787 flawed
Old September 18th 07, 03:06 PM posted to rec.aviation.piloting
WhoGivesAFig?
Default 787 flawed
This could be huge
http://seattletimes.nwsource.com/ABP...2003889769.pdf
Old September 18th 07, 04:18 PM posted to rec.aviation.piloting
WhoGivesAFig?
Default 787 flawed
Richard Riley wrote:
On Tue, 18 Sep 2007 10:06:06 -0400, WhoGivesAFig?
This could be huge
Or it could be nothing. Real world experinece with smaller composite
airplanes have showed them to be MUCH more crashworthy than aluminum
airplanes. Composite small planes have been certified for lightning
strike before.
You are correct. I should have said "May" be flawed
Old September 18th 07, 05:35 PM posted to rec.aviation.piloting
C J Campbell[_1_]
Default 787 flawed
On 2007-09-18 07:06:06 -0700, WhoGivesAFig? said:
This could be huge
Hmmm. A retired employee who worked for Boeing for 46 years claims to
know more than the FAA and Boeing about how planes should be crash
tested. He concludes that composites are not as crashworthy as metal,
but does not back his assertions up with any hard data.
His complaint is that composite materials are stronger in some
directions than they are in others, that cracking is less visible, and
that composites are more subject to fire and more vulnerable to
lightning. He points out that g levels in a crash are unlikely to be
uniform all along a composite structure. All of this is true, but he
seems to be alleging some sort of Boeing coverup of these facts. He
discounts actual experience with other composite aircraft, saying that
either they are not airliners subjected to the stress and number of
flights that airliners get, or that the numbers of such composite
aircraft are too few to be statistically significant.
Of course, his report will make great fodder for trial lawyers when the
first 787 crashes, no matter what the actual cause of death of the
passengers is. Weldon seems to be down at the site trying to tell
people how to crash test an airplane even though he no longer works
there. No doubt his experience is valuable, but he cannot possibly be
aware of everything that Boeing is doing to mitigate these problems and
Boeing is certainly not going to give corporate secrets to former
employees.
Waddling Eagle
World Famous Flight Instructor
Old September 18th 07, 05:47 PM posted to rec.aviation.piloting
WhoGivesAFig?
Default 787 flawed
This could be huge
passengers is. Weldon seems to be down at the site trying to tell people
how to crash test an airplane even though he no longer works there. No
doubt his experience is valuable, but he cannot possibly be aware of
everything that Boeing is doing to mitigate these problems and Boeing is
certainly not going to give corporate secrets to former employees.
He claims to know more than Boeing he may or may not. 46
years is a lot of experience. Does he know more than the
FAA? My dog knows more than the FAA about aviation.
Old September 18th 07, 07:14 PM posted to rec.aviation.piloting
Bertie the Bunyip[_19_]
Default 787 flawed
WhoGivesAFig? wrote in
said:
This could be huge
and that composites are more subject to fire and more vulnerable to
that either they are not airliners subjected to the stress and number
of flights that airliners get, or that the numbers of such composite
the first 787 crashes, no matter what the actual cause of death of
the passengers is. Weldon seems to be down at the site trying to tell
and Boeing is certainly not going to give corporate secrets to former
employees.
I think I just found a new pet.
Bertie
Old September 18th 07, 08:47 PM posted to alt.disasters.aviation,alt.usenet.kooks,alt.alien.vampire.flonk.flonk.flonk,rec.aviation.piloting
WhoGivesAFig?
Default 787 flawed
said:
This could be huge
employees.
Bertie
You can have him. He is a fat worthless
mutt. Just like a Government employee
Old September 18th 07, 08:59 PM posted to rec.aviation.piloting
Default 787 flawed
WhoGivesAFig? wrote in newsWVHi.40$Wv3.34
@newsfe06.lga:
said:
This could be huge
to
metal,
be
he
number
composite
tell
be
former
employees.
Bertie
I meant you, fjukkwit.
Fetch!
Bertie
Old September 19th 07, 03:27 AM posted to rec.aviation.piloting
Andrew Sarangan
Default 787 flawed
On Sep 18, 12:35 pm, C J Campbell
This could be huge
employees.
Waddling Eagle
That was an interesting letter. The questions he raise are all valid.
The public (including us) simply assume that the relevant crash
worthiness and fire worthiness results have been thoroughly studied
and found to be adequate. I am assuming that Boeing has the answers to
these questions, but if they don't, this is the time to be asking
these questions.
I have personally witnessed the post-crash fire of an experimental
Velocity. When the fire was out, there was nothing left on the ground
except some metal parts from the wheels, avionics and control links.
All the composite parts had simply evaporated. It was unbelievable.
The two occupant were taken with severe burn, but I never found out
whether they survived.
I also personally know of a pilot who experienced a lightening strike
on his all-composite experimental airplane. There were some burn marks
on the airframe, and all his avionics had to be replaced. Although
there did not appear to be any structural damage, he was saying there
was no way of checking if there are any internal problems due to
delaminations. We assumed that production models probably use an
embedded wire mesh to discharge the current.
Old September 19th 07, 03:46 AM posted to rec.aviation.piloting
Dan Luke[_2_]
Default 787 flawed
IOW, about the same as what's left of a burned out aluminum airplane.
And they'd have fared better in an aluminum airplane? Why?
Dan
T-182T at BFM
Old September 19th 07, 06:57 AM posted to rec.aviation.piloting
Default 787 flawed
On Tue, 18 Sep 2007 22:47:08 -0700, Richard Riley
On Tue, 18 Sep 2007 12:47:09 -0400, WhoGivesAFig?
I don't know what you have to do to get fired from Boeing with 46
years of seniority, but it's a LOT.
According to today's newspaper, he allegedly threatened to hang his manager on a
meat hook, and supposedly made some sort of reference to a noose. He's denied
the noose comment, and claims the meat hook reference wasn't a threat.
Military parts were flawed, indictment says Otis Willie Military Aviation 0 September 3rd 04 08:58 PM
Florida List for Purge of Voters Proves Flawed WalterM140 Military Aviation 2 July 10th 04 05:57 PM
