Approaching Deep Stall
Old September 6th 07, 03:23 PM posted to rec.aviation.piloting
Roger (K8RI)
Default Approaching Deep Stall
On Thu, 6 Sep 2007 06:18:24 -0500, "Neil Gould"
Recently, Dudley Henriques posted:
DR wrote:
Fred the Red Shirt wrote:
Here deep stall is defined as a condition in which the
main wing is stalled and the stabilizer is enveloped
in the turbulent wake of the stalled wing so that
the pilot has lost pitch control and thus cannot lower
the nose to recover. For certain airframe geometries,
(such as the illustration above) that condition can
occur even if the aircraft is within the proper CG limits.
Err, that's not how I see it,
The aircraft can/will still pitch down after stall for 2 reasons:
First, the center of wing lift moves aft once the wing is stalled
which will drop the nose. Second, the tail is pushing the nose up to
increase angle of attack so that once blanketed the nose drops.
As far as I understand it, all certificated aircraft must be able to
recover from a basic stall.
My 2c
Cheers
Not so for the F16. Deep stall is an issue for the Viper at specific
angles of attack and cg configurations, especially if the airplane is
out of fuel balance. The result of deep stall in the Viper is a flat
extremely fast ROD either with occiliation or without.
The ONLY way to break deep stall in the Viper is to INCREASE the aoa,
then quickly input forward stick to induce a high nose rate down
through the deep stall region into a recovery.
Make no mistake, if the aoa is not increased before this fast nose
down pitch rate, the Viper will stay in deep stall and can be
completely unrecoverable.
There is no "automatic" nose down pitch rate in deep stall in the F16.
Thank you for this explanation! One of my favorite past-times is playing
Falcon 4.0 (F-16 sim), and there have been times when I've gotten into
deep stall and have not found a way to recover. Perhaps the game is not
The explanation as to what is happening and how to recover is in the
Falcon 4 manual.
Roger (K8RI)
sophisticated enough to execute the manouver as you've described, but at
least I understand better what's happening.
More on-topic, my basic training was in a Tomahawk, and can say that the
liklihood of deep stalls in that plane are rather slim unless there is
some significant weight in the baggage area.
Neil
Old September 6th 07, 08:45 PM posted to rec.aviation.piloting
Neil Gould
Recently, Roger (K8RI) posted:
[...] One of my favorite past-times is
playing Falcon 4.0 (F-16 sim), and there have been times when I've
gotten into deep stall and have not found a way to recover. Perhaps
the game is not
Falcon 4 manual.
Roger (K8RI)
Thanks, Roger. After looking it over, I think I was doing everything right
except hitting the MPO switch.
Neil
Car and Deep Cycle Battery FAQ Bill Darden Home Built 0 May 28th 07 11:57 AM
ILS approaching help Syucomm Simulators 8 December 13th 06 09:58 PM
deep hole Randall Robertson Simulators 9 April 22nd 04 07:51 PM
German AUV "Deep C" robert arndt Military Aviation 0 November 25th 03 04:07 PM
Approaching BFM... Craig Prouse Piloting 5 September 26th 03 04:50 AM
