In a previous article, Judah said:
2) As others have pointed out, you certainly had enough of a head start on him that unless you had some sort of engine failure you would be clear of the runway long before he caught up to you. In an interesting coincidence, I was just bringing the plane back from maintenance to deal with a problem where the engine would fail when taxiing off the runway. It had happened twice at the end of a series of touch and goes, never in the air or on a regular point to point flight. They'd replaced the mags, and the problem seems like it might be fixed - at least I did 4 touch and goes back at Genesee County where the work had been done with no evidence of problems. -- Paul Tomblin http://blog.xcski.com/ So logically, if she weighs the same as a duck, she's made of wood, and therefore a witch. |
(Paul Tomblin) wrote in news:fc67l2$b2s$2
@xen1.xcski.com: In a previous article, Judah said: 2) As others have pointed out, you certainly had enough of a head start on him that unless you had some sort of engine failure you would be clear of the runway long before he caught up to you. In an interesting coincidence, I was just bringing the plane back from maintenance to deal with a problem where the engine would fail when taxiing off the runway. It had happened twice at the end of a series of touch and goes, never in the air or on a regular point to point flight. They'd replaced the mags, and the problem seems like it might be fixed - at least I did 4 touch and goes back at Genesee County where the work had been done with no evidence of problems. Interesting. Perhaps because of this you were slightly more anxious than would be otherwise. That being said, I'm pretty sure the MD-80 behind you wouldn't have started barrelling down the runway until he actually saw you at least turn off, even if you didn't cross the hold short line. |
Don't Want to be Screwed | [email protected] | Home Built | 5 | May 22nd 04 06:58 AM |
Screwed by Helicopter Support Inc. | Becky DeWind | Owning | 3 | May 18th 04 01:14 PM |
