Electrically Powered Ultralight Aircraft
Old August 20th 07, 12:36 AM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.ultralight,rec.aviation.soaring
Montblack
Default Electrically Powered Ultralight Aircraft
wrote)
The coefficient of drag for motorcycles is usually pretty bad unless they
are faired, and it still ain't great.
The power required to overcome drag is 1/2(p*v^3*A*C)
p is the densitity of the fluid
v is the airspeed
A is the area
C is the coefficient of drag
80-ft length of the semi
(vs.)
8-ft length of the motorcycle
Does this play (much) of a role here?
Is that role expressed (adequately/sufficiently) in the above formula,
through "C" ...drag?
Paul-Mont
http://www.totalmotorcycle.com/motorcyclespecshandbook/1MotorcycleManufacturer.htm
Fun site - make / model / year. My Yamahoppers were both in there.
Old August 20th 07, 01:25 AM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.ultralight,rec.aviation.soaring
In rec.aviation.piloting Montblack wrote:
wrote)
v is the airspeed
A is the area
(vs.)
The C is the catchall variable that is determinded by the object's
overall shape and for all but the most simple shapes (i.e. flat plate,
sphere, etc.) determined by measurement.
As to what length does specifically, it depends.
Smooth sides are going to be less "draggy" than lumpy sides.
A flat back end is going to be more "draggy" than a tapered back end.
Jim Pennino
Remove .spam.sux to reply.
Electrically Powered Ultralight Aircraft Larry Dighera Piloting 178 December 31st 07 08:53 PM
Electrically Powered Ultralight Aircraft Larry Dighera Home Built 191 August 21st 07 12:29 AM
World's First Certified Electrically Propelled Aircraft? Larry Dighera Piloting 2 September 22nd 06 01:50 AM
Powered gliders = powered aircraft for 91.205 Mark James Boyd Soaring 2 December 12th 04 03:28 AM
Help! 2motors propelled ultralight aircraft [email protected] Home Built 3 July 9th 03 01:02 AM
