"R Haskin" wrote: If you've got a parachute, what are you ditching for, anyway? Jumping out is a lit less risky than ditching a fixed-gear airplane which will almost surely flip over once it touches down... I'm assuming you've never made a parachute jump into water. I have, you can die quite easily unless you know what you're doing. And, most people who would be wearing a parachute (not including the military here) would have a rig that has NO quick disconnects for the risers or harness which is going to make things even harder. I don't believe the stats are going to support your statement that the airplane will "almost surely flip over". If you fly over water you should attend a survival course that teaches ditching evacuation using a "dilbert dunker" type device. Very enlightening, after doing so I quit flying over water. G -- Dale L. Falk There is nothing - absolutely nothing - half so much worth doing as simply messing around with airplanes. http://home.gci.net/~sncdfalk/flying.html |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 1 | November 24th 03 02:46 PM |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 2 | November 24th 03 05:23 AM |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart Hull | Home Built | 0 | November 24th 03 03:52 AM |
Aluminum vs Fiberglass landing gear - Pro's and cons. | Bart D. Hull | Home Built | 0 | November 22nd 03 06:24 AM |
Landing gear door operation | Elliot Wilen | Military Aviation | 11 | July 8th 03 03:30 AM |
