In rec.aviation.piloting Dan Luke wrote:
"Charles Vincent" wrote: Just because it is not noticeable, or measurable by the lack of sensitivity with the instrument you are currently not using, does not mean that it does not exist. More weight on the bearings will cause more rolling resistance. That is fact, not open to dispute. If you say it is, I want to buy the rights to the bearings you are using, so I can patent them and make a fortune. If a bird craps on your windshield, it is more likely to noticeably influence your aerodynamic drag than rolling resistance.....I took Jim's "can't be found" to mean lost in the noise. According to SAE studies, aerodynamic drag accounts for 60% of the resistance that must be overcome for highway cruise, with tires being 25% and driveline friction making up the last 15%. Pardon the intrusion on this interesting discussion, but just how *does* added weight in a car impose extra load on the powerplant besides via bearing friction and tire deformation? It takes more power to accelerate the car to cruise speed in a given time. F=ma Added weight means the powerplant is doing more work to maintain the same speed; there's no way around it, the laws of physics demand it. So where's the extra power going? Ummm, no, quite the opposite. The laws of physics say once an object is in motion it takes no energy to maintain the velocity UNLESS there is some other force at work that would cause the velocity to decrease. Since at a constant speed, the a in F=ma is zero, the force is zero no matter the mass. Once at speed in a car (or airplane or rocket ship) the only energy needed to maintain speed is that equal to any drag forces that would otherwise slow the car down. Have you looked at the current crop of high mileage cars? They all have very aerodynamic profiles to get the air drag down. -- Jim Pennino Remove .spam.sux to reply. |
In rec.aviation.piloting Ernest Christley wrote:
wrote: The laws of physics say once an object is in motion it takes no energy to maintain the velocity UNLESS there is some other force at work that would cause the velocity to decrease. Since at a constant speed, the a in F=ma is zero, the force is zero no matter the mass. Once at speed in a car (or airplane or rocket ship) the only energy needed to maintain speed is that equal to any drag forces that would otherwise slow the car down. Have you looked at the current crop of high mileage cars? They all have very aerodynamic profiles to get the air drag down. They also have very narrow, hard tires. Unfortunately, the DOT has laws against solid rubber tires or they could be made even harder. Your analysis would be mostly correct if we were talking about trains. My analysis of what? The biggest source of drag on a car is air followed by tires. Of course the makers are going to put hard tires on as well as streamline the vehicle to get mileage up. The less drag, the less gas the vehicle uses. What's your point? -- Jim Pennino Remove .spam.sux to reply. |
In rec.aviation.piloting Charles Vincent wrote:
wrote: The biggest source of drag on a car is air followed by tires. Of course the makers are going to put hard tires on as well as streamline the vehicle to get mileage up. The less drag, the less gas the vehicle uses. What's your point? That is only true in cruise on the highway. In stop and go city driving driveline friction is the majority, followed by inertia. Air and tire is a small percentage combined. Inertia is not drag. Inertia is F=ma. In stop and go driving, F=ma dominates. If it didn't, hybrids converting the F in deceleration into energy in the batteries instead of heat in the brakes wouldn't get their high mileage numbers. -- Jim Pennino Remove .spam.sux to reply. |
In rec.aviation.piloting Ernest Christley wrote: wrote: The laws of physics say once an object is in motion it takes no energy to maintain the velocity UNLESS there is some other force at work that would cause the velocity to decrease. Since at a constant speed, the a in F=ma is zero, the force is zero no matter the mass. Once at speed in a car (or airplane or rocket ship) the only energy needed to maintain speed is that equal to any drag forces that would otherwise slow the car down. Have you looked at the current crop of high mileage cars? They all have very aerodynamic profiles to get the air drag down. They also have very narrow, hard tires. Unfortunately, the DOT has laws against solid rubber tires or they could be made even harder. Your analysis would be mostly correct if we were talking about trains. My analysis of what? The biggest source of drag on a car is air followed by tires. Of course the makers are going to put hard tires on as well as streamline the vehicle to get mileage up. The less drag, the less gas the vehicle uses. What's your point? The point is that weight matters...even in land-locked vehicles. |
