wrote)
In cars, weight matters most in acceleration and doesn't matter in any significant amount with modern tires in cruise. Speculate please: 1. Two 3,600 lb cars - good tires 2. Traveling 60 mph (no wind) 3. 4cly - 150 hp (Honda Accords) 3. Flat highway in North Dakota 4. Fuel flow meters hooked up to both vehicles (Honda #1) Driver ................ 105 lbs Fuel .................... 15 lbs TOTAL .............. 120 lbs (1/30th of 3,600 lb car) (Honda #2) Driver ................. 300 lbs Passengers ........ 700 lbs Luggage ............. 100 lbs Fuel ................... 100 lbs TOTAL ............. 1,200 lbs (1/3 of 3,600 lb car) ....BTW, BTDT! g If both vehicles were monitored for 50 miles, would their fuel flow be (approx) the same, in cruise? Paul-Mont |
In rec.aviation.piloting Montblack wrote:
wrote) In cars, weight matters most in acceleration and doesn't matter in any significant amount with modern tires in cruise. Speculate please: 1. Two 3,600 lb cars - good tires 2. Traveling 60 mph (no wind) 3. 4cly - 150 hp (Honda Accords) 3. Flat highway in North Dakota 4. Fuel flow meters hooked up to both vehicles (Honda #1) Driver ................ 105 lbs Fuel .................... 15 lbs TOTAL .............. 120 lbs (1/30th of 3,600 lb car) (Honda #2) Driver ................. 300 lbs Passengers ........ 700 lbs Luggage ............. 100 lbs Fuel ................... 100 lbs TOTAL ............. 1,200 lbs (1/3 of 3,600 lb car) ....BTW, BTDT! g If both vehicles were monitored for 50 miles, would their fuel flow be (approx) the same, in cruise? A pulled out of my ass, wild assed guess is that since you are increasing the load by 33%, then yes, you will see a difference, and at that loading the tires will be visibly deformed. Now, would you care to calculate the energy required to accelerate 3720 pounds to 60 mph versus accelerating 4800 pounds to 60 mph? Assume gasoline is 45 megajoules per kilogram and the engine is 38% efficient. You may neglect all drag for this calculation and express the energy in kilograms of gasoline. -- Jim Pennino Remove .spam.sux to reply. |
Electrically Powered Ultralight Aircraft | Larry Dighera | Piloting | 178 | December 31st 07 08:53 PM |
Electrically Powered Ultralight Aircraft | Larry Dighera | Home Built | 191 | August 21st 07 12:29 AM |
World's First Certified Electrically Propelled Aircraft? | Larry Dighera | Piloting | 2 | September 22nd 06 01:50 AM |
Powered gliders = powered aircraft for 91.205 | Mark James Boyd | Soaring | 2 | December 12th 04 03:28 AM |
Help! 2motors propelled ultralight aircraft | [email protected] | Home Built | 3 | July 9th 03 01:02 AM |
