wrote)
The coefficient of drag for motorcycles is usually pretty bad unless they are faired, and it still ain't great. The power required to overcome drag is 1/2(p*v^3*A*C) p is the densitity of the fluid v is the airspeed A is the area C is the coefficient of drag 80-ft length of the semi (vs.) 8-ft length of the motorcycle Does this play (much) of a role here? Is that role expressed (adequately/sufficiently) in the above formula, through "C" ...drag? Paul-Mont http://www.totalmotorcycle.com/motorcyclespecshandbook/1MotorcycleManufacturer.htm Fun site - make / model / year. My Yamahoppers were both in there. |
In rec.aviation.piloting Montblack wrote:
wrote) The coefficient of drag for motorcycles is usually pretty bad unless they are faired, and it still ain't great. The power required to overcome drag is 1/2(p*v^3*A*C) p is the densitity of the fluid v is the airspeed A is the area C is the coefficient of drag 80-ft length of the semi (vs.) 8-ft length of the motorcycle Does this play (much) of a role here? Is that role expressed (adequately/sufficiently) in the above formula, through "C" ...drag? The C is the catchall variable that is determinded by the object's overall shape and for all but the most simple shapes (i.e. flat plate, sphere, etc.) determined by measurement. As to what length does specifically, it depends. Smooth sides are going to be less "draggy" than lumpy sides. A flat back end is going to be more "draggy" than a tapered back end. -- Jim Pennino Remove .spam.sux to reply. |
Solar powered aircraft. Was: Can Aircraft Be Far Behind? | Jim Logajan | Piloting | 4 | February 9th 07 01:11 PM |
World's First Certified Electrically Propelled Aircraft? | Larry Dighera | Piloting | 2 | September 22nd 06 01:50 AM |
Powered gliders = powered aircraft for 91.205 | Mark James Boyd | Soaring | 2 | December 12th 04 03:28 AM |
Is JB Weld electrically conductive? | Scott | Home Built | 14 | July 12th 04 11:24 PM |
Help! 2motors propelled ultralight aircraft | [email protected] | Home Built | 3 | July 9th 03 01:02 AM |
