"The doomsday plane
Old September 16th 07, 03:52 AM posted to rec.aviation.military,rec.aviation.piloting
Mxsmanic
Default "The doomsday plane
Leadfoot writes:
Ground hydraulic units use green hoses
Perhaps that is it, then.
But I've never seen one hooked up near the wing tip on a 747. Usually you
use the hydrualic servicing panel in the gear wheel well.
That's what I would expect, so it was puzzling.
  #54
Old September 16th 07, 05:05 AM posted to rec.aviation.military,rec.aviation.piloting
In rec.aviation.piloting Mxsmanic wrote:
Leadfoot writes:
Since the airplane is sitting with engine covers on in the middle of
one of the EMP test stands at Kirtland AFB, it is most likely some
sort of instrumentation.
And, if you look closely, there another connection to the other wing
tip.
But whatever it is, it certainly isn't fueling.
Jim Pennino
Remove .spam.sux to reply.
  #56
Old September 16th 07, 05:30 AM posted to rec.aviation.military,rec.aviation.piloting
John Keeney
On Sep 15, 10:51 pm, Mxsmanic wrote:
writes:
Are you talking about the building behind the airplane associated
with the wire antenna system?
I'm talking about the flexible green conduit that appears to be connected to
the wing near its tip.
Ah, I was wondering. Not sure what that is but definitly not for
adding fuel to the plane.
  #57
Old September 16th 07, 07:22 AM posted to rec.aviation.military,rec.aviation.piloting
Leadfoot[_2_]
Leadfoot writes:
you
Instrumentation is orange not green
tip.
Jim Pennino
  #58
Old September 16th 07, 07:30 AM posted to rec.aviation.military,rec.aviation.piloting
J a c k
B A R R Y wrote:
During the first genuine commercial power failure, there were people
carrying 5 gallon jugs up 12 1/2 stories of stairs to keep the
generators running.
Once started, the generators couldn't run their own pumps?
Jack
  #59
Old September 16th 07, 11:10 AM posted to rec.aviation.military,rec.aviation.piloting
B A R R Y
On Sun, 16 Sep 2007 01:30:38 -0500, J a c k
generators running.
They were accidentally wired to the commercial side of the transfer
switch. During tests, commercial power was never removed, so the
pumps worked. The first time the power actually failed long enough to
use up the day tank... G
  #60
Old September 16th 07, 01:37 PM posted to rec.aviation.military,rec.aviation.piloting
Mxsmanic
writes:
Real aircraft don't fuel from the wing tips.
Yes, that's what I thought. So what is it?
Saw President Bush's plane (response to "Saw J.T.'s Plane") Ricky Piloting 60 September 1st 07 09:25 PM
Jay's "Plane Crash Video Ubersite" Peter Duniho Piloting 18 August 14th 06 05:45 AM
Have you created anything "home-made" for your plane? (or a low cost alternative?) Andy Piloting 69 April 29th 06 03:25 PM
Have you created anything "home-made" for your plane? (or a low cost alternative?) Andy Owning 61 April 29th 06 03:25 PM
