Being multiband is not illegal. I believe the issue is civilian use of
military frequencies There are plenty of multiband radios on the market - some amatuer radio/HAM equipment can broadcast on 4 distinct bands. Yaesu used to make a VHF/UHF public safety band radio. Just not seen any civilian transcievers that do VHF and UHF air band - and the stick in the mud is UHF air band cause its uncle sams. Dave buttman wrote: I'm in the market for a handheld scanner. Ideally I'd like one that can both receive and transmit on the 108-136 "airband", as well as be able to receive ATIS and CTAF broadcasts from military airports, which I believe are UHF and in the area of 276 MHz. Apparently, such a device is illegal (that can transmit and receive on two different "bands"), so I guess I can live with a unit that can only receive those frequencies, but can't transmit. I've been trying to do research on which unit to get, but it's all very confusing. I guess there are a bunch of different "modes" of transmissions, (AM, FM, WFM, etc) and military airplanes only transmit using one of those types, yet most scanners only decode AM (or something). As you can tell, I'm not a radio expert, so I was hoping if someone out there knows their stuff, they could point me in the right direction. I'm looking to spend about 300 bucks or less. Thanks. |
Which PC Flightplanning Software EFB Would You Recommend? | FlyBean | Instrument Flight Rules | 9 | September 20th 05 01:11 AM |
Ok to recommend? | Roger Opar | Piloting | 19 | February 24th 05 12:00 AM |
Recommend an IA or A&P for prebuy in Ft. Lauderdale. | Paul | Owning | 0 | February 29th 04 08:39 PM |
recommend a good aircraft painter/shop on the NE or East coast | Baron Man | Owning | 8 | January 15th 04 05:24 PM |
Recommend A&P Tulsa Area? | Carl Orton | Owning | 2 | December 4th 03 01:36 PM |
