De-registration
Old August 22nd 07, 08:52 AM posted to rec.aviation.soaring
Bert Willing[_2_]
Default De-registration
If the glider is type certified in Germany (which it is most probably
because otherwise it wouldn't be allowed to fly in the US), the former owner
has to apply for de-registration in Germany (sending in the form, the
original certificate of airworthiness and the original certificate of
immatriculation), and the LBA then issues a certificate of de-registration
to the former owner. That takes 3-4 weeks, plus the snail mail from the US
to D and back.
There is no LBA webseite listing immatriculations vs owners.
Bert
I am buying a used glider and it's in the US. Is
there a German website that would show aircraft registry with names
next to registration numbers like we have here in the US?
Old August 23rd 07, 01:07 AM posted to rec.aviation.soaring
On Aug 22, 12:52 am, "Bert Willing" bw_no_spam_ple...@tango-
to D and back.
next to registration numbers like we have here in the US?- Hide quoted text -
- Show quoted text -
Thanks for the response.
Chris Aniol
Old August 23rd 07, 02:00 AM posted to rec.aviation.soaring
CindyB
Chris:
The group needed a little more info to answer your question
most correctly. But I think you got the answer you needed,
circuitously.
I would guess from your original post that you are a US citizen,
trying to buy a German registered airframe that happens to be
on a flying holiday in the US.
An airframe registered in a particular country, flown by a pilot of
that same
citizenship, may fly in most ICAO countries without (much)
interference
for recreational uses. But to change the ownership and hence
registration
of ownership to a new nationality requires a de-registration from the
current
country. (One airframe doesn't get to wear an "N" number and a "D"
number
at the same time.)
Bert is likely pretty correct on the LBA's procedures, and others are
helpful in telling you that most of Europe goes to the beach (or
somewhere)
on vacation for all of August. So, hopefully, LBA will spit out
documents
for you in a few more weeks.
But the one wrinkle that was wrong..... a glider doesn't have to be
LBA
type certified to leave Germany and fly in the US. It could be
factory
built or not, leave it's home country, and be licensed for
Airworthiness in the US
under Experimental Airworthiness - Air Racing. Many lovely gliders,
mostly
single-place, fly here in that manner.
Cindy B
SSA Governmental Liaison Committee
www.caracolesoaring.com
Old August 23rd 07, 09:17 AM posted to rec.aviation.soaring
Bert Willing[_2_]
Cindy,
a glider certainly doesn't have to be type certificated by the LBA to fly in
the US ;-) It's the US who decides which aircrafts it wants to see above its
territory.
But if it does have written a D-... on it, the LBA has either issued an
immatriculation based on a type certificate, or based on a preliminary
certificate. In the second case, the certificate is limited in time and in
the mode of operation. Operation abroad, or over populated areas is usually
ruled out by a preliminary type certificate. "Experimental" doesn't exist
for gliders in Germany.
Ciao
Bert
"CindyB" wrote in message
LBA
factory
mostly
Cindy B
Old August 24th 07, 06:09 AM posted to rec.aviation.soaring
On Aug 23, 1:17 am, "Bert Willing" bw_no_spam_ple...@tango-
whisky.com wrote:
Cindy,
territory.
Ciao
Bert
LBA
factory
mostly
Cindy B
Thank you for all the help. Finally I was able to contact the German
LBA and got all the information that I needed. They want the original
airworthiness certificate and registration as well as proof of
purchase/bill of sale. After that they will send the deregistration
certificate.
OLC Registration [email protected] Soaring 7 April 17th 07 04:10 PM
Registration question Michael Horowitz Owning 7 January 25th 06 03:50 PM
Aircraft Registration jcarlyle Soaring 11 January 21st 06 05:16 PM
Canadian registration to US? CFLav8r Owning 7 March 15th 04 03:35 AM
2004 Registration PaulaJay1 Owning 30 January 2nd 04 04:50 PM
