there are no instrument requirements for gliders in the FAR's. So if
you have a type certified glider the only thing that governs you would be the Handbook or the Type Certificate. For experimental, it completely depends on your operating limitations that were issued with your airworthiness certificate. My Cherokee's Op Lims say that I must be equipped IAW 91.207, so I have a compass. The only reason I have a compass is to keep the FAA happy. its a normal "whiskey" compass and bobbles around constantly. |
On Sep 21, 9:39 am, wrote:
there are no instrument requirements for gliders in the FAR's. The compass requirement may be found on the Type Certificate Data Sheet. 14 CFR (aka "FAR") 91.205 (addressing POWERED aircraft...which would include motorgliders) says that aircraft must have a magnetic direction indicator. While it may not spell out "g-l-i-d-e-r", having one to avoid pain during a ramp check might be worthwhile. I have PAI-700's in both my glider and power plane. Some times they work well, some times they're less desirable than the old whiskey compass (e.g., in a nose high attitude...). On some airplanes, the vertical card compass is superior (a Bonanza I used to fly comes to mind). The chief advantage is a good picture of current vs. desired heading (or heading to a landmark...maybe useful when navigating near restricted airspace). Be sure to have a compass correction card on board...I got dinged by the absence of the sheet...fortunately by my A&P during an annual inspection! I've never had a compass stop working because the batteries were dead. Maybe that's why they're required? -Pete #309 |
Vertical Card Compass? | Bubba[_2_] | Owning | 10 | April 2nd 07 03:31 PM |
Vertical card compass? | Bubba[_2_] | Home Built | 1 | March 31st 07 12:49 AM |
Vertical Card Compass | Bubba[_2_] | General Aviation | 0 | March 30th 07 06:56 PM |
Vertical Card Compass? | Bubba[_2_] | Aviation Marketplace | 0 | March 30th 07 06:56 PM |
Vertical card compasses | Dan Luke | Owning | 13 | March 1st 04 11:23 PM |
