In rec.aviation.piloting, on Mon 27 Aug 2007 02:27:25p, Kelly
wrote: How easy is it to view charts, such as TACs, on the ipaq? Have you used it for approach plates? I've found that my PDA has a more viewable screen during bright sunlight situations, but you just don't have the screen real estate that you do with a laptop. At night, a laptop can actually be too bright though. Garmin has a 5 Hz model receiver (GPS 18) that would be great on a laptop for aviation purposes (most GPS receivers are only 1 Hz). |
![]() "Really-Old-Fart" wrote At night, a laptop can actually be too bright though. Nearly all laptops can be made to adjust the screen brightness, all the way down to so dim it can hardly be seen, no? -- Jim in NC |
In rec.aviation.piloting, on Mon 27 Aug 2007 05:49:59p, "Morgans"
wrote: Nearly all laptops can be made to adjust the screen brightness, all the way down to so dim it can hardly be seen, no? I have not been able to find such an option for my Compaq laptop. It does get a bit dimmer if I run it on the internal battery instead of off of A/C power. |
On Tue, 28 Aug 2007 04:18:04 +0200 (CEST), "Really-Old-Fart"
wrote: In rec.aviation.piloting, on Mon 27 Aug 2007 05:49:59p, "Morgans" wrote: Nearly all laptops can be made to adjust the screen brightness, all the way down to so dim it can hardly be seen, no? I have not been able to find such an option for my Compaq laptop. It does get a bit dimmer if I run it on the internal battery instead of off of A/C power. Unless Compaq has completely omitted the function, there should be two keys with a sun-looking thing printed on them in (blue?) ink - either the up or down arrows, or somewhere in the function keys. Press the Fn and appropriate key together, it should adjust the brightness. The half-moon looking thing is for contrast. |
Peter Clark wrote:
On Tue, 28 Aug 2007 04:18:04 +0200 (CEST), "Really-Old-Fart" wrote: In rec.aviation.piloting, on Mon 27 Aug 2007 05:49:59p, "Morgans" wrote: Nearly all laptops can be made to adjust the screen brightness, all the way down to so dim it can hardly be seen, no? I have not been able to find such an option for my Compaq laptop. It does get a bit dimmer if I run it on the internal battery instead of off of A/C power. Unless Compaq has completely omitted the function, there should be two keys with a sun-looking thing printed on them in (blue?) ink - either the up or down arrows, or somewhere in the function keys. Press the Fn and appropriate key together, it should adjust the brightness. The half-moon looking thing is for contrast. That is how it is done on my wifes Compaq. |
XM Wx Garmin 430/430W with Garmin GDL-69? | [email protected] | Instrument Flight Rules | 4 | March 5th 07 03:52 AM |
Garmin 195...295...296...396.... | [email protected] | Owning | 51 | June 9th 06 12:39 AM |
Garmin 396 and XM | John Doe | Products | 1 | December 16th 05 02:12 AM |
This is why Garmin 296's street price has been dropping -> Garmin 396 | [email protected] | Instrument Flight Rules | 7 | July 11th 05 06:39 PM |
FA: Garmin 195 | JerryK | Aviation Marketplace | 1 | September 8th 03 09:41 PM |
