CNN article on problems in Air Travel, as seen by FAA
Old September 12th 07, 03:20 PM posted to rec.aviation.piloting,rec.travel.air
John Kulp
Default CNN article on problems in Air Travel, as seen by FAA
On Wed, 12 Sep 2007 07:29:44 +0200, Mxsmanic
http://us.cnn.com/2007/US/09/11/airl...ing/index.html
"He blamed resistance from environmentalists for the government's
failure to move more quickly toward a satellite-based technology
that's been 10 years in the making.
"'Residents that have homes that would be in that flight path are
saying no,' Castelveter said."
I'm not sure how using GPS would change airport flight paths.
They're two different things, both of which can improve delays. The
changed flight paths allow for more efficient TOs and landings, while
GPS allows closer flying.
"She called for airlines and the government to make the transition from
1960s radar-based air traffic control systems to satellite-based
technology, 'a solution that will cut delays by 20 percent and reduces
noise for 600,000 people.'"
I don't see how GPS replaces radar coverage, nor do I see how it would reduce
delays.
That's exactly what it does. GPS is much more precise than radar
allowing closer spacing and straighter flight paths.
I guess those magic satellites are somehow going to make it all better.
From what I understand of the reality, the real bottleneck is the number of
runways and the number of planes that want to use them. The airports are
where all the planes meet, and so that's where the conflicts and delays occur
(or at least that's their ultimate origin).
Part of the problem but certainly not all. And seasonal as well,
being worse in summer and less in the off months.
Airlines also seem to be scheduling too many flights. Everyone is buying 737s
and A320s and running tiny flights every hour instead of 747 flights twice a
day, wasting fuel and polluting the environment and overcrowding the air
traffic system. Not only that, but with so many operators flying similar
routes, there are even more small jets going to and fro, wasting more
resources.
Uuh, it's better service. You can hardly fly large planes to small
regional airports which is what the smaller planes service. What do
you want to do? Restrict the number of operators so the fares will be
less competitive and go up?
I'm surprised that with airlines wailing about how difficult business is they
nevertheless resort to practices that are so manifestly wasteful and
inefficient.
They don't. It's just the opposite and seat loads are at historical
heights.
"The Air Transport Association's Castelveter also focused on corporate
aviation.
"The guys who fly around in private jets" make up about 40 percent of
the air traffic in the Northeast, he said. "One would think it's not just
airlines that would be asked to reduce capacity," he said.
Is this number correct?
Yes, and they don't pay anywhere near their fair share of fees either.
Old September 12th 07, 06:16 PM posted to rec.aviation.piloting,rec.travel.air
Mxsmanic
John Kulp writes:
How does this diminish noise to residents adjacent to airports (the only ones
affected by noise)?
GPS does not track aircraft; radar does.
you want to do?
Fly larger aircraft less often to the major airports, reducing fuel
consumption, pollution, stress on the environment, and noise.
Restrict the number of operators so the fares will be less competitive
and go up?
Regulate the nature and amount of commercial airline traffic, which is almost
the same thing.
heights.
Flying multiple flights with smaller aircraft is much less efficient than
flying once with a larger aircraft.
Old September 12th 07, 07:16 PM posted to rec.aviation.piloting,rec.travel.air
John Kulp
On Wed, 12 Sep 2007 19:16:07 +0200, Mxsmanic
John Kulp writes:
affected by noise)?
By flying different paths than now.
Funny, GPS can place a smart bomb right on a target it tracks, but it
can't track aircraft. I have news for you. I was on an international
flight a while back and was talking to the relief pilot. He said the
US was the only country NOT using GPS and was totally outdated. So
how, then, do the flights get to where they're going?
you want to do?
Ah, so you reduce shedules making them less convenient for the public,
force aircraft to buy and sell aircraft they don't want, etc. etc.
Brilliant.
and go up?
the same thing.
Sure. Regulation does wonder. Deregulation did nothing for the
industry. Brilliant once again.
heights.
You can babble this all you want. It hardly makes it true. And it's
not.
