![]() "Michael Horowitz" wrote It's a rag and tube a/c and we're talking holes in the steel. I can send you an illustration via e-mail showing the hole in the landing gear strut if you're interested - Mike That goes against convention, for rag and tube aircraft, from everything I have read. The tubes should have holes at joints, so all of the insides of the tubes are connected to each other. All of the tubes should not be open to the outside air. That is the only way that rust inside of the tubes can be prevented. Linseed oil is (one of the most popular things) used, because of the ability to coat the inside of the bare metal tubes, and because the oil oxidizes (binds with the free oxygen) and that leaves an environment inside the tubes that prevents the steel from rusting. If you are capable of keeping the inside without free oxygen, there can be no oxidation (rusting) of the tubes. Some aerobatic rag and tub aircraft have a air fill valve, and a pressure gauge where it can be checked at every pre-flight. It is then filled with some gas, like nitrogen or argon. If the pressure is lower, or at atmospheric pressure, there is a crack somewhere, meaning that it might not be structurally sound, especially for high G loads. I think you have some decisions to make, as how to proceed with your airplane. It would seem to me that you need to be able to see if the tubes are still sound, and that you need to seal that sucker up and coat the inside with something. JMHO. -- Jim in NC |
Morgans wrote:
"Michael Horowitz" wrote It's a rag and tube a/c and we're talking holes in the steel. I can send you an illustration via e-mail showing the hole in the landing gear strut if you're interested - Mike That goes against convention, for rag and tube aircraft, from everything I have read. The tubes should have holes at joints, so all of the insides of the tubes are connected to each other. All of the tubes should not be open to the outside air. That is the only way that rust inside of the tubes can be prevented. There seems to be two conventions then, Jim. One is as you describe. The other is to make sure that water doesn't have a place to collect by providing a drain hole at the lowest point. The Dyke Delta's rear spar and elevon spars are completely open. If kept in a reasonably dry environment, the less labor intensive method is sufficient. The Delta prototype, N555A, has lasted 45 years. John Dyke just announced that he has found rust in the elevon spars and may have to ground the plane. If you expect the airplane to fly over the beaches of the world forever, then a 100% guaranteed seal is necessary. For the rest of us, I'm not so sure that is the case. |
![]() "Ernest Christley" wrote There seems to be two conventions then, Jim. One is as you describe. The other is to make sure that water doesn't have a place to collect by providing a drain hole at the lowest point. The Dyke Delta's rear spar and elevon spars are completely open. If kept in a reasonably dry environment, the less labor intensive method is sufficient. The Delta prototype, N555A, has lasted 45 years. John Dyke just announced that he has found rust in the elevon spars and may have to ground the plane. If you expect the airplane to fly over the beaches of the world forever, then a 100% guaranteed seal is necessary. For the rest of us, I'm not so sure that is the case. Humm. I wonder if the extra labor to do the sealed method is that significant, compared to all of the time and effort it takes to weld up a good fuselage. I tend to think the extra effort is not significant, but to each his own. There is something in me that _does not want to accept_ the fact that there can be damage happening that can not be inspected visually, and that gives no sign that "bad things" are happening, and if allowed to continue, could cause a failure and an almost certain injury and possible death. I can not accept that a little more effort in sealing the inside of the tubes is not worth what ever extra effort it takes. That is just me, though. I guess you know where I stand on the subject now, don't you! g -- Jim in NC |
![]() "Morgans" wrote in message ... Some aerobatic rag and tub aircraft have a air fill valve, and a pressure gauge where it can be checked at every pre-flight. It is then filled with some gas, like nitrogen or argon. If the pressure is lower, or at atmospheric pressure, there is a crack somewhere, meaning that it might not be structurally sound, especially for high G loads. Some helicopters also pressurize the rotor blades and monitor real time for pressure drop... |
Shaking off the Rust | john smith | Piloting | 22 | March 1st 07 12:36 AM |
New book / close calls / accident prevention / Bob Wander | [email protected] | Soaring | 0 | September 11th 06 11:04 PM |
Looking for a fuselage | Jay Honeck | Home Built | 79 | March 7th 05 01:42 PM |
Inside | Rivière | Owning | 0 | February 11th 04 10:10 AM |
Rust inhibitor? | Steve Thomas | Home Built | 10 | August 30th 03 09:34 PM |
