Bonanza crash caught on video
Old September 1st 07, 05:35 PM posted to rec.aviation.piloting
RST Engineering
Default Bonanza crash caught on video
Probably a bit cooler because we get the winds through the hills that
cool things down.
We do too; it was well above 100 dF down in Sacramento that day and we maxed
out at 94. That's why my best guess. What is your best guess or is there
hard data? And you say "we". Are you based out of Cameron?
Cameron Park is a bitchkitty coming in or departing on either end.
Never noticed that and I've been flying in and out of there for 7
years. What part about it is a "bitchkitty"???
The airport was commissioned in late 1967 and we didn't move up to Grass
Valley until ten years later. I vaguely remember going in and out a couple
of times in the '70s, but when nobody would carry autofuel when the STCs
became available, I was in and out of there on a monthly if not weekly basis
because they had an autogas pump. When Auburn shut off the 80 pumps in the
late '80s it was a regular fuel stop both going south to San Diego and again
coming back home. At that time you could take on a full load of 80 at
Gillespie field and still have plenty of reserve when you got to Cameron.
Then another fifteen minutes and I was home.
Bitchkitty? The geese coming off of the lake about a hundred yards off the
runway come to mind, as do the terrain and flora on either end. It's just
like home; flat as a pancake with trees and hills all around. Once you get
used to it, no problem. Take a 40 hour student in there some time if you
want to see pucker factor. And those hills on either end juice up some
pretty fair thermals on a hot summer afternoon. I dunno if that guy was
wobbling from stall burble or thermals, but I'll bet the NTSB will find out.
The thing Cameron does NOT have that we do are those goddamned 80' steel
pigstickers with obstruction lights on them all across the north side of the
runway. The story is that someone in the heirarchy of the County told the
FAA to go stuff it and somehow the airport was going to be shut down for
obstruction clearance unless we put those damned steel sticks up. One of
these days I'm gonna take my portable cutting torch ...
Old September 1st 07, 05:48 PM posted to rec.aviation.piloting
Robert M. Gary
cool things down.
I am based out of Cameron Park. Its a great drive up there because its
usually 5 degrees cooler than it is in Folsom.
No geese today. Probably run off by the development.
Yea, but the termals usually get you on downwind.
It will be interesting to find out. Its just impossible to tell at
this point. A friend of mine had a very similar accident. The NTSB
found the result to be two partially plugged injector lines. That's
just an example of how non-expected the results could be.
runway.
Yea, those things always give me the chills. I can't believe that the
FAA (or more likely CalTrans) required your airport to *install*
airplane obsitcles.
-Robert
Old September 1st 07, 06:03 PM posted to rec.aviation.piloting
Dudley Henriques[_2_]
cool things down.
runway.
airplane obsitcles.
-Robert
I Agree. This one just might turn out to be an engine issue suffered
right at or after rotation. No telling without the analysis that will
follow the crash, but it very well might not have been a density
altitude problem or an over gross problem at all.
I agree with you that waiting on the facts is a prudent move with these
things.
Dudley Henriques
Dudley Henriques
Old September 1st 07, 06:37 PM posted to rec.aviation.piloting
Jack Allison
things.
Wait for the facts? Wow...what a novel idea! :-) Just think what that
would do to the noise level on threads like this...
Old September 1st 07, 08:44 PM posted to rec.aviation.piloting
Dale[_3_]
things.
Dudley Henriques
I'm wondering if perhaps this guy did an intersection takeoff.
Old September 1st 07, 10:20 PM posted to rec.aviation.piloting
things.
Dudley Henriques
Making a judgment from a video is difficult without correlated data but
the run looked normal to me right through rotation. The aircraft seemed
to have required acceleration and I couldn't see or hear anything wrong.
Rotation seemed normal without excessive nose attitude or rate.
The slight wobbling and sudden decrease in rate of climb seemed visually
at least what would be expected with a sudden change in engine power.
These of course are nothing but experienced observations based on not
enough data to reach any kind of assumption or conclusion.
It's difficult to determine if the takeoff was initiated from an
intersection but the rate of acceleration and the length of the run
didn't indicate that to me.
The aircraft was absolutely in stall mush when it when in and there was
little change in angle of attack during that period before impact.
I have the feeling that had the sound track been recorded from a closer
vantage point further down the runway closer to the rotation point more
useful data would be available to a knowledgeable eye witness.
Dudley Henriques
Old September 1st 07, 11:20 PM posted to rec.aviation.piloting
Dan Luke[_2_]
Yes. Something happened at about the end of the runway that made the airplane
start to wobble and mush, where a moment before it appeared to be flying ok.
The more I look at it, the more I think the power failed.
Dan
T-182T at BFM
Old September 2nd 07, 03:44 AM posted to rec.aviation.piloting
karl gruber[_1_]
act.
Dudley Henriques
All sorts of things could have affected the TO as well. Parking brake? Were
BOTH mags on? Was the airplane in trim? Did he have the mixture way out for
taxi and forget to push it up some? Etc.
Karl
Old September 1st 07, 06:08 PM posted to rec.aviation.piloting
RST Engineering
It was Caltrans, the *******s. THey issue the airport permit, you know.
"If you think you can, or think you can't, you're right."
--Henry Ford
"Robert M. Gary" wrote in message Yea, those things
airplane obsitcles.
-Robert
Old September 1st 07, 11:18 PM posted to rec.aviation.piloting
Jack Allison
I always wondered about those ugly red/white airplane skewers at KGOO.
The first time I rolled out on final, they were a bit unnerving to see
as it seems the can reach out and grab you.
Oshkosh P-51 crash video Frank from Deeetroit Aviation Photos 0 July 30th 07 06:06 PM
S-3 Crash Video Sanderson Naval Aviation 0 June 13th 05 10:22 PM
Orlando Crash Video Jay Honeck Piloting 35 January 21st 05 03:30 AM
VIDEO: Helicopter crash Micbloo Rotorcraft 0 November 3rd 04 03:28 AM
Video of crash 206 gaylon9 Rotorcraft 9 December 2nd 03 04:53 PM