Old September 13th 07, 04:36 AM posted to rec.aviation.piloting,rec.travel.air
mrtravel
GPS was used to guide the bombs to pre-determined fixed locations, which
is a bit different than how it would work with aircraft.
To use GPS for tracking an aircraft, the GPS device would be on the
aircraft being tracked and it would have to broadcast this location
information to the trackers.
Old September 13th 07, 05:14 AM posted to rec.aviation.piloting,rec.travel.air
John Kulp
True, but GPS is GPS. They all use the same satellites.
Old September 13th 07, 06:01 AM posted to rec.aviation.piloting,rec.travel.air
Mxsmanic
John Kulp writes:
Yes, but GPS is useless for tracking, and that is by design.
Old September 13th 07, 03:30 PM posted to rec.aviation.piloting,rec.travel.air
John Kulp
On Thu, 13 Sep 2007 07:01:47 +0200, Mxsmanic
John Kulp writes:
Do you ever have one clue about what you're posting. See below:
A GPS tracking unit is a device that uses the Global Positioning
System to determine the precise location of a vehicle, person, or
other asset to which it is attached and to record the position of the
asset at regular intervals. The recorded location data can be stored
within the tracking unit, or it may be transmitted to a central
location data base, or internet-connected computer, using a cellular
(GPRS), radio, or satellite modem embedded in the unit. This allows
the asset's location to be displayed against a map backdrop either in
real-time or when analysing the track later, using customized
software.
Mxsmanic
John Kulp writes:
Without moving runways, that's going to be difficult.
GPS is a receiver-only system. It provides guidance to the aircraft in which
it is installed. It provides nothing to anyone else, by design.
What your pilot doesn't know is that the FMS in every aircraft (almost) uses
GPS as one of its navigation sources. The FMS uses GPS, VORs, ILS, ADF, and
potentially whatever else is on the aircraft for navigation. So the U.S. is
making heavy use of GPS.
Still, this has nothing to do with _tracking_ aircraft by GPS, which is not
possible.
Brilliant.
As fuel dwindles and CO2 increases, it will certainly seem so, although I
rather consider it self-evident.
Old September 13th 07, 03:37 PM posted to rec.aviation.piloting,rec.travel.air
John Kulp
On Thu, 13 Sep 2007 07:01:16 +0200, Mxsmanic
John Kulp writes:
Completely ridiculous. The problem is the runways are at capacity
GIVEN the ATC system/paths being used. Change the path to shorten the
paths and you increase capacity. Got that yet?
More complete nonsense. Go read the other post which actually tells
you what it does.
Oh, so a long experience pilot with a major carrier who uses these
systems every day doesn't know what he's talking about but you do huh?
Right. It's apparent from virtually all your posts that you have no
clue what you're talking about.
possible.
Completely stupid comment as usual.
Brilliant.
Self-evident to a complete idiot. Fuel isn't dwindling. There is
plenty of it. CO2 footprints of aircraft ARE dwindling with more fuel
efficient engines, wing tips, etc.etc. See 787.
Old September 15th 07, 02:12 AM posted to rec.aviation.piloting,rec.travel.air
Mxsmanic
John Kulp writes:
How do you change arrival and departure paths without moving runways? MLS is
a dead letter now and GPS isn't precise enough to provide ILS-equivalent
landing capability, so you're stuck with straight-in approaches, aligned with
runways.
Possibly. Pilots know how to fly planes, but they don't have to know how
planes work. In the old days, before computers did most of the dirty work,
planes had flight engineers, who _did_ know how the planes worked. Today, a
computer handles most things. In both cases, the pilots didn't have to know,
and it would have been quite an extra burden on them to try to train them,
anyway. You don't have to know how a FMS works in order to use one.
Travel aid [email protected] Soaring 0 February 7th 06 12:25 PM
Travel aid [email protected] Restoration 0 February 7th 06 12:25 PM
Travel aid [email protected] General Aviation 0 February 7th 06 12:25 PM
Travel aid [email protected] Aviation Marketplace 0 February 7th 06 12:25 PM
Travel Supplements Jetnw Aviation Marketplace 0 September 15th 04 07:50 AM
