On Sep 1, 9:35 am, "RST Engineering" wrote:
Probably a bit cooler because we get the winds through the hills that cool things down. We do too; it was well above 100 dF down in Sacramento that day and we maxed out at 94. That's why my best guess. What is your best guess or is there hard data? And you say "we". Are you based out of Cameron? I am based out of Cameron Park. Its a great drive up there because its usually 5 degrees cooler than it is in Folsom. Bitchkitty? The geese coming off of the lake about a hundred yards off the runway come to mind, as do the terrain and flora on either end. No geese today. Probably run off by the development. And those hills on either end juice up some pretty fair thermals on a hot summer afternoon. Yea, but the termals usually get you on downwind. I dunno if that guy was wobbling from stall burble or thermals, but I'll bet the NTSB will find out. It will be interesting to find out. Its just impossible to tell at this point. A friend of mine had a very similar accident. The NTSB found the result to be two partially plugged injector lines. That's just an example of how non-expected the results could be. The thing Cameron does NOT have that we do are those goddamned 80' steel pigstickers with obstruction lights on them all across the north side of the runway. Yea, those things always give me the chills. I can't believe that the FAA (or more likely CalTrans) required your airport to *install* airplane obsitcles. -Robert |
Robert M. Gary wrote:
On Sep 1, 9:35 am, "RST Engineering" wrote: Probably a bit cooler because we get the winds through the hills that cool things down. We do too; it was well above 100 dF down in Sacramento that day and we maxed out at 94. That's why my best guess. What is your best guess or is there hard data? And you say "we". Are you based out of Cameron? I am based out of Cameron Park. Its a great drive up there because its usually 5 degrees cooler than it is in Folsom. Bitchkitty? The geese coming off of the lake about a hundred yards off the runway come to mind, as do the terrain and flora on either end. No geese today. Probably run off by the development. And those hills on either end juice up some pretty fair thermals on a hot summer afternoon. Yea, but the termals usually get you on downwind. I dunno if that guy was wobbling from stall burble or thermals, but I'll bet the NTSB will find out. It will be interesting to find out. Its just impossible to tell at this point. A friend of mine had a very similar accident. The NTSB found the result to be two partially plugged injector lines. That's just an example of how non-expected the results could be. The thing Cameron does NOT have that we do are those goddamned 80' steel pigstickers with obstruction lights on them all across the north side of the runway. Yea, those things always give me the chills. I can't believe that the FAA (or more likely CalTrans) required your airport to *install* airplane obsitcles. -Robert I Agree. This one just might turn out to be an engine issue suffered right at or after rotation. No telling without the analysis that will follow the crash, but it very well might not have been a density altitude problem or an over gross problem at all. I agree with you that waiting on the facts is a prudent move with these things. Dudley Henriques -- Dudley Henriques |
Dudley Henriques wrote:
I agree with you that waiting on the facts is a prudent move with these things. Wait for the facts? Wow...what a novel idea! :-) Just think what that would do to the noise level on threads like this... |
Dudley Henriques wrote: I Agree. This one just might turn out to be an engine issue suffered right at or after rotation. No telling without the analysis that will follow the crash, but it very well might not have been a density altitude problem or an over gross problem at all. I agree with you that waiting on the facts is a prudent move with these things. Dudley Henriques I'm wondering if perhaps this guy did an intersection takeoff. |
Dale wrote:
In article , Dudley Henriques wrote: I Agree. This one just might turn out to be an engine issue suffered right at or after rotation. No telling without the analysis that will follow the crash, but it very well might not have been a density altitude problem or an over gross problem at all. I agree with you that waiting on the facts is a prudent move with these things. Dudley Henriques I'm wondering if perhaps this guy did an intersection takeoff. Making a judgment from a video is difficult without correlated data but the run looked normal to me right through rotation. The aircraft seemed to have required acceleration and I couldn't see or hear anything wrong. Rotation seemed normal without excessive nose attitude or rate. The slight wobbling and sudden decrease in rate of climb seemed visually at least what would be expected with a sudden change in engine power. These of course are nothing but experienced observations based on not enough data to reach any kind of assumption or conclusion. It's difficult to determine if the takeoff was initiated from an intersection but the rate of acceleration and the length of the run didn't indicate that to me. The aircraft was absolutely in stall mush when it when in and there was little change in angle of attack during that period before impact. I have the feeling that had the sound track been recorded from a closer vantage point further down the runway closer to the rotation point more useful data would be available to a knowledgeable eye witness. -- Dudley Henriques |
![]() "Dudley Henriques" wrote: The aircraft was absolutely in stall mush when it when in and there was little change in angle of attack during that period before impact. I have the feeling that had the sound track been recorded from a closer vantage point further down the runway closer to the rotation point more useful data would be available to a knowledgeable eye witness. Yes. Something happened at about the end of the runway that made the airplane start to wobble and mush, where a moment before it appeared to be flying ok. The more I look at it, the more I think the power failed. -- Dan T-182T at BFM |
![]() act. I have the feeling that had the sound track been recorded from a closer vantage point further down the runway closer to the rotation point more useful data would be available to a knowledgeable eye witness. -- Dudley Henriques All sorts of things could have affected the TO as well. Parking brake? Were BOTH mags on? Was the airplane in trim? Did he have the mixture way out for taxi and forget to push it up some? Etc. Karl |
It was Caltrans, the *******s. THey issue the airport permit, you know.
Jim -- "If you think you can, or think you can't, you're right." --Henry Ford "Robert M. Gary" wrote in message Yea, those things always give me the chills. I can't believe that the FAA (or more likely CalTrans) required your airport to *install* airplane obsitcles. -Robert |
RST Engineering wrote:
It was Caltrans, the *******s. THey issue the airport permit, you know. Jim I always wondered about those ugly red/white airplane skewers at KGOO. The first time I rolled out on final, they were a bit unnerving to see as it seems the can reach out and grab you. |
![]() "Jack Allison" wrote I always wondered about those ugly red/white airplane skewers at KGOO. The first time I rolled out on final, they were a bit unnerving to see as it seems the can reach out and grab you. I've never seen such things. Anyone got some pictures of them? -- Jim in NC |
Oshkosh P-51 crash video | Frank from Deeetroit | Aviation Photos | 0 | July 30th 07 06:06 PM |
S-3 Crash Video | Sanderson | Naval Aviation | 0 | June 13th 05 10:22 PM |
Orlando Crash Video | Jay Honeck | Piloting | 35 | January 21st 05 03:30 AM |
VIDEO: Helicopter crash | Micbloo | Rotorcraft | 0 | November 3rd 04 03:28 AM |
Video of crash 206 | gaylon9 | Rotorcraft | 9 | December 2nd 03 04:53 PM |
