Question about glide ratios (for the aerodynamically skilled)
Old September 17th 07, 03:10 AM posted to rec.aviation.piloting
Roger (K8RI)
Default Question about glide ratios (for the aerodynamically skilled)
On Sun, 16 Sep 2007 15:15:25 -0000, Tina
As best I can tell, it seems for a given configuration air speed for
best glide angle (I will define best as most shallow angle) changes
with weight, but the angle itself doesn't change much. Hi performance
gliders carry water to increase penetration into headwinds, dump it
to increase time aloft, but still go down about foot for every 20 some
they move thru the air, don't they?
I certainly hope they do better than that. An F-33 Bonanza is between
17 and 20:1 clean (depending on how heavily it's loaded.) My old Deb
has almost twice the ratio of a 172. Best glide is @ 120 MPH (give or
take)and that gives a rate of descent between 500 and 600 fpm.
Roger (K8RI)
I need, for a fictional piece I'm writing, an efficient long range low
power consumption airplane and don't want it to fail because of
technical errors.
Thanks for your comments
Are you thorough, I mean, exerting to individual ratios? Yosri al Jabr Piloting 0 August 14th 07 01:52 AM
wide wingspan and good lift to drag ratios Tony Piloting 6 March 13th 06 01:19 AM
question on glide ratio functions in Garmin 96, 96C, 196 GPS Steve S Soaring 1 January 10th 06 07:43 PM
silly question on best glide speed? Piloting 13 October 24th 05 02:00 AM
But, I'm a skilled professional [email protected] Piloting 10 December 2nd 04 05:01 AM
