CNN article on problems in Air Travel, as seen by FAA
Old September 19th 07, 03:01 PM posted to rec.aviation.piloting,rec.travel.air
Andrew Gideon
Default CNN article on problems in Air Travel, as seen by FAA
On Thu, 13 Sep 2007 14:26:38 +0000, John Kulp wrote:
Have heard of them and even use them at times. Unless you are IFR,
they are NOT needed at a vast majority of airports in the United States.
Most airports in the U.S. do not have a control tower, and many of those
who do do not have a 24 hour control tower. No local or ground
controllers. No ground control.
These aren't the airports that have much traffic or are the problem.
Those are major airports, which do have ATC.
That's rather the point. This idea of congestion is an airport issue,
and it is limited to those airports where GA has little-to-no presence.
There are a few possible exceptions to this (ie. TEB), but it's also
worth remembering that TEB exists as a reliever precisely because of the
congestion at EWR etc.
- Andrew
Old September 13th 07, 06:10 PM posted to rec.aviation.piloting,rec.travel.air
Rick Blaine
"Gig 601XL Builder" wrDOTgiaconaATsuddenlink.net wrote:
Apparently, you have never heard of approach control, ground control,
or departure control.
Apparently, you have not heard of uncontrolled.
Exactly.
"Tell me what I should do, Annie."
"Stay. Here. Forever." - Life On Mars
Old September 13th 07, 06:17 PM posted to rec.aviation.piloting,rec.travel.air
me[_2_]
On Sep 13, 9:29 am, "Gig 601XL Builder" wrDOTgiaconaATsuddenlink.net
John Kulp wrote:
On Wed, 12 Sep 2007 15:23:10 -0600, Rick Blaine
[snip]
The vast majority of gen av traffic would operate just fine without
ATC at all. With the exception of a few airports that are commercial
hubs, and a couple like Teterboro that attract a bunch of CEO
flights.
An airport 'round these parts just went controlled because of the
number of GA jets that requested it. It was over the objections of
many of the actual more frequent users (VFR mostly). I suspect
that the portion of the GA traffic being discussed (business jets)
wouldn't "get along just fine" without some large amount of ATC.
Old September 13th 07, 07:09 PM posted to rec.aviation.piloting,rec.travel.air
Gig 601XL Builder
[snip]
commercial hubs, and a couple like Teterboro that attract a bunch
of CEO flights.
control, or departure control.
That doesn't change the fact that airline traffic needs the ATC system WAY
more than the GA traffic does. What airport are you talking about?
Old September 13th 07, 07:16 PM posted to rec.aviation.piloting,rec.travel.air
me[_2_]
On Sep 13, 2:09 pm, "Gig 601XL Builder" wrDOTgiaconaATsuddenlink.net
[snip]
of CEO flights.
Of the traffic being discussed, I'd suspect that is not true. Not
sure
how to prove it however. For GA in general, I'd suspect the vast
majority
would PREFER no ATC.
DED
Old September 13th 07, 07:38 PM posted to rec.aviation.piloting,rec.travel.air
Gig 601XL Builder
[snip]
without ATC at all. With the exception of a few airports that are
of CEO flights.
system WAY more than the GA traffic does.
sure
majority
DED
The current AFD shows that Daytona handles approach and departure and
there's no tower freq listed
http://www.naco.faa.gov/pdfs/se_56_30AUG2007.pdf and it looks like it seldom
averages more than 2 IFR operations per hour
http://flightaware.com/analysis/grap...t?airport=KDED.
But all that aside. Do you really think that the incremental cost to the ATC
system for the services provided to a Cessna Citation III are really over
$24/hour? If not then GA is paying it's fair share because the ATC system is
primarily there because of the airlines. Others use it because it is there.
Travel aid [email protected] Soaring 0 February 7th 06 12:25 PM
Travel aid [email protected] Restoration 0 February 7th 06 12:25 PM
Travel aid [email protected] General Aviation 0 February 7th 06 12:25 PM
Travel aid [email protected] Aviation Marketplace 0 February 7th 06 12:25 PM
Travel Supplements Jetnw Aviation Marketplace 0 September 15th 04 07:50 AM
