On Tue, 21 Aug 2007 04:44:14 -0700, Jay Honeck
wrote in . com: On Aug 21, 5:33 am, Larry Dighera wrote: Here in the Northeast, the FSDO will not approve an Air Gizmo at all, and the avionics shop I talked to won't install it as a result. Apparently Air Gizmo's products are not intended for installation in certified aircraft: http://www.airgizmos.com/paneldock.asp All products on this site are intended for use on experimental aircraft. Installation in a production aircraft may require an FAA field approval. Copyright © 2005-2007, AirGizmos, LLC. All Rights Reserved. Insurance company boilerplate. Lawyers dictating life, yet again. [...] For the FAA to be doing anything but embracing this innovative device shows precisely how stupid a government agency can be. Perhaps. But how do you know that the Air Gizmo is safe for installation in your aircraft? Have you personally (or anyone else) thoroughly tested it, and can you state with certainly, for example, that it will not emit voluminous poisonous smoke in the event of an electrical fire, or any of many other possible objectionable hazards or deficiencies? That's why the FAA has STCs. http://en.wikipedia.org/wiki/Type_certificate Supplemental Type Certificate A Supplemental Type Certificate (STC) is a document issued by the Federal Aviation Administration approving a product (aircraft, engine, or propeller) modification. The STC defines the product design change, states how the modification affects the existing type design, and lists serial number effectivity. It also identifies the certification basis listing specific regulatory compliance for the design change. Information contained in the certification basis is helpful for those applicants proposing subsequent product modifications and evaluating certification basis compatibility with other STC modifications. Would you be comfortable knowing, that the interior materials used in your aircraft will emit cyanide gas in the event of a fire? Or would you naively rely on ALL upholstery manufacturers to use safe materials that don't do that without submitting them to FAA for certification? Perhaps the government isn't as stupid as you think. Perhaps there have been issues in the past that warranted the implementation of STC policy? Given the manufacturer's admonition: http://www.airgizmos.com/faq.asp Q: Can the Panel Dock be installed in a certified aircraft? A: The Panel Dock can be installed in a certified aircraft, but you will need an FAA field approval. It would seem that FAA field approval* is required. I'm not an A&P, nor FAA inspector, so I'm not qualified to provide a definitive answer to this issue, so I'll defer to the professionals. (But I can see where those manufacturers who do go through the expense of STC approval might feel that they are being discriminated against if the FAA were to permit unapproved parts to be manufactured for installation in certified aircraft.) * https://www.faa.gov/aircraft/air_cer...d_approv_proc/ Field Approval Process The field approval process is used for one serial numbered aircraft in accordance with FAA Order 8300.10, Vol. 2, Chapter 1. Steps of the field approval process a The applicant proposes to repair or alter one serial numbered aircraft. The applicant must determine that the change is a major alteration or repair per 14 CFR 1.1** and 14 CFR part 43, Appendix A; The change is annotated on a FAA Form 337, Major Repair and Alteration; The applicant submits FAA Form 337 annotating the change with the data package to the Flight Standards District Office; The Flight Standards District Office may meet to assess the scope, complexity of change in light of 14 CFR 1.1 definitions and 14 CFR part 43, Appendix A. The Flight Standards District Office determines that either: The data is adequate and no field approval is required. The Aviation Safety Inspector can sign Block 3 of FAA Form 337 to approve the repair or alteration, or Additional data from the applicant is needed if the original data package is found to be inadequate, or The data needs Aircraft Certification Office review in light of its complexity or adequacy, or The alteration is of a type listed in FAA Orders 8300.10 which exceed the basic scope of a Field Approval and must be processed as an STC. If the Aircraft Certification Office reviews the data, they may: Determine that the data package is acceptable as is and can be approved as a Field Approval; Support the field approval with engineering review, advocate additional data or testing, assist with the flight test and Airplane Flight Manual supplements; Recommend that the project should be an Aircraft Certification Office managed Supplemental Type Certification project, and should proceed with the Supplemental Type Certification process. The Inspector approves the repair or alteration by signing block 3 of Form 337. Owners, operators, and persons who repair or alter aircraft, FAA Flight Standards Inspectors, FAA Aircraft Certification Office Engineers, and DERs need to know when a field approval is made. ** http://www.access.gpo.gov/nara/cfr/w...14cfr1_06.html Major alteration means an alteration not listed in the aircraft, aircraft engine, or propeller specifications-- (1) That might appreciably affect weight, balance, structural strength, performance, powerplant operation, flight characteristics, or other qualities affecting airworthiness; or (2) That is not done according to accepted practices or cannot be done by elementary operations. Major repair