randall g writes:
In principle this is not hard to troubleshoot. With the engine running and a full electrical load, simply measure the voltage starting at the alternator and moving back to the avionics buss and battery, at all possible points. At the alternator it should be over 14.0 I think. This should isolate where there is a voltage drop, and therefore too much resistance. The problem is; on a car you have to dodge the radiator fan, but if I'd ever worked on a plane (not me!!!! That would Be Wrong..) I'd wonder if that big fan out front did not make life lots harder... and THAT's while it is sitting still. But a good test is, after the voltage is stable [ie the starting drain has been recouped..] is to go from no load to fax load while looking at the voltage. What we are asking is: what's the voltage drop between the battery and the avionics buss? If it is drop in the wiring, looking at no load will show a voltage ~identical to that at the battery. -- A host is a host from coast to & no one will talk to a host that's close........[v].(301) 56-LINUX Unless the host (that isn't close).........................pob 1433 is busy, hung or dead....................................20915-1433 |
Mooney Low Voltage | [email protected] | Owning | 22 | August 1st 05 01:01 PM |
FA: 12V to 24V DC voltage converter | Karl Geng, N1DL | Home Built | 2 | April 21st 05 08:48 PM |
Altimeters and air pressure variation | jharper aaatttt cisco dddooottt com | Piloting | 22 | January 12th 05 09:21 PM |
magnetic variation | Angus Lepper | Simulators | 1 | September 23rd 03 06:58 AM |
