Some tailwheel questions/comments
Old September 25th 07, 06:39 PM posted to rec.aviation.piloting
Default Some tailwheel questions/comments
Not really, and I'd be surprised if you could taxi a Citabria with the
tailwheel raised anyway. Easy in a cub, though.
Firstly this isnt a troll and if somebody feels it is, they simply
need to ignore it, thats how usenet works. Anyways, the question was
based more on what I saw on the takeoff run where we raise the tail as
airspeed increases. It just felt more stable and more like a
conventional gear takeoff run in that phase, so I was just wondering.
The intent of the question wasn't about how to taxi at a high speed.
The problem with the Citabria is it's a bit too easy for tailwheel
conversion. You'll get the basics, but if you try a cub afterwards you'll
find it significantly more difficult, wheras the other way around would be
a piece of cake. Citabria is a good airplane, but it's not the best
tailwheel trainer for that reason. However, it will certainly do in a
pinch!
Thanks for the tip, I have been looking to find a place to learn in a
cub but the closest one is about 70 miles away, so that may have to
wait.
The CG doesn't change significantly when the tail is raised, though, to
answer your question, and fast taxiing is something best left to someone
with a LOT of tailwhel time. Taxiing on the mains is something best left to
airshow pilots or guys that can afford to replace props as easily as they
would buy a cup of coffee.
What my instructor seemed to imply (and things didn't really sink in
till about a day after the flying) was that the takeoff roll is more
stable when the tail is up. So I was wondering if the CG shifts
forward when the tail is raised because this is a more stable
configuration than when the CG is behind the main wheels.
Old September 25th 07, 06:49 PM posted to rec.aviation.piloting
Bertie the Bunyip[_19_]
wrote in
ups.com:
the tailwheel raised anyway. Easy in a cub, though.
Ah, OK. Wel, the main reason you get the tail up is to aid acceleration
and to have th eairplane in the correct atttude when you rotate.
You have a lot of power on and that is why the airplane feels more
stable than when you are taxiing. The reason being the vast amount of
air yu have going over the rudder.
Not all airplanes re like that, BTW. Some get very interesting when you
raise the tail on takeoff!
you'll find it significantly more difficult, wheras the other way
around would be a piece of cake. Citabria is a good airplane, but
it's not the best tailwheel trainer for that reason. However, it will
certainly do in a pinch!
wait.
Nothing wrong with a Citabria, but the cub is just so perfect. You'll
learn a lot in a Citabira as well, Just be aware that when you get the
tailwheel signoff you're not "there" In fact it doesn't matter what
you've been checked out in, you're only just like a kid who's been let
go onhis first two wheeler..
to
someone with a LOT of tailwhel time. Taxiing on the mains is
something best left to airshow pilots or guys that can afford to
replace props as easily as they would buy a cup of coffee.
Ah, OK. Well, it might have something to do with that, but I'd suspect
it;s more to do with decreasing the angle of attack on the wings.
Bertie
Old September 26th 07, 04:16 AM posted to rec.aviation.piloting
Phil
pinch!
wait.
OK, I'm just a student pilot, and not a taildragger student either.
But I know a little physics. The CG is still behind the mains even
with the tail up. It is possible that the airplane would feel more
stable in yaw when it is accelerating, however. Since the center of
gravity is being pulled along behind the propeller, I would think the
airplane would tend to stay in line. This ignores other influences
like crosswinds and the torque effects of the prop which would tend to
counter this. And it won't help you in taxiing when you are moving at
a constant speed.
Old September 26th 07, 06:37 AM posted to rec.aviation.piloting
a constant speed.
Yes, you are right about the CG not changing, I was probably
mistakenly thinking that the CG moves forward relative to the ground
as the airplane nose is "lowered" but I think that's not correct. The
stability in a level attitude while taxing probably also comes from
the fact that the P-factor is gone and there is no turning tendency
any more.
Old September 26th 07, 04:24 PM posted to rec.aviation.piloting
a constant speed.
any more.
Thrust acts along the centerline whether the airplane is
tracking straight or not, whether the CG is behind the mains or in
front. The only time thrust is a little off is when the AOA is high
(tail low) and the downgoing blade has more pull (P-factor). The
airplane will still want to pull left with the tail up due to the
swirl of the prop slipstream striking the left side of the fin, and a
small amount caused by more pressure on the left main due to engine
torque reaction. Raising the tail will make the nose swerve left, a
gyroscopic precession caused by the prop's rotating mass.
Whatever the airplane tries to do, you have to be ready for it
and not afraid to use ALL the controls rather aggressively to show it
who's boss. It won't fly itself.
Dan
2nd RFD: remove rec.aviation.questions moderated (LAST CALL FOR COMMENTS) Jim Riley Piloting 0 March 10th 07 09:41 AM
2nd RFD: remove rec.aviation.questions moderated (LAST CALL FOR COMMENTS) Jim Riley Owning 0 March 10th 07 09:41 AM
2nd RFD: remove rec.aviation.questions moderated (LAST CALL FOR COMMENTS) Jim Riley Instrument Flight Rules 0 March 10th 07 09:41 AM
2nd RFD: remove rec.aviation.questions moderated (LAST CALL FOR COMMENTS) The Big-8 Management Board General Aviation 0 March 10th 07 05:50 AM
wanted scott 3200 tailwheel /alaskan bushwheel tailwheel phillip9 Aviation Marketplace 0 June 6th 06 07:57 PM
