AIR FORCE WORKING TO REMOVE CORROSION FROM F-22A FIGHTER JETS
Old September 13th 07, 07:56 PM posted to rec.aviation.military,rec.aviation.military.naval
Daryl Hunt
Default AIR FORCE WORKING TO REMOVE CORROSION FROM F-22A FIGHTER JETS
"Juergen Nieveler" wrote in message
"Daryl Hunt" wrote:
Newsflash, NDI or Non-Destructive Inspection is part of EVERY
Scheduled Maintenance Dock inspection. Yes, they do inspect for
corrosion and metal fatigue as well. This goes for ALL Aircraft
regardless of age. Twisting this into something other than Preventive
Maintenance is just plain wrong.
PM is certainly being done - but they are talking about "removing
recently discovered corrosion".
Woppy Doo. There is ALWAYS "newly or recently formed" corrosion. The
exotic metals required corrode and get worse as they age and corrode even
more.
PM means checking if something is corroded - but this sounds like
somebody did PM and discovered that the planes have corroded parts, and
that those parts are now being fixed, which is a totally different
story.
Nope, same story.
Old September 14th 07, 06:59 PM posted to rec.aviation.military,rec.aviation.military.naval
Daryl Hunt
even
more.
You mean the F-22 corrodes faster than a 1970s Toyota? ;-)
story.
Nope, same story.
So we can agree that there are parts of this brand new airplane that
are corroded to the point where they have to get replaced - which means
that somebody will have to take a look at the maintenance budget.
Corrosion does occur, that's normal - but those planes are HOW old? And
need spare parts already? THAT is the real story behind this - the F-22
was supposed to be less maintenance-intensive.
I have yet to see a Toyota flying at M.1.5 and 50,000 feet. And NOTHING
corrodes faster than an old Toyota.
Old September 14th 07, 07:55 PM posted to rec.aviation.military,rec.aviation.military.naval
Alistair Gunn
In rec.aviation.military Daryl Hunt twisted the electrons to say:
Put enough thrust behind one and I'm sure it would be possible?
And NOTHING corrodes faster than an old Toyota.
What about the late-70s/early-80s products of Fiat and Alfa Romeo?
These opinions might not even be mine ...
Let alone connected with my employer ...
Old September 14th 07, 08:52 PM posted to rec.aviation.military,rec.aviation.military.naval
"Alistair Gunn" wrote in message
Rust: designed by the Japanese, mass-produced by the British and perfected
by the Italians.
Cheers,
Old September 15th 07, 03:02 AM posted to rec.aviation.military,rec.aviation.military.naval
Dan[_2_]
They never made it to the US - didn't survive the shipping ;-)
Juergen Nieveler
Doesn't Fiat mean fix it again, tony?
Dan, U.S. Air Force, retired
Old September 15th 07, 02:19 PM posted to rec.aviation.military,rec.aviation.military.naval
Andrew Chaplin
"Dan" wrote in message
Juergen Nieveler
"Feeble Italian Attempt at Transportation."
Andrew Chaplin
SIT MIHI GLADIUS SICUT SANCTO MARTINO
(If you're going to e-mail me, you'll have to get "yourfinger." out.)
Hunting scopes in fighter jets? DDAY Naval Aviation 8 August 30th 06 06:26 PM
Air Force Working to Combat Stressors Otis Willie Military Aviation 0 September 18th 04 03:54 AM
Bush Flew Fighter Jets During Vietnam WalterM140 Military Aviation 609 September 11th 04 03:26 AM
U.S. Air Force to purchase 1,763 LOCKHEED MARTIN F-35 Joint Strike Fighter jets for $245 billion Larry Dighera Military Aviation 0 July 22nd 04 06:06 AM
Bush flew fighter jets, but never over VIETNAM. ArtKramr Military Aviation 159 July 21st 04 02:22 PM
