what kind of glider was this on? This would seem very unusual as literally
thousands of these wheels are in use on almost all glider types. it would help to know this tim Please visit the Wings & Wheels website at www.wingsandwheels.com "Jack Glendening" wrote in message ups.com... I am wondering if others have experienced the shearing of a Tost brake bolt resulting in brake failure - I'm speaking about the bolt which extends from the hub and is secured to the aircraft frame (not the bolt which extends for the wire lever attachment). I experienced such a failure on my latest landing with a month-old Tost unit - I was puliing more strongly than usual on the brake but not nearly as hard as I could, and certainly not as hard as I would if it had been an emergency situation. I was amazed that such could produce a bolt shear - I would have thought that some other brake part would fail before such a relatively thick bolt would, but I am no mechanic. It makes me wonder about the quality of the parts Tost is using. Is this a known/common point of failure? Jack Glendening |
Tim Mara wrote:
what kind of glider was this on? This is a also a DG400. (the Tost assembly was purchased from W&W.) Jack |
it would be most unusual that enough force could be supplied to shear the
anchor bolt unless it was not the proper anchor bolt .... please send images of the wheel and bolt to myself and also to TOST tim Please visit the Wings & Wheels website at www.wingsandwheels.com "Jack Glendening" wrote in message ... Tim Mara wrote: what kind of glider was this on? This is a also a DG400. (the Tost assembly was purchased from W&W.) Jack |
![]() Responding to several replies at once, yes this is the "anti-rotation" nut on a mechanical Tost brake. Whether there should be any "wonder" about the bolt failing depends a lot on how hard I was pulling on the brake. While I braked harder than I normally do, it was with a pressure I felt comfortable with and I was surprised that the brake would break under those circumstances. I know I have on occasion pulled harder on the brake in other gliders. And the failure did _not_ occur at the time of maximum pull, so I guess some details of this particular incident are in order. The landing was on a old WW2 base with wide and long runways. I misjudged my approach and landed faster than usual and beyond the runway start markers where I normally touch down. I normally turn off at the first turnoff (760 feet beyond the runway start) but did not know if I could do that this time. So I pulled as hard as I felt comfortable doing to see what would happen, intending that if I could not get stopped by the first taxiway I would go to next one 300 ft further down. But I did get slowed down enough to take the first taxiway. I actually released pressure on the brake as I went into the turn because I wanted to be sure of having enough speed to get to the runway incursion markers on the taxiway (the turn is more than 90 degrees). After the turn was completed I could see I had more than sufficient speed and tried to again pull on the brake but found no response. So I think the bolt sheared during or just after the turn. I found myself looking at the spinning prop of a facing airplane on the same taxiway, just beyond a crossing (runway-paralleling) taxiway, and thought "I'm going to have to do something drastic if this thing does not stop before I get to that crossing taxiway!" Thankfully I had correctly judged the speed needed prior to the turn and with full spoilers I did stop about 20 feet beyond the runway incursion markers, just before reaching the cross taxiway. So possibly the additional side forces during the turn did something. Another possibility is that heating of the brake by the heavy braking prior to that point helped cause the bolt to fail. It has been suggested by a private email that the bolt tempering may have been faulty. FWIW the brake was newly installed by an aircraft mechanic (not me) but one who has limited experience with gliders. I will plan on taking some pictures the next time I visit the plane. All I know at this point is that there is a nut on that bolt at the brake case (as a spacer?) and the shearing occurred just outside that nut. I assume that the missing bolt part was attached to the plate extending from the fuselage for that purpose. I had had about 10 successful landings since brake installation, but all with minimal braking. My reason for bringing this failure to this forum was because I was so surprised by the bolt breakage given the amount of force I applied, a force I did not feel was undue based on my past experience with Tost brakes, so was looking for comments by those who might have knowledge/experience that I do not. I would be more understanding about a bolt breaking if I felt I had pulled extremely hard. I really believe that the force I applied was not unreasonable. I would like to think my braking capability is limited only by pad friction, not by the strength of some bolt or other part of the brake! Certainly for my car that is the case - my car's braking is not limited by part of my brake assembly failing. I certainly hope my ailerons/rudders are that way - I don't want to think that if I yank too hard on the stick my ailerons/rudder might break off ! If there is some amount of pull beyond which a brake part will break, one will never know just where that point is until a pull actually does go beyond that point and the brake then breaks - so one never knows exactly how much stopping power one has until after he's broken the brake once. Jack |
Jack Glendening wrote:
at this point is that there is a nut on that bolt at the brake case (as a spacer?) and the shearing occurred just outside that nut. I don't have a tost wheel in front of me right now, but I'm certain that there is *no* nut on that bolt as a *spacer* (maybe a washer, I can't remember). There is a nut on that bolt outside the "receptical" to secure that bolt. So if your mechanic installed that bolt inside that "receptical" (e.g. as a spacer), it's pretty clear that the bolt would slip out, the plate would rotate and that bolt would eventually be sheared off. Just a guess based on your description, I may have understood you completely wrong. |
John Smith wrote:
Just a guess based on your description, I may have understood you completely wrong. To clarify, immediately next to the shear is a thin bolt (shiny, new looking), then the large drum case - i.e. the bolt is outside the case. I have since learned from Tom Stowers that the nut is standard, so my guess that it might be a spacer was wrong (I was thrown off by my inspection of the _old_ brake parts, given to me after the new installation, which does not have any such nut outside the hub, so I incorrectly guessed that perhaps the bolt threaded into the hub itself - for whatever reason that old nut was not included with the old parts.) Jack |
To clarify, immediately next to the shear is a thin bolt (shiny, new looking), then the large drum case - i.e. the bolt is outside the .... I fear that without a picture I won't understand what you're talking about. |
FS Tost E85 Release | scooter | Soaring | 0 | March 7th 06 02:31 AM |
FS Tost E85 Release | scooter | Soaring | 0 | November 22nd 05 01:11 AM |
TOST E85 RELEASES | [email protected] | Soaring | 2 | March 6th 05 04:21 PM |
Cessna 182 Tost 337? | [email protected] | Soaring | 6 | May 15th 04 03:24 PM |
Tost springs | Lord Struthers | Soaring | 1 | October 10th 03 10:49 PM |
