![]() "Mark Hansen" wrote in message ... The EFC is of use only if you experience communication failure. Assuming that's the case, then with no EFC, you're expected to proceed upon reaching the holding fix as though the EFC was zero. Thanks for the correct answer. In the meantime, I also found the answer in AIM 91.185(c)(3)(ii): "...leave the clearance limit at the expect further clearance time if one has been received, or if one has not been received, ... as close as possible to the ETA..." Thanks, Dennis |
On 09/24/07 20:14, Dennis Johnson wrote:
"Mark Hansen" wrote in message ... The EFC is of use only if you experience communication failure. Assuming that's the case, then with no EFC, you're expected to proceed upon reaching the holding fix as though the EFC was zero. Thanks for the correct answer. In the meantime, I also found the answer in AIM 91.185(c)(3)(ii): "...leave the clearance limit at the expect further clearance time if one has been received, or if one has not been received, ... as close as possible to the ETA..." Yes, and that is the answer you want to give on the exams, but in real life, you'll find that the controllers want you out of the air as soon as possible. They're expecting you to get on the ground asap. I wouldn't plan on waiting for your ETA once you get to the fix... -- Mark Hansen, PP-ASEL, Instrument Airplane, USUA Ultralight Pilot Cal Aggie Flying Farmers Sacramento, CA |
Mark Hansen wrote:
On 09/24/07 20:14, Dennis Johnson wrote: "Mark Hansen" wrote in message ... The EFC is of use only if you experience communication failure. Assuming that's the case, then with no EFC, you're expected to proceed upon reaching the holding fix as though the EFC was zero. Thanks for the correct answer. In the meantime, I also found the answer in AIM 91.185(c)(3)(ii): "...leave the clearance limit at the expect further clearance time if one has been received, or if one has not been received, ... as close as possible to the ETA..." Yes, and that is the answer you want to give on the exams, but in real life, you'll find that the controllers want you out of the air as soon as possible. They're expecting you to get on the ground asap. I wouldn't plan on waiting for your ETA once you get to the fix... If you really lose comm, waiting until your ETA is the correct procedure. Matt |
![]() "Matt Whiting" wrote in message ... If you really lose comm, waiting until your ETA is the correct procedure. Why? |
Steven P. McNicoll wrote:
"Matt Whiting" wrote in message ... If you really lose comm, waiting until your ETA is the correct procedure. Why? Why not? |
![]() "Matt Whiting" wrote in message ... Why not? Waiting for the ETA ties up airspace and delays other aircraft. |
"Matt Whiting" wrote in message ... Why not? Waiting for the ETA ties up airspace and delays other aircraft. ATC won't clear anyone into your block of airspace until after your EFC time to prevent two aircraft in IMC from using the same space. Rip |
"Matt Whiting" wrote in message ... If you really lose comm, waiting until your ETA is the correct procedure. Why? Because you own the block of airspace assigned to you. Someone else owns the block of airspace ahead of and behind you. You wait until your EFC time so that you don't blunder into the guy ahead in IFR conditions. Rip |
rip wrote:
Because you own the block of airspace assigned to you. Someone else owns the block of airspace ahead of and behind you. You wait until your EFC time so that you don't blunder into the guy ahead in IFR conditions. When you go NORDO ATC is going to clear everyone else out of your way. Just get on the ground and relieve ATC of their misery. DGB |
![]() Dave Butler writes: When you go NORDO ATC is going to clear everyone else out of your way. Just get on the ground and relieve ATC of their misery. Sounds plausible for a bugsmasher, maybe. But, imagine how ATC (and NORAD for that matter) might respond to a bigger plane that goes NORDO and instead of following the proper procedures, starts improvising. - FChE |
Bose X - $995 and holding... | [email protected] | Piloting | 23 | November 30th 05 12:57 AM |
Holding pattern reporting | Yossarian | Instrument Flight Rules | 14 | July 4th 05 10:57 AM |
Stupid Newbie Pattern Question | Lakeview Bill | Piloting | 76 | June 11th 05 02:54 PM |
Holding at CHS | Stuart King | Instrument Flight Rules | 3 | November 10th 03 07:52 PM |
Holding Pattern Entries | Dan Luke | Instrument Flight Rules | 17 | July 11th 03 05:18 AM |
