Fatal accident in Scotland
Old September 5th 07, 10:37 AM posted to rec.aviation.soaring
Tom Gardner
Default Winch launch procedure and accidents
On Sep 5, 8:03 am, Ian wrote:
On 5 Sep, 01:31, Dan G wrote:
You do not attach a cable to the glider until it is ready to fly. All
checks complete, nothing left to do.
Yes, precisely. I don't see any problems with that. I'll go further
and
state that I would need to be convinced that anything else was safer.
Which is fine in an ideal world. But it doesn't always work like that.
Sometimes there are delays, and a safe system will take account of
that possibility.
Er, what's the problem with releasing the cable if there's a delay?
In what way isn't that a "safe system"?
You
have one hand on the stick and the other holds the release. You will
not have time to go feeling for the release if you need it.
That's my opinion, too. As an early solo neophyte who recently
experienced
my first low-level winch failure, heads down while groping for the
cable
release would have been too high a workload. In addition, there is a
significant chance I would have grabbed the airbrake instead of the
release.
It's hard to see how you could screw up if you follow these simple
procedures. I don't give a toss who invented them or why - they're
safe, and that's all that matters to me.
I'm interested in
1) if I follow those standard rules, what are the remaining
potential
problems and avoidance procedures
2) what's the relative probability and severity of problems with/
without
hand on the release
I suspect the (2) is the reason for the BGA selecting the current
rules.
The onus is firmly on anybody challenging the current rules to
convince others that the rules should be changed.
It's when people start thinking that the rules will keep them safe
that accidents happen.
True, but of course that has only tangential relevance to whether
or not the rules are good.
Old September 5th 07, 02:40 PM posted to rec.aviation.soaring
Ian
and
Agreed - as long as the ground crew (signaller, driver, anyone else
involved at the site in question) are also ready to go.
that possibility.
How long a delay? Ten seconds? Twenty? A minute? What if the ground is
muddy and the pilot doesn;t want to make someone grovel in the mud
again to reattach? What if an impatient instructor (I have seen this)
is saying "Don't drop the cable, this won't take long".
Yes, in an ideal world we could hook up and go. I just think the final
word on whether to start the launch should rest with the pilot in
charge ... and in a world where occasional delays between hook-up and
launch are inevitable, that means the pilot should initiate the launch
after the hook-up.
My reasons for liking the "Up slack" and "All out" signals from the
pilot are because too many signallers are rotten at deciding when to
do the transition (although most are fine). I have in the past pulled
off because the signaller was giving "All out" too soon, and I'll do
it again if I have to ...
I don't agree. No rules which are followed mindlessly are good.
Ian
Old September 5th 07, 03:02 PM posted to rec.aviation.soaring
Tom Gardner
and
If anyone isn't ready to go, then the launch doesn't start.
If anyone thinks there's a problem, they can stop the launch.
I don't see any difficulty in that, and I can't conceive of
anything else being appropriate.
that possibility.
Reasonable question. I would have thought that there was
no single correct answer and doesn't need to be;
judgement is required from everybody.
My only rule of thumb is that if people's attention might
wander away from thinking about the launch and/or
"eventualities", then drop the cable. Thus a minute is
probably usually OK, whereas 5 minutes isn't.
Other opinions welcome, of course.
What if the ground is muddy and the pilot doesn't
again to reattach?
The pilot is a twit if they let that sway a safety decision.
It depends on what "this" is, and I'd apply my "attention
test", as above.
charge ...
Nope, it rests with everybody involved in the launch, in that all
must be happy before proceeding. In particular, the pilot can't
adequately see "all clear above and behind", nor the cow that
has just wandered onto the strip, just over that little hump
halfway down the strip
after the hook-up.
See above.
I've never seen that, but if I did then I'd follow your action
(hopefully
without hesitation
The rule can be good even if it is mindlessly followed. Most
of the time I mindlessly follow the rule to drive on the left side
of the road
But both of us think the reason for the rule should be understood
before it is mindlessly followed!
Old September 5th 07, 03:44 PM posted to rec.aviation.soaring
toad
of the road
Hopefully, you convert mindfully when you are driving somewhere that
uses the right hand side of the road :-)
Todd
3S
Old September 5th 07, 04:16 PM posted to rec.aviation.soaring
Tom Gardner
of the road
No problems, except when in carparks, petrol stations, and
when emerging from them onto the road. It also helps if the
steering wheel is on the appropriate side of the car.
OTOH, "right" and "left" have to be replaced by "your way" and
"my way" since there is a demanding feeling that "turn right"
means "turn across oncoming traffic". Surprisingly, I'm not the
only person with those neurons in a twist!
Old September 5th 07, 04:34 PM posted to rec.aviation.soaring
Ian
Indeed. Which gibves the pilot fiddling time ...
Then you and up with a non-launching glider on a cable, the pilot
getting distracted, the signaller seeing an opportunity for a quick
launch and ... bang.
Actually, I agree with you. I just think that the pilot should
retain / have retained control.
again to reattach?
Might it not alter the judgment (see above) about how long to delay
pulling the bung?
charge ...
Lots of people have input - your point about the check behind is very
good - but only one person can ever have a final word about anything.
of the road
Even if you meet approaching walkers ...?
Ian
Old September 6th 07, 12:49 AM posted to rec.aviation.soaring
Tony Verhulst
You
That *used* to be my opinion. What changed it was hitting a severe bump
and watching the end of the rope continue without me. Now, I keep my
left hand *very* close to the release handle. No groping needed at all
should you need to release.
Tony V.
Another fatal accident Mike the Strike Soaring 0 September 20th 06 11:50 PM
Fatal accident in Italy 2cernauta2 Soaring 1 April 4th 06 05:50 PM
Fatal accident near Wenatchee, WA [email protected] Soaring 2 June 27th 05 01:54 AM
Pilot's 2nd Fatal Accident Aardvark Piloting 44 May 21st 04 02:34 PM
Hawaii Fatal Accident Rocky Rotorcraft 0 July 25th 03 03:01 PM
