On Sep 5, 2:40 pm, Ian wrote:
On 5 Sep, 10:37, Tom Gardner wrote: On Sep 5, 8:03 am, Ian wrote: On 5 Sep, 01:31, Dan G wrote: You do not attach a cable to the glider until it is ready to fly. All checks complete, nothing left to do. Yes, precisely. I don't see any problems with that. I'll go further and state that I would need to be convinced that anything else was safer. Agreed - as long as the ground crew (signaller, driver, anyone else involved at the site in question) are also ready to go. If anyone isn't ready to go, then the launch doesn't start. If anyone thinks there's a problem, they can stop the launch. I don't see any difficulty in that, and I can't conceive of anything else being appropriate. Which is fine in an ideal world. But it doesn't always work like that. Sometimes there are delays, and a safe system will take account of that possibility. Er, what's the problem with releasing the cable if there's a delay? In what way isn't that a "safe system"? How long a delay? Ten seconds? Twenty? A minute? Reasonable question. I would have thought that there was no single correct answer and doesn't need to be; judgement is required from everybody. My only rule of thumb is that if people's attention might wander away from thinking about the launch and/or "eventualities", then drop the cable. Thus a minute is probably usually OK, whereas 5 minutes isn't. Other opinions welcome, of course. What if the ground is muddy and the pilot doesn't want to make someone grovel in the mud again to reattach? The pilot is a twit if they let that sway a safety decision. What if an impatient instructor (I have seen this) is saying "Don't drop the cable, this won't take long". It depends on what "this" is, and I'd apply my "attention test", as above. Yes, in an ideal world we could hook up and go. I just think the final word on whether to start the launch should rest with the pilot in charge ... Nope, it rests with everybody involved in the launch, in that all must be happy before proceeding. In particular, the pilot can't adequately see "all clear above and behind", nor the cow that has just wandered onto the strip, just over that little hump halfway down the strip ![]() and in a world where occasional delays between hook-up and launch are inevitable, that means the pilot should initiate the launch after the hook-up. See above. My reasons for liking the "Up slack" and "All out" signals from the pilot are because too many signallers are rotten at deciding when to do the transition (although most are fine). I have in the past pulled off because the signaller was giving "All out" too soon, and I'll do it again if I have to ... I've never seen that, but if I did then I'd follow your action (hopefully without hesitation ![]() It's when people start thinking that the rules will keep them safe that accidents happen. True, but of course that has only tangential relevance to whether or not the rules are good. I don't agree. No rules which are followed mindlessly are good. The rule can be good even if it is mindlessly followed. Most of the time I mindlessly follow the rule to drive on the left side of the road ![]() But both of us think the reason for the rule should be understood before it is mindlessly followed! |
On Sep 5, 10:02 am, Tom Gardner wrote:
.... The rule can be good even if it is mindlessly followed. Most of the time I mindlessly follow the rule to drive on the left side of the road ![]() Hopefully, you convert mindfully when you are driving somewhere that uses the right hand side of the road :-) Todd 3S |
On Sep 5, 3:44 pm, toad wrote:
On Sep 5, 10:02 am, Tom Gardner wrote: ... The rule can be good even if it is mindlessly followed. Most of the time I mindlessly follow the rule to drive on the left side of the road ![]() Hopefully, you convert mindfully when you are driving somewhere that uses the right hand side of the road :-) No problems, except when in carparks, petrol stations, and when emerging from them onto the road. It also helps if the steering wheel is on the appropriate side of the car. OTOH, "right" and "left" have to be replaced by "your way" and "my way" since there is a demanding feeling that "turn right" means "turn across oncoming traffic". Surprisingly, I'm not the only person with those neurons in a twist! |
On 5 Sep, 15:02, Tom Gardner wrote:
On Sep 5, 2:40 pm, Ian wrote: Agreed - as long as the ground crew (signaller, driver, anyone else involved at the site in question) are also ready to go. If anyone isn't ready to go, then the launch doesn't start. Indeed. Which gibves the pilot fiddling time ... How long a delay? Ten seconds? Twenty? A minute? Reasonable question. I would have thought that there was no single correct answer and doesn't need to be; judgement is required from everybody. Then you and up with a non-launching glider on a cable, the pilot getting distracted, the signaller seeing an opportunity for a quick launch and ... bang. Actually, I agree with you. I just think that the pilot should retain / have retained control. What if the ground is muddy and the pilot doesn't want to make someone grovel in the mud again to reattach? The pilot is a twit if they let that sway a safety decision. Might it not alter the judgment (see above) about how long to delay pulling the bung? Yes, in an ideal world we could hook up and go. I just think the final word on whether to start the launch should rest with the pilot in charge ... Nope, it rests with everybody involved in the launch, in that all must be happy before proceeding. Lots of people have input - your point about the check behind is very good - but only one person can ever have a final word about anything. I don't agree. No rules which are followed mindlessly are good. The rule can be good even if it is mindlessly followed. Most of the time I mindlessly follow the rule to drive on the left side of the road ![]() Even if you meet approaching walkers ...? Ian |
Another fatal accident | Mike the Strike | Soaring | 0 | September 20th 06 11:50 PM |
Fatal accident in Italy | 2cernauta2 | Soaring | 1 | April 4th 06 05:50 PM |
Fatal accident near Wenatchee, WA | [email protected] | Soaring | 2 | June 27th 05 01:54 AM |
Pilot's 2nd Fatal Accident | Aardvark | Piloting | 44 | May 21st 04 02:34 PM |
Hawaii Fatal Accident | Rocky | Rotorcraft | 0 | July 25th 03 03:01 PM |