means a repair: (1) That, if improperly done, might appreciably affect weight, balance, structural strength, performance, powerplant operation, flight characteristics, or other qualities affecting airworthiness; or (2) That is not done according to accepted practices or cannot be done by elementary operations. But that's no surprise. Neither is your shortsighted cynicism. :-) Ray, c'mon back to the Midwest, where common sense prevails. "where the men are all good looking, the women are all strong, and the children are above average." Any of a dozen shops will install it for ya, properly, with an A&P sign-off and logbook entry. And your insurance company will have an opportunity to deny your claim, and you can be assured of an FAA investigation at your next ramp check, not to mention your opportunity to stay in an aviation-themed motel. :-) |
Ray Andraka wrote:
OK, I have a 496, and an air gizmo mount, which I'd like to put on my panel. I'm curious to the signoffs needed: The Air gizmo I think should be allowed to be installed by the owner/pilot as an interior decoration as long as it doesn't involve drilling or cutting the panel. Correct? If I have to cut the panel or drill holes, do I need an A&P signature? The W&B change is negligible I believe. In order to wire the power into the aircraft power (not through a cigar lighter plug), I think I need an A&P signature, and all work has to conform to 43.13, nothing more correct? How about running extension wires for the XM USB and remote antenna to the top of the glareshield with the wires behind the panel? I imagine that needs an A&P sign-off if the wires are tie-wrapped into place? OK, and the final question: It looks like in order to fit it in, I'll need to pull the ancient Foster Loran and it's tray out. That's surely going to need somebody's sign-off. Does that have to be pulled by an avionics shop (it does have a connection to the autopilot switch), or can that be done under an A&P's supervision and signature as well? I figure I'll replace the Loran antenna with a comm antenna and leave the end available on the panel for my handheld. There was some FAA decisions a while back concerning the Air Gizmos in certified aircraft. I did a quick Google search and couldn't find it but I'm sure someone here will remember the details. Here's what Air Gizmo's FAQ has to say about it. Q: Can the Panel Dock be installed in a certified aircraft? A: The Panel Dock can be installed in a certified aircraft, but you will need an FAA field approval. |
![]() Gig 601XL Builder wrote: Here's what Air Gizmo's FAQ has to say about it. Q: Can the Panel Dock be installed in a certified aircraft? A: The Panel Dock can be installed in a certified aircraft, but you will need an FAA field approval. It is irrelevant what Air Gizmo has to say about it. If they don't provide the STC then what they say about installation could not possibly matter less. |
Newps wrote:
Gig 601XL Builder wrote: Here's what Air Gizmo's FAQ has to say about it. Q: Can the Panel Dock be installed in a certified aircraft? A: The Panel Dock can be installed in a certified aircraft, but you will need an FAA field approval. It is irrelevant what Air Gizmo has to say about it. If they don't provide the STC then what they say about installation could not possibly matter less. I'd hardly say that it is irrelevant. They might just received some feedback from what is happening in the real world. |
![]() Ray Andraka wrote: OK, I have a 496, and an air gizmo mount, which I'd like to put on my panel. I'm curious to the signoffs needed: The Air gizmo I think should be allowed to be installed by the owner/pilot as an interior decoration as long as it doesn't involve drilling or cutting the panel. Correct? If I have to cut the panel or drill holes, do I need an A&P signature? The W&B change is negligible I believe. It is a minor alteration and needs to be signed off by an A&P as such. An owner cannot do that. Drilling or cutting does not affect that. In order to wire the power into the aircraft power (not through a cigar lighter plug), I think I need an A&P signature, and all work has to conform to 43.13, nothing more correct? Yes. One other way to go is to have the A&P wire up a cig lighter plug under the panel where you can't see it. That way when the next latest/greatest comes out you're ready to go. I have two extra cig lighters under the panel. I have one wired directly to the battery so it is always hot, that way I can recharge a cell phone or whatever. The other is wired to come on with the master, that way the GPS fires up automatically. How about running extension wires for the XM USB and remote antenna to the top of the glareshield with the wires behind the panel? I imagine that needs an A&P sign-off if the wires are tie-wrapped into place? No, it wouldn't. OK, and the final question: It looks like in order to fit it in, I'll need to pull the ancient Foster Loran and it's tray out. That's surely going to need somebody's sign-off. Does that have to be pulled by an avionics shop (it does have a connection to the autopilot switch), or can that be done under an A&P's supervision and signature as well? I figure I'll replace the Loran antenna with a comm antenna and leave the end available on the panel for my handheld. An A&P can do that. You can do all the work, just have him look it over and sign it off. He'll have to change the placard on the autopilot switch to reflect that the loran was removed. |
Newps, Thanks.
