Well, the nose of the camel is having the gummint require us to check
in with ATC on every flight (and pay their fees) as is common in some european countries... As far as me personally, ATC could vanish and it would affect me very little - and that 'little' could be worked around... I file IFR less and less... When I do not file IFR I do not need ATC... I can, do, and have, flown from one border of this country to the other without talking to ATC... Without ATC, if the weather is IFR I would have to lay over until it improves... That would affect roughly 10% of my trips... From my point of view an acceptable price for having the gummint off my back... denny |
Warning... thread drift.
After watching 60 Minutes last night, I am more convinced than ever that Lock Mart is a disaster and the federal government is so in bed with them that we're screwed. |
On Mon, 20 Aug 2007 04:30:58 -0700, Denny wrote
in . com: As far as me personally, ATC could vanish and it would affect me very little - and that 'little' could be worked around... I file IFR less and less... When I do not file IFR I do not need ATC... I can, do, and have, flown from one border of this country to the other without talking to ATC... Out here in the Los Angeles basin, the air traffic is so thick, that I wouldn't consider not using Radar Advisory Service on VFR flights. But if I had to pay for it, I might reconsider that decision. Privatized, user fee based, ATC must necessarily negatively impact air safety, because it provides a disincentive (dollar price) against the use of aviation services meant to enhance safety. |
![]() "Larry Dighera" wrote in message ... On Mon, 20 Aug 2007 04:30:58 -0700, Denny wrote in . com: As far as me personally, ATC could vanish and it would affect me very little - and that 'little' could be worked around... I file IFR less and less... When I do not file IFR I do not need ATC... I can, do, and have, flown from one border of this country to the other without talking to ATC... Out here in the Los Angeles basin, the air traffic is so thick, that I wouldn't consider not using Radar Advisory Service on VFR flights. But if I had to pay for it, I might reconsider that decision. Privatized, user fee based, ATC must necessarily negatively impact air safety, because it provides a disincentive (dollar price) against the use of aviation services meant to enhance safety. If, with a simple box upgrade, you could be sure that you knew where all the traffic was, would you still want the radar advisories? think ADS/B |
On Mon, 20 Aug 2007 18:31:53 -0400, "Blueskies"
wrote in : "Larry Dighera" wrote in message ... On Mon, 20 Aug 2007 04:30:58 -0700, Denny wrote in . com: As far as me personally, ATC could vanish and it would affect me very little - and that 'little' could be worked around... I file IFR less and less... When I do not file IFR I do not need ATC... I can, do, and have, flown from one border of this country to the other without talking to ATC... Out here in the Los Angeles basin, the air traffic is so thick, that I wouldn't consider not using Radar Advisory Service on VFR flights. But if I had to pay for it, I might reconsider that decision. Privatized, user fee based, ATC must necessarily negatively impact air safety, because it provides a disincentive (dollar price) against the use of aviation services meant to enhance safety. If, with a simple box upgrade, you could be sure that you knew where all the traffic was, would you still want the radar advisories? think ADS/B Of course, ADS/B will only "see" transponder equipped aircraft, so it is not able to provide positional information on ALL aircraft traffic. Have you any idea of the cost to equip a typical GA aircraft with ADS/B? Do you agree, that the expense may delay such installations infinitely? Doesn't it make more sense to have a few ground-based radar installations for traffic separation rather than the hundreds of thousands of ADS/B installations for it to work? Unless ALL aircraft (including the military) are equipped with ADS/B, there will be potentially conflicting air traffic that will not be flagged, won't there? What is a reasonable period of time to expect ALL aircraft to be ADS/B equipped? What is a reasonable period of time to expect FAA Traffic Information Service–Broadcast (TIS–B) installations to provide coverage of the entire NAS? Is ADS/B infallible; is it able to provide absolute confirmation of the location of conflicting traffic, or does it rely upon the validity of the information provided by all ADS/B equipped flights? In the case of low-level flights in sparsely populated areas (such as military aircraft on MTR routs), how well will ADS/B function for air traffic deconfliction given its line-of-sight communications limitations and the military's workaround approach to ADS/B equipping for military aircraft?* What sort of backup system will be available for deconflicting air traffic in the event of a GPS outage as may occur at the next, and succeeding, periodic eleven-year solar maxima** due to possible CME events? As you can see, I am thinking about, not only ADS/B, but satellite-based NextGen ATC too, and I'm wondering what sort of backup plan the FAA has to separate aircraft when GPS and radio communications become unreliable? * http://www.mitre.org/work/tech_paper...relli_adsb.pdf ** http://en.wikipedia.org/wiki/Solar_maximum Historic maximums The last solar maximum was in 2001, and on March 10, 2006 NASA researchers announced that the next cycle would be the strongest since the historic maximum in 1958 in which northern lights could be seen as far south as Mexico. [1] This projection was based on research done by Mausumi Dikpati of the National Center for Atmospheric Research (NCAR). http://science.nasa.gov/headlines/y2...htm?list862664 Solar Storm Warning 03.10.2006 + Play Audio | + Download Audio | + Historia en Español | + Email to a friend | + Join mailing list March 10, 2006: It's official: Solar minimum has arrived. Sunspots have all but vanished. Solar flares are nonexistent. The sun is utterly quiet. Like the quiet before a storm. This week researchers announced that a storm is coming--the most intense solar maximum in fifty years. The prediction comes from a team led by Mausumi Dikpati of the National Center for Atmospheric Research (NCAR). "The next sunspot cycle will be 30% to 50% stronger than the previous one," she says. If correct, the years ahead could produce a burst of solar activity second only to the historic Solar Max of 1958. That was a solar maximum. The Space Age was just beginning: Sputnik was launched in Oct. 1957 and Explorer 1 (the first US satellite) in Jan. 1958. In 1958 you couldn't tell that a solar storm was underway by looking at the bars on your cell phone; cell phones didn't exist. Even so, people knew something big was happening when Northern Lights were sighted three times in Mexico. A similar maximum now would be noticed by its effect on cell phones, GPS, weather satellites and many other modern technologies. |
On Tue, 21 Aug 2007 11:15:13 +0000, Larry Dighera wrote:
Doesn't it make more sense to have a few ground-based radar installations for traffic separation rather than the hundreds of thousands of ADS/B installations for it to work? How would a few ground-based installations cover the entire nation? Or are you speaking only of the LA area? One advantage of ADS-B is that properly equiped aircraft can "see" each other even outside of RADAR coverage. Being in RADAR coverage provides additional "service" (more information is spread more widely), but the system doesn't *require* that coverage to function. However, outside of RADAR coverage full (and mutually compatible!) ADS-B ubiquity is necessary. And since, at least last time I checked, ADS-B has at least two (three?) mutually incompatible transceivers, even achieving 100% installation wouldn't be enough. My opinion is that this is a good idea but (1) it'll take some time for the full utility to be achieved and (2) it'll be completely screwed if the compatibility issue is left unresolved. As far as the GPS requirement, this is a separate issue. "Modern" navigation devices should exploit a combination of space and ground based systems. Why we have "GPS units" rather than more diverse "Navigation units" is probably just a matter of cost. But, obviously, there's yet to be much in the way of a call for these superior "Navigation units". Perhaps I'm wrong, though. Perhaps it isn't cost, but the expectation that ground based navaids are really going to be shut down. That would be bad. - Andrew |
On Wed, 22 Aug 2007 12:33:04 -0400, Andrew Gideon
wrote in : On Tue, 21 Aug 2007 11:15:13 +0000, Larry Dighera wrote: Doesn't it make more sense to have a few ground-based radar installations for traffic separation rather than the hundreds of thousands of ADS/B installations for it to work? How would a few ground-based installations cover the entire nation? Or are you speaking only of the LA area? I'm speaking of the current system. It pretty much covers the CONUS down to the line-of-sight floor. I doubt there are hundreds of thousands of FAA radar installations. One advantage of ADS-B is that properly equiped aircraft can "see" each other even outside of RADAR coverage. Being in RADAR coverage provides additional "service" (more information is spread more widely), but the system doesn't *require* that coverage to function. That certainly is a significant advantage if it doesn't lull the crew into relying on ADS/B exclusively for separation. How much does it cost to properly equip the GA and military fleets with ADS/B? Incidentally, the military doesn't intend to install ADS/B in their aircraft, so ADS/B equipped GA flights will still not be able to "see" the fast-movers on MTRs, nor any NORDO flights. However, outside of RADAR coverage full (and mutually compatible!) ADS-B ubiquity is necessary. And since, at least last time I checked, ADS-B has at least two (three?) mutually incompatible transceivers, even achieving 100% installation wouldn't be enough. OMG, you've got to be kidding. Three incompatible ADS/B systems? Surely that's destined to change, right? My opinion is that this is a good idea but (1) it'll take some time for the full utility to be achieved Given the fact that the military does not intend to equip its fleet with ADS/B, full utility will *never* be achieved. and (2) it'll be completely screwed if the compatibility issue is left unresolved. Or in the event of GPS unavailability due to jamming, solar activity, or intentional shutdown as may occur in the event of perceived or real threats to the nation. As far as the GPS requirement, this is a separate issue. "Modern" navigation devices should exploit a combination of space and ground based systems. Exactly. Why we have "GPS units" rather than more diverse "Navigation units" is probably just a matter of cost. But, obviously, there's yet to be much in the way of a call for these superior "Navigation units". The issue of price, and the recurring cost of periodic database updates will substantially delay the ubiquity of such systems. Perhaps I'm wrong, though. Perhaps it isn't cost, but the expectation that ground based navaids are really going to be shut down. That would be bad. I agree. Decommissioning the existing navaids would be less than prudent. Of course, we're looking at the issue from a personal-GA point of view not an airline POV. |
OSH H.O.P.S. Party -- 2nd Call! | Jay Honeck | Piloting | 4 | June 28th 07 06:41 AM |
A call on 121.5 | Dylan Smith | Piloting | 10 | April 30th 07 09:52 AM |
Close call? | Alan[_4_] | Piloting | 6 | April 8th 07 11:17 PM |
Just call me Han...... | JIM105 | Rotorcraft | 7 | November 5th 04 12:29 AM |
Who do you call? | Travis Marlatte | Piloting | 4 | August 21st 03 08:16 AM |
