"Bertie the Bunyip" wrote
One piece of advice I can give that's useful to new talidragger pilots, or at least I've found it so, is to get religious about aving the controls in the right position when taxiing in wind. Any wind at all. Even three knots. For one thing, having the ailerons in particualr, plcaed correctly, you increase your control of the airplane dramatically. Being in the habit of doing this wil give you the edge you need it during crosswind landings. It's habits that come to the forefront when your brain degenerates to it's primevel state when things start happening quickly. Good advice. It's easy to get complacent about control positioning while taxiing, and I know what you mean about the difference in control when they're in the right position. You can definitely feel the difference. BTW, when taxiing with a tailwind you need to reverse, as yo know. Don't forget to consider the taxi speed of your airplane in relation to the wind. Elevators are tricky in this situation. If you got a roaring tailwind, you need to have them forward (Careful with the power here or you could have an instant headwind as far as your elevators are concerned) It can be hard to tell if you need the elevators up or down when you're taxing downwind, but th erule I use is if you can feel the stick "click" as the wind passes ovr the elavotrs as you move them up and down you should have them down. Make sense? I'll have to try that rule of thumb next time but it sounds like what you're saying is that if you can feel the wind pushing on the elevator as it moves through neutral then it should be down. I've been taxiing with the elevator full forward in all tailwind conditions up to this point, and that's probably not a good habit to get into, especially when moving into something with more power. BDS |
On 25 Sep, 19:03, "BDS" wrote:
"Bertie the Bunyip" wrote One piece of advice I can give that's useful to new talidragger pilots, or at least I've found it so, is to get religious about aving the controls in the right position when taxiing in wind. Any wind at all. Even three knots. For one thing, having the ailerons in particualr, plcaed correctly, you increase your control of the airplane dramatically. Being in the habit of doing this wil give you the edge you need it during crosswind landings. It's habits that come to the forefront when your brain degenerates to it's primevel state when things start happening quickly. Good advice. It's easy to get complacent about control positioning while taxiing, and I know what you mean about the difference in control when they're in the right position. You can definitely feel the difference. BTW, when taxiing with a tailwind you need to reverse, as yo know. Don't forget to consider the taxi speed of your airplane in relation to the wind. Elevators are tricky in this situation. If you got a roaring tailwind, you need to have them forward (Careful with the power here or you could have an instant headwind as far as your elevators are concerned) It can be hard to tell if you need the elevators up or down when you're taxing downwind, but th erule I use is if you can feel the stick "click" as the wind passes ovr the elavotrs as you move them up and down you should have them down. Make sense? I'll have to try that rule of thumb next time but it sounds like what you're saying is that if you can feel the wind pushing on the elevator as it moves through neutral then it should be down. I've been taxiing with the elevator full forward in all tailwind conditions up to this point, and that's probably not a good habit to get into, especially when moving into something with more power. BDS Yes, sounds like you got the idea. An awful lot of airplanes end up on their nose (particularly Supercubs for some reason) because the pilot turns downwind quickley using a bit of brake at the same time. Bertie |
On Sep 25, 3:11 pm, Bertie the Bunyip
wrote: Yes, sounds like you got the idea. An awful lot of airplanes end up on their nose (particularly Supercubs for some reason) because the pilot turns downwind quickley using a bit of brake at the same time. Bertie Some quick ways to get a taildragger up on its nose: -Using lots of brake in the rollout without using elevator to maintain attitude. And holding the brakes on hard even when the speed is gone. -Taxiing too fast downwind and either losing control (no airflow over the surfaces; got to fly a taildragger all the time, remember?) and initiating a groundloop, or turning too quickly out of a tailwind. The wind against the side of the fuselage, under the upwind wing and under the stab combines with centrifugal force to lift a wheel, whereupon the downwind wing drags on the surface, and now that more wind can get at the wing and stab, there's more lift, the tail comes up, and inertia through the CG and against the dragging wing does the rest. -With CG forward (nobody in the back), doing a runup without holding the elevator back will lift the tail of many taildraggers. As the tail comes up, the angle between the CG and the locked mains decreases so that the tail gets even lighter, and over she goes. Happens if the pilot has his head in the cockpit and isn't paying attention to what's going on outside. Can happen, too, if the pilot is trying to taxi through deep snow or gooey mud. Dan |
2nd RFD: remove rec.aviation.questions moderated (LAST CALL FOR COMMENTS) | Jim Riley | Piloting | 0 | March 10th 07 09:41 AM |
2nd RFD: remove rec.aviation.questions moderated (LAST CALL FOR COMMENTS) | Jim Riley | Owning | 0 | March 10th 07 09:41 AM |
2nd RFD: remove rec.aviation.questions moderated (LAST CALL FOR COMMENTS) | Jim Riley | Instrument Flight Rules | 0 | March 10th 07 09:41 AM |
2nd RFD: remove rec.aviation.questions moderated (LAST CALL FOR COMMENTS) | The Big-8 Management Board | General Aviation | 0 | March 10th 07 05:50 AM |
wanted scott 3200 tailwheel /alaskan bushwheel tailwheel | phillip9 | Aviation Marketplace | 0 | June 6th 06 07:57 PM |