Newps wrote: Ray Andraka wrote: OK, I have a 496, and an air gizmo mount, which I'd like to put on my panel. I'm curious to the signoffs needed: The Air gizmo I think should be allowed to be installed by the owner/pilot as an interior decoration as long as it doesn't involve drilling or cutting the panel. Correct? If I have to cut the panel or drill holes, do I need an A&P signature? The W&B change is negligible I believe. It is a minor alteration and needs to be signed off by an A&P as such. An owner cannot do that. Drilling or cutting does not affect that. In order to wire the power into the aircraft power (not through a cigar lighter plug), I think I need an A&P signature, and all work has to conform to 43.13, nothing more correct? Yes. One other way to go is to have the A&P wire up a cig lighter plug under the panel where you can't see it. That way when the next latest/greatest comes out you're ready to go. I have two extra cig lighters under the panel. I have one wired directly to the battery so it is always hot, that way I can recharge a cell phone or whatever. The other is wired to come on with the master, that way the GPS fires up automatically. How about running extension wires for the XM USB and remote antenna to the top of the glareshield with the wires behind the panel? I imagine that needs an A&P sign-off if the wires are tie-wrapped into place? No, it wouldn't. OK, and the final question: It looks like in order to fit it in, I'll need to pull the ancient Foster Loran and it's tray out. That's surely going to need somebody's sign-off. Does that have to be pulled by an avionics shop (it does have a connection to the autopilot switch), or can that be done under an A&P's supervision and signature as well? I figure I'll replace the Loran antenna with a comm antenna and leave the end available on the panel for my handheld. An A&P can do that. You can do all the work, just have him look it over and sign it off. He'll have to change the placard on the autopilot switch to reflect that the loran was removed. |
![]() Is your aircraft certified or experimental? Here's an article from AOPA on the subject: http://www.aopa.org/whatsnew/newsite...0201parts.html Don't take panel-mount option out of portable GPS, AOPA tells FAA Think your portable GPS would work great mounted to your old Cessna 172's instrument panel? If the FAA has its way, you won't be able to mount it. The parts — panel dock and connective wiring — needed to mount your portable GPS would either no longer be available or be too expense to buy. The FAA's proposal would make it illegal for manufacturers to produce a replacement or modification part if they know (or should know) the part would end up installed in a certified aircraft — that is unless they obtain production approval from the agency. But that costs tens of thousands of dollars, something many companies can't afford. While AOPA agrees production approval is necessary for critical parts like connecting rods and cylinders, it isn't needed for non-critical parts like a portable GPS panel dock or traffic detector that enhance pilot safety. "This [rule] would basically require any person who manufactures a part, like a light bulb, smoke detector, entertainment system, or other non-critical part that has not been identified as a 'standard or commercial part' to obtain a production approval from the FAA if the part is to be installed in a type-certificated product," Gutierrez said in formal comments opposing the proposed rule. Also under the rule, parts listed on the design approval for one aircraft couldn't be used as a replacement in another aircraft. For example, let's say Cessna installs GE light bulbs in the aircraft's instrument panel and lists the bulb in its design approval. Well, you wouldn't be able to use that same type of light bulb to replace the burned out one in your old Bonanza. These proposals "would substantially increase the cost of general aviation parts and unnecessarily stifle the development and availability of safety and operational enhancement modifications," Gutierrez told the FAA. "AOPA requests that the FAA revise this proposal to ensure that replacement and modification parts remain affordable and available to GA aircraft owners." February 1, 2007 --------------------------------- AOPA's response to FAA NPRM: Docket No. FAA-2006-25877; Notice of Proposed Ruelmaking; Production and Airworthiness Approvals, Part Marking, and Miscellaneous Proposals: http://www.aopa.org/whatsnew/newsite...rts-letter.pdf -------------------------------- Enter docket number 25877 he http://dms.dot.gov/search/searchFormSimple.cfm And you can read the NPRM and comments. -------------------------------- http://www.faa.gov/about/office_org/...M_Briefing.ppt http://search.google.dot.gov/FAA/FAA...ntend&oe=UTF-8 Summary of Proposals 14 CFR Part 45 Continued New Part Marking Requirements Manufacturer & Part Number Req?d Delete ?FAA-PMA? Markings Delete ?installation eligibility? ? PMA Project Status Currently On Track ? NPRM and Implementation Advisory Circulars Available for Comment at http://dms.dot.gov, docket numbers 25877 and 25882 Final Rule to be published by April, 2008 Effective Date of Final Rule is set for October, 2009 --------------------------------- |
Mounting 396 | Paul kgyy | Piloting | 40 | August 24th 07 08:47 AM |
Mounting Cambridge 10 in ASW-19 | jcarlyle | Soaring | 0 | February 27th 06 01:48 PM |
ELT Mounting for an ASW20-C | Papa3 | Soaring | 11 | January 26th 06 06:37 AM |
Mounting my GPS | Charles Talleyrand | Owning | 8 | November 19th 03 11:51 AM |
Mounting my GPS | Charles Talleyrand | Piloting | 8 | November 19th 03 11:51 AM |
