Hornet Autogyro
Old July 23rd 07, 05:49 AM posted to rec.aviation.homebuilt
Chief McGee
Default Hornet Autogyro
Anyone have any experience with this gyro? Opinions? Thanks
http://www.gdt-systems.com/body.asp
Old August 26th 07, 12:24 AM posted to rec.aviation.homebuilt
Bret Ludwig
It would appear to be Bell 47 Rule noncompliant.
Old August 27th 07, 03:37 PM posted to rec.aviation.homebuilt
Gig 601XL Builder
Bell 47 rule?
Old August 28th 07, 12:00 AM posted to rec.aviation.homebuilt
Bob Kuykendall
On Aug 27, 7:37 am, "Gig 601XL Builder"
Bell 47 rule?
Paraphrased, there is no cheaper/more economical/more efficient way of
achieving vertical takeoff and landing than with a Bell 47 helicopter.
If a proposed rotorcraft or VTOL aircraft is simpler and/or less
expensive than a Bell 47, either the price is unrealistic or the
aircraft will not fly as promised.
Bob K.
Old August 28th 07, 11:38 AM posted to rec.aviation.homebuilt
CanalBuilder
Bell 47 rule?
Bob K.
But it's an autogyro. It doesn't take off or land vertically.
Old August 28th 07, 02:18 PM posted to rec.aviation.homebuilt
Gig 601XL Builder
Bell 47 rule?
Bob K.
OK, but it is sad that a 60 year old peice of technology should be able to
retain such a status.
Old August 28th 07, 03:40 PM posted to rec.aviation.homebuilt
Stuart & Kathryn Fields
Bob: I fly a Safari helicopter which looks a lot like the Bell 47. I did
my helo dual in a Bell 47 D-1. The Safari is much simpler. Just the rod
end count is much less, there are no hydraulics and the Safari is capable of
higher cruise speeds. The Safari is just one of several two seat
helicopters that can outperform a Bell for both speed and cost of purchase
and operation.
Stuart & Kathryn Fields, Publishers
Experimental Helo magazine
P. O. Box 1585
Inyokern, CA 93527
(760) 377-4478 ph
(760) 408-9747 publication cell
(760) 608-1299 technical cell
www.experimentalhelo.com
www.vkss.com
"Bob Kuykendall" wrote in message
Bell 47 rule?
Bob K.
Old August 28th 07, 04:12 PM posted to rec.aviation.homebuilt
Bob Kuykendall
On Aug 28, 7:40 am, "Stuart & Kathryn Fields" wrote:
Bob: I fly a Safari helicopter which looks a lot like the Bell 47...
I'm not saying the rule is valid. I'm just saying what it is said to
be.
Bob K.
Old August 28th 07, 07:09 PM posted to rec.aviation.homebuilt
Montblack
("Stuart & Kathryn Fields" wrote)
of higher cruise speeds. The Safari is just one of several two seat
and operation.
Link(s)...? Link(s)...? Link(s)...?
Paul-Mont
Old August 28th 07, 10:23 PM posted to rec.aviation.homebuilt
Senor Montblack( and I use the commonly used address that is nearing
mandatory requirement in California), If I read your "Link(s)? correctly,
there are a few: www.acehelicopter.com, www.experimentalhelo.com,
www.rotorway.com, www.verticalaviation.com that come to mind. There are
others coming from Europe and possibly from the Orient. These non-certified
ships allow for actual ownership as opposed to the certified birds that
have both FAA and the Mfr. dictating replacement times and modification
limits; not to mention the cost of replacement parts eg. $65,000 for a pair
of Bell 47 blades. The recent R-22 blade AD, the Bell 47 grip AD are strong
examples of the lack of true ownership being available to owners of both
these birds. Amen
(end of sermon)
P. O. Box 1585
Inyokern, CA 93527
(760) 377-4478 ph
www.vkss.com
"Montblack" wrote in message
did my helo dual in a Bell 47 D-1. The Safari is much simpler. Just the
rod end count is much less, there are no hydraulics and the Safari is
capable of higher cruise speeds. The Safari is just one of several two
seat helicopters that can outperform a Bell for both speed and cost of
purchase and operation.
Paul-Mont
Hornet Autogyro Chief McGee Rotorcraft 0 July 14th 07 02:28 AM
Which is/are the best AutoGyro(s)? [email protected] Rotorcraft 4 July 16th 05 07:25 AM
ID question: hornet or super-hornet? Jim Battista Military Aviation 12 April 20th 04 10:33 PM
GYRORAPTOR model autogyro [email protected] Rotorcraft 0 March 20th 04 09:45 PM
Autogyro Crash - UK Phil Miller Military Aviation 0 June 30th 03 11:55 PM