wrote: In rec.aviation.piloting Ernest Christley wrote: wrote: The laws of physics say once an object is in motion it takes no energy to maintain the velocity UNLESS there is some other force at work that would cause the velocity to decrease. Since at a constant speed, the a in F=ma is zero, the force is zero no matter the mass. Once at speed in a car (or airplane or rocket ship) the only energy needed to maintain speed is that equal to any drag forces that would otherwise slow the car down. Have you looked at the current crop of high mileage cars? They all have very aerodynamic profiles to get the air drag down. They also have very narrow, hard tires. Unfortunately, the DOT has laws against solid rubber tires or they could be made even harder. Your analysis would be mostly correct if we were talking about trains. My analysis of what? The biggest source of drag on a car is air followed by tires. Of course the makers are going to put hard tires on as well as streamline the vehicle to get mileage up. The less drag, the less gas the vehicle uses. What's your point? The point is that weight matters...even in land-locked vehicles. In cars, weight matters most in acceleration and doesn't matter in any significant amount with modern tires in cruise. -- Jim Pennino Remove .spam.sux to reply. |
wrote)
In cars, weight matters most in acceleration and doesn't matter in any significant amount with modern tires in cruise. Speculate please: 1. Two 3,600 lb cars - good tires 2. Traveling 60 mph (no wind) 3. 4cly - 150 hp (Honda Accords) 3. Flat highway in North Dakota 4. Fuel flow meters hooked up to both vehicles (Honda #1) Driver ................ 105 lbs Fuel .................... 15 lbs TOTAL .............. 120 lbs (1/30th of 3,600 lb car) (Honda #2) Driver ................. 300 lbs Passengers ........ 700 lbs Luggage ............. 100 lbs Fuel ................... 100 lbs TOTAL ............. 1,200 lbs (1/3 of 3,600 lb car) ....BTW, BTDT! g If both vehicles were monitored for 50 miles, would their fuel flow be (approx) the same, in cruise? Paul-Mont |
In rec.aviation.piloting Montblack wrote:
wrote) In cars, weight matters most in acceleration and doesn't matter in any significant amount with modern tires in cruise. Speculate please: 1. Two 3,600 lb cars - good tires 2. Traveling 60 mph (no wind) 3. 4cly - 150 hp (Honda Accords) 3. Flat highway in North Dakota 4. Fuel flow meters hooked up to both vehicles (Honda #1) Driver ................ 105 lbs Fuel .................... 15 lbs TOTAL .............. 120 lbs (1/30th of 3,600 lb car) (Honda #2) Driver ................. 300 lbs Passengers ........ 700 lbs Luggage ............. 100 lbs Fuel ................... 100 lbs TOTAL ............. 1,200 lbs (1/3 of 3,600 lb car) ....BTW, BTDT! g If both vehicles were monitored for 50 miles, would their fuel flow be (approx) the same, in cruise? A pulled out of my ass, wild assed guess is that since you are increasing the load by 33%, then yes, you will see a difference, and at that loading the tires will be visibly deformed. Now, would you care to calculate the energy required to accelerate 3720 pounds to 60 mph versus accelerating 4800 pounds to 60 mph? Assume gasoline is 45 megajoules per kilogram and the engine is 38% efficient. You may neglect all drag for this calculation and express the energy in kilograms of gasoline. -- Jim Pennino Remove .spam.sux to reply. |
Electrically Powered Ultralight Aircraft | Larry Dighera | Piloting | 178 | December 31st 07 08:53 PM |
Solar powered aircraft. Was: Can Aircraft Be Far Behind? | Jim Logajan | Piloting | 4 | February 9th 07 01:11 PM |
World's First Certified Electrically Propelled Aircraft? | Larry Dighera | Piloting | 2 | September 22nd 06 01:50 AM |
Powered gliders = powered aircraft for 91.205 | Mark James Boyd | Soaring | 2 | December 12th 04 03:28 AM |
Help! 2motors propelled ultralight aircraft | [email protected] | Home Built | 3 | July 9th 03 01:02 AM |
