![]() "Fred the Red Shirt" wrote in message oups.com... http://www.youtube.com/watch?v=GkrUMT1d3C4 Wow. I especially like the part where "about fifty men" install the wing. Looks like they used the mixture as an anti-seize compound... If white lead will harden castor oil then I would suppose the opposite--that it was used as a thread-locking compound. But if it does not harden, then I agree, anti-seize. -- FF Looked like there was a separate locking gizmo to ensure the prop stayed put... Only ten men to put the prop on ;-) |
On Aug 21, 12:01 am, "Blueskies"
wrote: "Fred the Red Shirt" wrote in ooglegroups.com... http://www.youtube.com/watch?v=GkrUMT1d3C4 Wow. I especially like the part where "about fifty men" install the wing. Looks like they used the mixture as an anti-seize compound... If white lead will harden castor oil then I would suppose the opposite--that it was used as a thread-locking compound. But if it does not harden, then I agree, anti-seize. .... Looked like there was a separate locking gizmo to ensure the prop stayed put... Now that you mention it, I recall that too. Besides, one of the old farts here confirmed that white lead was a traditional anti-seize compound. I guess that it must not castor oil the way ti does linseed oil. 'Boiled' linseed oil is linseed oil that has hardening agents (driers) added to it. When white lead was used, it was heated after mixing, hence the term 'boiled'. Only ten men to put the prop on ;-) Were it a Corsair, they would have needed a boy too! -- FF |
Fred the Red Shirt wrote:
On Aug 21, 12:01 am, "Blueskies" wrote: "Fred the Red Shirt" wrote in ooglegroups.com... http://www.youtube.com/watch?v=GkrUMT1d3C4 Wow. I especially like the part where "about fifty men" install the wing. Looks like they used the mixture as an anti-seize compound... If white lead will harden castor oil then I would suppose the opposite--that it was used as a thread-locking compound. But if it does not harden, then I agree, anti-seize. ... Looked like there was a separate locking gizmo to ensure the prop stayed put... Now that you mention it, I recall that too. Besides, one of the old farts here confirmed that white lead was a traditional anti-seize compound. I guess that it must not castor oil the way ti does linseed oil. 'Boiled' linseed oil is linseed oil that has hardening agents (driers) added to it. When white lead was used, it was heated after mixing, hence the term 'boiled'. Only ten men to put the prop on ;-) Were it a Corsair, they would have needed a boy too! -- FF Sorry to disagree, but When linseed oil was first used in paints,(as was white lead) the drying--(actually oxidation-not solvent evaporation) was accelerated if the oil was first "cooked,or boiled"--Later chemists added Catalytic-type compounds which did the job much more effectively.. You had to caution the livestock trade to use only Raw Linseed(as a laxative) and not the boiled or it'd kill the animals. Jerry |
On Aug 21, 6:48 pm, Jerry Wass wrote:
Fred the Red Shirt wrote: On Aug 21, 12:01 am, "Blueskies" wrote: "Fred the Red Shirt" wrote in ooglegroups.com... http://www.youtube.com/watch?v=GkrUMT1d3C4 Wow. I especially like the part where "about fifty men" install the wing. Looks like they used the mixture as an anti-seize compound... If white lead will harden castor oil then I would suppose the opposite--that it was used as a thread-locking compound. But if it does not harden, then I agree, anti-seize. ... Looked like there was a separate locking gizmo to ensure the prop stayed put... Now that you mention it, I recall that too. Besides, one of the old farts here confirmed that white lead was a traditional anti-seize compound. I guess that it must not castor oil the way ti does linseed oil. 'Boiled' linseed oil is linseed oil that has hardening agents (driers) added to it. When white lead was used, it was heated after mixing, hence the term 'boiled'. Only ten men to put the prop on ;-) Were it a Corsair, they would have needed a boy too! -- FF Sorry to disagree, I think if you re-read, you'll find you are not disagreeing. but When linseed oil was first used in paints,(as was white lead) the drying--(actually oxidation-not solvent evaporation) was accelerated if the oil was first "cooked,or boiled"--Later chemists added Catalytic-type compounds which did the job much more effectively.. BTW, it is still called boiled, even if it wasn't heated. You had to caution the livestock trade to use only Raw Linseed(as a laxative) and not the boiled or it'd kill the animals. ... -- FF |
Right prop, wrong prop? Wood prop, metal prop? | Gus Rasch | Aerobatics | 1 | February 14th 08 10:18 PM |
Increase efficiency of rotating shaft. | jigar | Home Built | 8 | October 6th 06 05:29 AM |
Subaru flywheel pto shaft | [email protected] | Home Built | 5 | November 28th 05 12:05 AM |
Thrust vs Shaft Horse Power? | Evan Williams | Military Aviation | 9 | July 22nd 04 02:45 AM |
Lubricating the primer shaft | Michael Horowitz | Home Built | 9 | November 20th 03 12:26 AM |
