Morgans wrote:
"Gig 601XL Builder" wrote Now here's the kicker. Just because that certified engine and prop were mounted and flown in an experimental they can never be considered certified again. That is not consistant with what I have read. If you keep the original data plate on the engine, and do all repair work and follow all of the directives for the engine, and the work is done by an A&P, then what you mount it in is not important. When you take it out, if all work (engine maintenance and rebuilds) as been done up to FAA standards by or supervised by an A&P, you can indeed put the engine back into a certified plane. AS far as the prop goes, I am not up with the requirements on them, but I "believe" the same standards apply for it. The problem arises that if ANY alterations or work has been done to the engine not by an A&P or supervised by one the certification is in doubt. In the real world once it is in an experimental you'd be hard pressed to get anyone to believe that it is still a certified engine. |
Cockpit instruments | T L Jones | Restoration | 0 | November 19th 03 08:40 PM |
