Electrically Powered Ultralight Aircraft
Old August 18th 07, 11:13 PM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.ultralight,rec.aviation.soaring
Montblack
Default Electrically Powered Ultralight Aircraft
("Charles Vincent" wrote)
According to SAE studies, aerodynamic drag accounts for 60% of the
resistance that must be overcome for highway cruise, with tires being 25%
and driveline friction making up the last 15%.
Semi:
Tires ........... 18
Footprint ..... big per tire
Weight ....... 80,000 lbs
Drag .......... HUGE!!
MPG .......... 5 (loaded)
Minivan:
Tires ........... 4
Footprint ..... smaller per tire
Weight ....... 4,000 lbs (for easy math)
Drag .......... MUCH less + no cab/trailer drag
MPG .......... 22
I've never really understood why an 800 lb motorcycle/rider gets (only) 50
mpg and a fully loaded semi can get (about) 5 mpg?
Motorcycle:
Tires ........... 2
Footprint ..... very small per tire
Weight ....... 800 lbs (with rider)
Drag .......... It's a motorcycle! g
MPG ........... 50
Paul-Mont
Old August 19th 07, 12:11 AM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.ultralight,rec.aviation.soaring
Matt Whiting
Semi:
Minivan:
Tires ........... 4
MPG .......... 22
Motorcycle:
Tires ........... 2
MPG ........... 50
Motorcycles have a terrible coefficient of drag given their shape and
the shape of the rider. A fully faired bike is much better, but still
much worse than most cars. My K1200LT is one of the better motorcycles
and its Cd is above 0.5 with the windshield fully lowered and I believe
it is closer to 0.6 with the windshield at the highest setting.
So even with the relatively small frontal area as compared to a car
(although not as much smaller as you might think as the bike is taller
than most cars), the drag coefficient is so high that the total drag is
quite high in comparison.
Matt
Old August 19th 07, 12:13 AM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.ultralight,rec.aviation.soaring
Matt Whiting
Motorcycle:
Tires ........... 2
MPG ........... 50
Paul-Mont
Check this: http://www.bgsoflex.com/airdragchart.html
Matt
Old August 19th 07, 12:45 AM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.ultralight,rec.aviation.soaring
Semi:
Minivan:
Tires ........... 4
MPG .......... 22
Motorcycle:
Tires ........... 2
MPG ........... 50
The coefficient of drag for motorcycles is usually pretty bad unless
they are faired, and it still ain't great.
The power required to overcome drag is 1/2(p*v^3*A*C)
p is the densitity of the fluid
v is the airspeed
A is the area
C is the coefficient of drag
Jim Pennino
Remove .spam.sux to reply.
Old August 20th 07, 12:36 AM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.ultralight,rec.aviation.soaring
Montblack
wrote)
The coefficient of drag for motorcycles is usually pretty bad unless they
v is the airspeed
A is the area
80-ft length of the semi
(vs.)
8-ft length of the motorcycle
Does this play (much) of a role here?
Is that role expressed (adequately/sufficiently) in the above formula,
through "C" ...drag?
Paul-Mont
http://www.totalmotorcycle.com/motorcyclespecshandbook/1MotorcycleManufacturer.htm
Fun site - make / model / year. My Yamahoppers were both in there.
Old August 20th 07, 01:25 AM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.ultralight,rec.aviation.soaring
wrote)
v is the airspeed
A is the area
(vs.)
The C is the catchall variable that is determinded by the object's
overall shape and for all but the most simple shapes (i.e. flat plate,
sphere, etc.) determined by measurement.
As to what length does specifically, it depends.
Smooth sides are going to be less "draggy" than lumpy sides.
A flat back end is going to be more "draggy" than a tapered back end.
Jim Pennino
Electrically Powered Ultralight Aircraft Larry Dighera Piloting 178 December 31st 07 08:53 PM
Solar powered aircraft. Was: Can Aircraft Be Far Behind? Jim Logajan Piloting 4 February 9th 07 01:11 PM
World's First Certified Electrically Propelled Aircraft? Larry Dighera Piloting 2 September 22nd 06 01:50 AM
Powered gliders = powered aircraft for 91.205 Mark James Boyd Soaring 2 December 12th 04 03:28 AM
Help! 2motors propelled ultralight aircraft [email protected] Home Built 3 July 9th 03 01:02 AM
