Well, IS IT (after it cures, that is)???
Scott http://corbenflyer.tripod.com Building RV-4 Gotta Fly or Gonna Die |
Scott wrote in message ...
Well, IS IT (after it cures, that is)??? Scott http://corbenflyer.tripod.com Building RV-4 Gotta Fly or Gonna Die I can not speak for JB WELD but I do know, for a fact, that BELZONA (1111) Super Metal is not conductive. It also will not rot, shrink, rust, or corrode. No solvents in Super Metal and does not stink like JB Weld. Excellent compressive and shear-adheision strength. It will stand up avgas, mogas, or jet fuel. It does not run off like JB WELD. I have built Belzona 1"thick on horizontal and verticle surfaces and it stays put. Amazing stuff, to say the least! |
Clay wrote:
Scott wrote in message ... Well, IS IT (after it cures, that is)??? Scott http://corbenflyer.tripod.com Building RV-4 Gotta Fly or Gonna Die I can not speak for JB WELD but I do know, for a fact, that BELZONA (1111) Super Metal is not conductive. It also will not rot, shrink, rust, or corrode. No solvents in Super Metal and does not stink like JB Weld. Excellent compressive and shear-adheision strength. It will stand up avgas, mogas, or jet fuel. It does not run off like JB WELD. I have built Belzona 1"thick on horizontal and verticle surfaces and it stays put. Amazing stuff, to say the least! Are you using the same JB Weld I do? I have never found it to stink or run off. Of course I do not stick my nose right in it to see if it smells. :-) Jerry |
I do not have to stick my nose in JB Weld. I find the odor offensive.
But that may just be me. I have used a couple of varieties of JB Weld and it will work in some situations however, if you check the product specification sheets Belzona is much stronger mechanical properties. Caterpiller corporation specifies Belzona for repairs in their engine blocks. Jerry Springer wrote in message link.net... Clay wrote: Scott wrote in message ... Well, IS IT (after it cures, that is)??? Scott http://corbenflyer.tripod.com Building RV-4 Gotta Fly or Gonna Die I can not speak for JB WELD but I do know, for a fact, that BELZONA (1111) Super Metal is not conductive. It also will not rot, shrink, rust, or corrode. No solvents in Super Metal and does not stink like JB Weld. Excellent compressive and shear-adheision strength. It will stand up avgas, mogas, or jet fuel. It does not run off like JB WELD. I have built Belzona 1"thick on horizontal and verticle surfaces and it stays put. Amazing stuff, to say the least! Are you using the same JB Weld I do? I have never found it to stink or run off. Of course I do not stick my nose right in it to see if it smells. :-) Jerry |
"Clay" wrote in message om... I do not have to stick my nose in JB Weld. I find the odor offensive. But that may just be me. I have used a couple of varieties of JB Weld and it will work in some situations however, if you check the product specification sheets Belzona is much stronger mechanical properties. Caterpiller corporation specifies Belzona for repairs in their engine blocks. It sounds interesting where can I find some? Tony |
"Scott" wrote in message
... Well, IS IT (after it cures, that is)??? Doesn't appear to be. I tried measuring the resistance of a recent repair using an autoranging ohmmeter. Even with the probes almost touching each other, it read infinity. Rich S. |
Rich,
Thanks for the "field test"!!! I did find on the European JB website that it is not conductive after set up. Dang, I need something that IS conductive (well, not really, but it would be nice)... Scott Rich S. wrote: "Scott" wrote in message ... Well, IS IT (after it cures, that is)??? Doesn't appear to be. I tried measuring the resistance of a recent repair using an autoranging ohmmeter. Even with the probes almost touching each other, it read infinity. Rich S. |
... Rich, Thanks for the "field test"!!! I did find on the European JB website that it is not conductive after set up. Dang, I need something that IS conductive (well, not really, but it would be nice)... Add a pinch of powdered Magnesium, some gunpowder, litharge and glycerin. Rich "plugging my ears" S. |
"B2431" wrote in message
... Rich, I'd venture to say he'd like to have it conduct more than once. Oh. The Fourth of July is over for this year I guess. Rich "Explosive ways to lose 13 lbs. of ugly fat." S. |
| Thread Tools | |
| Display Modes | |
| JB Weld or Hi Temp RTV silicone oil crack fix. | Paul Lee | Home Built | 7 | July 12th 04 04:12 PM |
| Learning to weld with a non-aircraft project | Ed | Home Built | 36 | March 31st 04 05:06 AM |
| What is best "JB Weld" type epoxy putty? | [email protected] | Home Built | 4 | March 8th 04 08:45 AM |
| Tube Cluster Weld Question | Dick | Home Built | 6 | January 17th 04 01:10 AM |
