![]() Judah wrote: [...] What some here may not realize is how fragile the radar antenna can be. [...] I would not risk plain old packing peanuts or bubble wrap, if the box being held sideways or upside down causes a load upon these parts. What happens in turbulence? Clearly, it can handle that, but then it has only a few ounces/decagrams of mass (the fragile mast in the middle) to move along. If one tries to push the ten-pound magnetron/etc. disc through the mast, a hundred times as much force would pass through the part. - FChE |
![]() "Frank Ch. Eigler" wrote in message ... Judah wrote: [...] What some here may not realize is how fragile the radar antenna can be. [...] I would not risk plain old packing peanuts or bubble wrap, if the box being held sideways or upside down causes a load upon these parts. What happens in turbulence? Clearly, it can handle that, but then it has only a few ounces/decagrams of mass (the fragile mast in the middle) to move along. If one tries to push the ten-pound magnetron/etc. disc through the mast, a hundred times as much force would pass through the part. So it sounds like mounting the radar to a piece of plywood, or something, (like it is mounted on an airplane) and fastening that in a box, then surrounding it with peanuts would be the right thing to do, no? -- Jim in NC |
Actually (a) the OP said he wanted to ship the RT unit and the display;
never said a frikkin' word about the antenna and (b) I'm not sure where Eigler gets his information that the antenna is delicate. Having worked directly with civilian aircraft weather radar for a long time, I have absolutely no idea where Eigler is coming from and (c) nobody ever said a word about packing a maggie directly on top of a delicate part. Separate boxes come to mind unless you want argument for argument's sake. Jim -- "If you think you can, or think you can't, you're right." --Henry Ford "Morgans" wrote in message ... "Frank Ch. Eigler" wrote in message ... Judah wrote: [...] What some here may not realize is how fragile the radar antenna can be. [...] I would not risk plain old packing peanuts or bubble wrap, if the box being held sideways or upside down causes a load upon these parts. What happens in turbulence? Clearly, it can handle that, but then it has only a few ounces/decagrams of mass (the fragile mast in the middle) to move along. If one tries to push the ten-pound magnetron/etc. disc through the mast, a hundred times as much force would pass through the part. So it sounds like mounting the radar to a piece of plywood, or something, (like it is mounted on an airplane) and fastening that in a box, then surrounding it with peanuts would be the right thing to do, no? -- Jim in NC |
![]() "RST Engineering" writes: Actually (a) the OP said he wanted to ship the RT unit and the display; never said a frikkin' word about the antenna It seems your broad experience has excluded radar units like my old RDR-160 where the RT and antenna are actually nailed together into one unit. and (b) I'm not sure where Eigler gets his information that the antenna is delicate. [...] Jim, I spelled out precisely where I got the information. From a manufacturer's warning sticker right on the antenna. - FChE |
![]() "RST Engineering" wrote in message ... Actually (a) the OP said he wanted to ship the RT unit and the display; never said a frikkin' word about the antenna My apologies, Jim, I thought the existance of the antenna was implied. This unit consists of two parts, the display in the aircraft, and the unit under the wing. The base unit that mounts to the pod is fairly rigged, but the slotted dish doesn't look like it would support much weight. I'm concerned about the unit getting tipped over, and landing on the antenna in the box. I'm sure that the base unit can support the antenna, which only weighs grams, like it does in turbulence, but I'm trying to avoid any situation where the antenna has to support the base unit that weighs about 15lbs. I've checked with our King dealer, in Troutdale, and all they will tell me is that they use a box from Honeywell. I've asked for a contact or part number or something, but got no reply. Roseburg isn't a big town, and doesn't have a Kinko's, but I think we have a package express, or something. Al G |
![]() "Al G" writes: Actually (a) the OP said he wanted to ship the RT unit and the display; never said a frikkin' word about the antenna My apologies, Jim, I thought the existance of the antenna was implied. There is no need to apologize. Jim was rude and overconfident of his mistaken information. This unit consists of two parts [...] Indeed, as a few seconds' googling shows, and there are several other "two-piece" radar systems. - FChE |
"Al G" wrote in
: "RST Engineering" wrote in message ... Actually (a) the OP said he wanted to ship the RT unit and the display; never said a frikkin' word about the antenna My apologies, Jim, I thought the existance of the antenna was implied. This unit consists of two parts, the display in the aircraft, and the unit under the wing. The base unit that mounts to the pod is fairly rigged, but the slotted dish doesn't look like it would support much weight. I'm concerned about the unit getting tipped over, and landing on the antenna in the box. I'm sure that the base unit can support the antenna, which only weighs grams, like it does in turbulence, but I'm trying to avoid any situation where the antenna has to support the base unit that weighs about 15lbs. I've checked with our King dealer, in Troutdale, and all they will tell me is that they use a box from Honeywell. I've asked for a contact or part number or something, but got no reply. Roseburg isn't a big town, and doesn't have a Kinko's, but I think we have a package express, or something. Perhaps the PC shipping model is appropriate... Some rigid styrofoam bars (you might even find them at a craft store or the craft section of a walmart) well taped together into a structure surrounding the antenna and then taped to the base. If the unit is flipped over, the structure should serve as a stand to the base so that the antenna is essentially suspended (but supported, ideally)... Generally, a picture is worth 1000 words, but hopefully I have enough words here to draw a bit of a picture... ![]() |
shipping glider to NZ-advice on securing glider in trailer | November Bravo | Soaring | 6 | November 1st 06 02:05 PM |
Europe to NA shipping | ADK | Soaring | 0 | April 29th 06 12:29 AM |
FS: Garmin 196 $550 + Shipping | Daniel L. Lieberman | Products | 0 | April 22nd 05 04:33 PM |
Integrating onboard weather radar data with satellite-fed Doppler radar | [email protected] | General Aviation | 3 | January 9th 05 08:57 PM |
Shipping cost | Gralmk | Restoration | 3 | December 15th 03 04:45 AM |
