread, I have no idea what sort of debate has been raging. As I
stated elsewhere, I just didn't expect that information required for
even the most basic pilot ticket would be the subject of any debate
here. In the end, to fly at the same speed and altitude but at a higher
weight requires more power be applied, whether you use that power to
drag the same wing at a higher angle of attack or a bigger wing doesn't
change that. Or you could use more power to drag the wing at a higher
speed to generate the lift you needed. All of this ignores the fact
that for internal combustion aircraft powerplants, the weight per HP
goes down as the power goes up. Last time I looked at it, the opposite
is true of electric motors. I don't think an electric assist for an IC
engine is going to be viable for aircraft in the near future.
Charles
Old August 17th 07, 05:25 PM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.ultralight,rec.aviation.soaring
Charles Vincent
so you have to account for the energy expended kiting you
deadweight electric takeoff system around the sky as well. Sizing
an engine for cruise has been done, if only backwards. Think JATO.
Most JATO's are actually RATO (rocket assisted takeoff). I expect
RATO would beat an electric system based on energy density and the
fact that when it is done you have reduced your weight by the fuel.
I also suspect for a given amount of thrust the rocket will be
lighter than an electric motor and associated clutches and gearing.
In my opinion, at this point in time it is just as practical for a
The original remark said "To carry more weight at the same speed and
altitude takes more power" -- which you have now taken the time to
substantiate with more detail. It never said it was the only factor,
and didn't need to, to rebut the earlier claim. I do not understand how
you arrive at it not being true. Frankly, I would expect any one
engaged in building or flying an airplane to understand those
relationships, and based on the FAA's published pilot exam questions and
other materials, it seems they agree.
Charles
Old August 17th 07, 05:04 PM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.ultralight,rec.aviation.soaring
Charles Vincent
energy.
Snippage
Jim Pennino
Tim Ward
Well in cruise in a car, more weight does not increase your aerodynamic
drag like it does on an airplane, but it does increase your rolling
resistance in the real world, so there is no free lunch. Different
tradeoffs for different missions. I guess that is why cheetahs and
sparrows look so different.
Charles
Electrically Powered Ultralight Aircraft Larry Dighera Piloting 178 December 31st 07 08:53 PM
Electrically Powered Ultralight Aircraft Larry Dighera Home Built 191 August 21st 07 12:29 AM
World's First Certified Electrically Propelled Aircraft? Larry Dighera Piloting 2 September 22nd 06 01:50 AM
Powered gliders = powered aircraft for 91.205 Mark James Boyd Soaring 2 December 12th 04 03:28 AM
Help! 2motors propelled ultralight aircraft [email protected] Home Built 3 July 9th 03 01:02 AM
