Shipping a Radar-Advice?
Old August 27th 07, 05:28 PM posted to rec.aviation.piloting,rec.aviation.homebuilt
Al G[_1_]
Default Shipping a Radar-Advice?
"RST Engineering" wrote in message
Actually (a) the OP said he wanted to ship the RT unit and the display;
never said a frikkin' word about the antenna
My apologies, Jim, I thought the existance of the antenna was implied.
This unit consists of two parts, the display in the aircraft, and the unit
under the wing. The base unit that mounts to the pod is fairly rigged, but
the slotted dish doesn't look like it would support much weight. I'm
concerned about the unit getting tipped over, and landing on the antenna in
the box. I'm sure that the base unit can support the antenna, which only
weighs grams, like it does in turbulence, but I'm trying to avoid any
situation where the antenna has to support the base unit that weighs about
15lbs.
I've checked with our King dealer, in Troutdale, and all they will tell
me is that they use a box from Honeywell. I've asked for a contact or part
number or something, but got no reply.
Roseburg isn't a big town, and doesn't have a Kinko's, but I think we
have a package express, or something.
Al G
Old August 27th 07, 08:01 PM posted to rec.aviation.piloting,rec.aviation.homebuilt
Frank Ch. Eigler
"Al G" writes:
display; never said a frikkin' word about the antenna
There is no need to apologize. Jim was rude and overconfident of his
mistaken information.
This unit consists of two parts [...]
Indeed, as a few seconds' googling shows, and there are several other
"two-piece" radar systems.
- FChE
Old September 2nd 07, 12:00 AM posted to rec.aviation.piloting,rec.aviation.homebuilt
Judah
"Al G" wrote in
implied.
unit under the wing. The base unit that mounts to the pod is fairly
rigged, but the slotted dish doesn't look like it would support much
weight. I'm concerned about the unit getting tipped over, and landing on
the antenna in the box. I'm sure that the base unit can support the
antenna, which only weighs grams, like it does in turbulence, but I'm
trying to avoid any situation where the antenna has to support the base
unit that weighs about 15lbs.
tell
part number or something, but got no reply.
we
Perhaps the PC shipping model is appropriate...
Some rigid styrofoam bars (you might even find them at a craft store or the
craft section of a walmart) well taped together into a structure
surrounding the antenna and then taped to the base. If the unit is flipped
over, the structure should serve as a stand to the base so that the antenna
is essentially suspended (but supported, ideally)...
Generally, a picture is worth 1000 words, but hopefully I have enough words
here to draw a bit of a picture...
shipping glider to NZ-advice on securing glider in trailer November Bravo Soaring 6 November 1st 06 02:05 PM
Europe to NA shipping ADK Soaring 0 April 29th 06 12:29 AM
FS: Garmin 196 $550 + Shipping Daniel L. Lieberman Products 0 April 22nd 05 04:33 PM
Integrating onboard weather radar data with satellite-fed Doppler radar [email protected] General Aviation 3 January 9th 05 08:57 PM
Shipping cost Gralmk Restoration 3 December 15th 03 04:45 AM
