![]() "L.D." wrote in message ... I'm no engineer and don't have a lots of formal smarts but common sense tells me if the following is true, then PVC is useless as tits on a boar hog for any use. 4 psi??? "when you do all the required derates and apply all the safety factors required for sound engineering practices, 1" PVC is rated to handle about 4psi working pressure." L.D. Craig wrote: It works great at what it is intended for, when installed correctly, and that is cold water supply. The temperature is the big issue, when dealing with pressure. Any building inspector has a piece of pvc blown up from 3/4" up to about 3", found after someone incorrectly installed it hooking up a hot water heater. -- Jim in NC |
